Power supply repair (FHF 8N60 IC )
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi, There I'm trying to repair a DJ light power supply which was blowing the internal fuse upon inspection the MOS FHF8N60 TO-220F 8A/600V ic was shorted with all pins. The only place I can source them from is china and won't be here till September. So I'm looking for advice on anything that I can get that is compatible with this chip.
    Thanks in advance
    Your never to old to learn
    Re: Power supply repair (FHF 8N60 IC )
    1) What is the SMPS IC U1 P/N?
    2) Did you check the power resistor connected between the Source pin of the MOSFET and the HOT side circuit ground to make sure it is still OK?
    3) Did you check R11?
    4) Did you check the components (R8, Q2, D3, etc.) between Gate drive output of the SMPS IC and the Gate of he MOSFET to make sure they are not damaged?
    5) When MOSFET shorted out like that, it usually takes out the SMPS IC with it, so if you do not change the SMPS IC you may take a chance of blowing up the new MOSFET.
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Thanks budm for your reply i will upload a pic of u1
      and i will check the rest when i get home tonight.
      Thanks Again for your reply
        U1 = sp6853
        • garrymc123
          • Apr 2010
          • 336
          • United Kingdom
          Hi Budm
          I'm in the progress of checking the items but was a bit confused with the pinout of the Mosfet I Have marked on the first pic what I think it the gate source drain which is different from the datasheet. On Ic u1 I have a short between pin 1 which is ground and pin 6 out which is for the gate of the MOSFET.
          The power resister is showing 000.2 ohms
          R11 =472.1
          R8 = 09.96 kohms on board testing
          q2 = not sure what is is yet with the markings y2
          D3 = 0.583 one way
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            Anyone Plz any advice
              • 31071
              R8&D3 are good,
              power resistor is good
              i cant see what's printed on R11
              "y2" is in my data as a 13v zener diode - which looks wrong
              • madan1
                • Nov 2016
                • 682
                • Bulgaria
                Get a new power supply. Those modules are dirt cheap on aliexpress or ebay.
                • garrymc123
                  • Apr 2010
                  • 336
                  • United Kingdom
                  Thanks can you send me a link to them please and i see if i can find one that will fit inside the light
                  Was hoping to fix it tho and to learn how to do things like this
                  Cheers
                  • madan1
                    • Nov 2016
                    • 682
                    • Bulgaria
                    What are the output specs?
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
