Re: Corsair GS800 Power Supply Problem
Sleep helps.
Power supply tester is applying a 329mah load to 5v+ rail. 15 ohm resistance I have been chasing is in the power supply tester itself. UGH again! Without PSU tester in place and 12v applied to daughter card w/bench power supply current is 137mah. This sound right?
Applied 12v to daughter board with a thermocouple attached. U1 temp rose from 77f to 96f and settled there in about in about one minute-draw at 307mah. Removed PSU tested and current dropped to 136mah but temp stayed at 99-100f.
Current state in this Corsair PSU SAGA is 5v stdb that does not power on. That is serious progress from where this thing started.
Sleep helps.
