Need Help on SMPS Power Supply Load Testing Failure..:(
  • dennis_elx33
    • May 2019
    • 32
    • Malaysia
    Hi Guys!
    I am a beginner in electronics repair. This time I tried to repair an SMPS power supply with 4 outputs 24VDC (10A), 5VDC(10A), 12VDC (4A) and 12VDC (4A) due to intermittent power on/off. After series of checking, I found some few capacitors with high ESR and replaced those with good spares. Now the power is stable and output voltages are all good. But whenever I load test atleast 2A, the voltage drop on outputs 5VDC, 12VDC, 12VDC respectively. The original 5VDC when there is a 2A load becomes 1.3VDC, and the 2 outputs with 12VDC becomes 5.4VDC. However, when I load 8A on 24VDC it drops to 23.6VDC and I think it has no issue. I already have replaced the 2 PWM UC3854BN and all the electrolytic capacitors but still failing. I have removed and measured all the resistors but cannot find abnormal reading. I also have checked the MOSFETs and proactively replaced it with same exact part number. I also have changed the 3-pin voltage reference ICs TL431C but with same result. The problem is I don't have any schematic diagram. Any idea on this is highly appreciated.
    PSU Model: PFC375-4200
    • Jul 2011
    • 6059
    Re: Need Help on SMPS Power Supply Load Testing Failure..
    Please post a few pictures front and back of this switching power supply so we can see what you are dealing with
    Please make sure that your pictures are very clear and sharp and in focus so the part numbers of devices can be read
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      When all else fails, replace everything including the optoisolator
      • AJ847.63e
        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
        by AJ847.63e
        Hi Folks,
        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
        05-06-2025, 10:37 PM
      • abhishekkumar1902
        Huntkey HK340-72FP SMPS shut on load above 2 amps
        by abhishekkumar1902
        I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
        I have checked the following:
        1. All output caps are OK, and all output rails read correct voltages at no load
        2. All output diodes are OK
        3. NTC is ok
        4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
        5. No short in main switching MOSFET
        6. All other components...
        12-18-2022, 09:52 AM
      • learnmore
        Testing LED TV Mainboard without SMPS
        by learnmore
        Hello Community,
        I've been looking at the TV160 mainboard tester for LED/LCD screens and wondered if there was a device for providing the required voltage to test a TV mainboard using the TV160 without the SMPS.
        Doing so may allow me to work on the main board away for the larger unit with the panel and SMPS
        Thanks,
        LL
        03-12-2024, 01:05 PM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • dicky96
        Load Testing Audio PA Amplifiers
        by dicky96
        Hi, one of my customers who rents out equipment for events and carnivals asked me to make a passive dummy load so the can test amplifiers under full power without causing noise problems to other nearby businesses.
        He wants 8 ohm and 4 ohm loads, originally he asked for 8 ohm 500w resistors, and I said we could use two resistors in parallel for 4 ohm 1000W
        Then I found these cheap power resistors on Alibaba. It says they are 'Braking' resistors, but they seem to be suitably rated for my purpose
        https://www.alibaba.com/product-deta...w-Resistor-8-o...
        01-12-2021, 10:31 AM
