Re: HEC Orion HP585D
Weird, I come back after a while and see one of my old threads resurrected the same day.
HEC Orion HP585D
Originally posted by eagleeyez View PostPlease anyone has the schematic diagram?
That said...
Originally posted by eagleeyez View PostI need to know the value of C31 and retrace what may be the cause of it's explosion so I can replace all of them.
Originally posted by eagleeyez View PostI want to know also if this PSU is worth my time repairing it? since I did found it trashed by someone and I've seen that it's 600W which I consider a good PSU
But for your information, this power supply is only capable of about 350 Watts, as Stefan noted, and 16 Amps on the 12V rail, not 600 Watts as advertised. So with that said, the PSU should be good enough to run a PC with a Core 2 Duo / Core i3 / Core i5 CPU and a mid-level video card (something like a Radeon HD 3650/4650/5670... etc. or the GeForce equivalent).Last edited by momaka; 09-19-2015, 04:29 AM.
Please anyone has the schematic diagram? I need to know the value of C31 and retrace what may be the cause of it's explosion so I can replace all of them.
I want to know also if this PSU is worth my time repairing it? since I did found it trashed by someone and I've seen that it's 600W which I consider a good PSU but I am not expert in this, just trying to save some hardwar from trash yard and putting a second life to it.
Thank youLast edited by eagleeyez; 09-18-2015, 08:49 PM.
I have recently acquired a Thermaltake TR2-430W. PC board looks just like yours - except it already had the line filtering parts. GBU806 bridge diode. I think Bestec is better built.
and how are you allowed to sell a fake logo? was this dated before there were laws?
so any how to's? - would love to spend little money and upgrade my PSU - I have a little DC/AC knowledge. Witha quick walkthrough I would be a PRO
That Teapo is a common failure. Every one I've seen in that position across various PSU makes and models is bulged. Some less than 2 years old.
Re: Polys in output - You'd need to double them up to get the oomph! provided by the higher capacitance of the regular lytics. Yes, ripple would be super low, but as soon as something drew current for an instant, the voltage(s) would sag to far. It's not something you may readily see with a meter, but on a scope you'd see the blip.
Think of it as trying to start the car with lawn tractor battery vs. a truck battery. Both may do the job, but the lights won't dim as much with the truck battery.
Toast
Opps, missed that IC behind the caps. 8pin ST UC3843B.
Don't know which cap is the 5vsb cap. There are many 50v 10uf and 4.7uf, and one teapo 6.3v, 2200uf cap next to the 5vsb transformer.
Thanks for the info.
I noticed there is one more IC behind the input caps. Probably a UC3842/UC3843 or some other similar variant. Unless this IC is something else, then it's very likely that this power supply uses a 2-transistor 5vsb design (The Welltrend wt751002 is similar to the TPS5310, and nither of those offer 5vsb monitoring/protection). The 3 4-pin ICs in the transformer area are optocouplers, like Toasty said. If there was 5vsb protection, there should have been one more optocoupler and maybe another IC somewhere (like the Bestec ATX-250 12Z).
With that said, it's probably a good idea to keep an eye out on this power supply (and definitely change the 50v, 10/22/47uF 5vsb cap if you find it).Last edited by momaka; 10-17-2009, 12:32 PM.
(4 pin) They're the opto's.
The Weltrend is a supervisor chip. (The iMac supplies use the 7512)
Toast
Well, not counting the three little 4 pin IC's near the 5vsb transformer, there is 1 8pin welltrend wt751002 930 j48a1g
The three little 4 pin IC's near the transformers, if they are even IC's, are all cosmo 1010 817 J18 C's.
I was thinking of getting some polymers for the secondary caps, as the highest uf 10mm 16v electrolytic cap I could find are all 1500. I was thinking of getting some nichicon 16v, 10mm, 820uf caps, but I don't think the ultra low esr of them would help any.
Originally posted by 370forlifeSome tests of the HP585D have shown that the OCP trip point is just above 430W.
Not surprising, this is the same unit used in those thermaltake XP550 430W psu's without the transient filter, which can do 430W in spec.
Here's the two reviews if anyone is interested
http://www.hardwaresecrets.com/article/332
http://www.xbitlabs.com/articles/coo...oundup_18.html
As far as regulation, 3.3v rail is derived from the same transformer pins as the 5v rail. The reason you see only one coil is that the 3.3v rail is regulated with a voltage regulator rather than a saturation coil.
Now I have a curiousity about this power supply, though - how many ICs are there on the PCB, 2 or 3 (ID numbers would also help)? I'm wondering because I have the Thermaltake XP550-NP 430W version of this power supply, and I want to know how the 5vsb rails generated and regulated - wheather it's a 2-transistor desing or something else. Mine's still under warranty, so I don't want to open it just yet.
By the way, 370forlife, you did some great work on this power supply!
Should be pretty reliable now. I know that mine has stable voltage regulation (12v is a little high at 12.36v, but all other rails are nearly perfect).
Doesn't look like a bad power supply now that you've added better components to it.
Well done 370forlife!
That is compucase's ul number. Fake UL logo is correct, same with the FCC logo.
Yup, the X caps are X2, Y caps are safety series X1 Y1.
the fcc logo and ul are forged.
no way it will pass either spec.well maybe now that you added a bunch of parts.
did you use x and y rated caps ?
Originally posted by kc8aduit will still go BANG! if loaded to the label ratings.probably ok for most home pc use though.
the mfr counts on the fact that very few pc's will need that 585w!
Really not that bad of a unit. No 2 transistor 5vsb, medium grade caps from the start, wouldn't be so bad if it wasn't for two things. One being advertised as Intel 2.01, while the PCB is dated for 08/07/2008 and marked as Intel 1.2, and the other is the super group regulation, as well as the transient filter.
Single forward primary switcher is a more efficient design, but not really viable for higher wattage units, although the primary switcher in this one is capable of about 450W. Secondary heatsink is thicker than most delta units I have used.
that is one POS PSU!
free, but shitty as hell. glad you could fix it.
