Help with car battery charger HT7715
  • R_J
    • 9551
    Re: Help with car battery charger HT7715
    That is why I asked for a voltage check across the cap in post #10, If there is no voltage across that cap there is no secondary voltage so the click can not come from the relay.
    Almost all pwm ic's will pulse the primary circuit at least once (click) this pulse should produce enough voltage across C24 to raise the vcc above the start threshold of the ic.
    The Dc voltage should be measured across the outside leads of the bridge rectifier (+ and -) or just measure the voltage across the large capacitor in the primary. It should be around 325VDC
      It is 12vdc relay coil (OKS2C-S15DC12V).
      See attachment as to what I believe how the relay is driven.
      I would expect the clicking to be continuous if the power supply is stuck in start/stop loop if it is in protection mode or due to bad startup/running cap.
      BTW, the click sound of the relay will be so much more metallic sound than the clicking of the SMPS circuit.
      • ex250
        • Jun 2019
        • 97
        • Spain
        Changed the cap C24 with a new one, same behabior than before.
        • R_J
          • 9551
          Check the voltage on C24, You must use the hot side ground, (- of bridge or - of primary cap). If you have o volts, (with power disconnected) check the resistor marked 104, and the resistor on the top side connected to it, also check the large 3 watt resistor next to the heatsink beside the fet.
          If you can provide the numbers of the two 8 pin ic's that would help, they may be hard to read due to the coating
          In the past did this charger come on when only pluged into the mains? or did it require the 12 volt battery be connected first?
          • ex250
            • Jun 2019
            • 97
            • Spain
            On C24 0v readings, 104 reads variable values 102K and 95K inverting poles, the top side resistor is 100K and the bigger 3w one I need to desolder it, the reading is 0,001K
            The charguer not needed to teh connected to the battery to power on, but without one conected only showed one icon on the display.
            • R_J
              • 9551
              The large 3 watt should read as a short, Try changing the resistance reading to the lowest scale (usually 200Ω) but I guess 0,001k means it is ok. You can also check that small glass diode next to the 2R0 resistor, if it is ok, It could be that the ic is bad, because you should have some startup voltage on C24
              Any chance you can read the ic niumbers?
              You should have around 325VDC on the large capacitor, That 100k resistor on the top side is connected to the positive of that main filter cap and supplies voltage to the smd resistor marked 104, This charges C24 to around 10~20vdc. this is the initial VCC voltage supply for the 8 pin ic. once the circuit is working the VCC voltage is maintained via the transformer, that small glass diode and the 2R0 resistor
              • ex250
                • Jun 2019
                • 97
                • Spain
                #27
                I am not able to remove the varnish, i tried with solvent and turpentine and nothing...seems "extra tough", I don't know any other way to remove it without erasing and deleting the IC chip letters.
                The 325VDC are present, seems that the fail is at the IC, the diode is OK reading to one side and nothing on reverse, 2R0 seems good at 2,1 Ohms.
                I 'm thinking to use some paint stripper liquid, let's see if it doesn't spoil anything too much...
                Thanks for the follow up and help of this!
                • redwire
                  • 3910
                  I use needle probes or dentist's picks to poke through the coating/varnish.
                  • maher471
                    • Tunisia
                    #29
                    Hi, here is the schematic I made by reverse engineering for the HT7715 charger, I hope it can help
Name:	CD15 - battery charger carrefour.jpg
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      #30
                      might be long gone .it was 4 years ago
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                        Narrow VDC applications where the system power source is
                        either the battery pack or the regulated output of the charger.
                        This makes the max voltage to the system equal to the max
                        battery voltage instead of the max adapter voltage. Operating
                        at lower system voltage can improve...
                        11-05-2024, 04:43 PM
                      • flat-earther
                        how to prevent a connected charger from draining battery when not charging?
                        by flat-earther
                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                        So the battery is backfeeding the charger and being drained.
                        How can I prevent...
                        08-07-2025, 01:04 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                        Bauer tool battery pack charging with a HERCULES charger modification
                        by sam_sam_sam
                        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                        05-06-2023, 12:17 PM
