Old AT power supply (model: API-3186S) troubleshooring/testing
  • Vejay
    • Greece
    So... I tore it off a PowerMac 4400/200 that I'm trying to repair. Currently I'm at the stage of eliminating factors that would keep the thing from powering on (RAM is fine, HDD and peripherals are fine, no obvious damage on motherboard).
    Problem is, I know precisely nothing about AT-era PSUs and this particular one is an oddball at that. It's got the two auxiliary power connectors that according to schematics online have three +3.3V power lines (and ground obviously) along with a connector that goes to a "SOFT PWR" connector on the motherboard so apparently it's not like the other ones that power on as soon as they're plugged in.
    I took some pictures of the back of the board... I put them in an imgur album. I can attach them here if imgur albums are a problem.
    The current problem with the power supply, is that it makes a buzzing sound when I plug it in. I'm not an expert, but another AT PSU that I've had was silent (aside from the fan). I also don't know how to make this particular PSU power on on its own so I can test its outputs.
    If it turns out that the thing is completely blown, can I modify an ATX PSU to give out the same kind of outputs? I think the -5VDC and the multiple +3.3VDC are going to be a bit of an issue... although I guess I could use the +3.3VDC from the MOLEX connectors...?
    • Jul 2011
    • 6059
    Re: Old AT power supply (model: API-3186S) troubleshooring/testing
    When you take pictures of a power supply board or anything that you are trying to repair you need to take pictures of both side of the boards
    Yes you need to post the pictures here because most people are not going to go to another website to view your pictures
    Do you know how to use a volt meter
    Do you understand the concept of troubleshooting
    • Vejay
      • Greece
      I took some more pictures of the main PSU board and a little daughterboard it has. I put them in another imgur album.
      I know how troubleshooting on ATX PSUs is supposed to work (connect a green wire to any of the black wires, check the various outputs...). But this isn't and ATX power supply. And as I've said on my post, the general consensus is that AT power supplies are supposed to turn on when you plug them in, but this doesn't - in fact there's a "SOFT PWR" plug in the motherboard itself.
      I can't attach pictures here, however. Whenever I try, I just get a message reading "Your submission could not be processed because the token has expired. Please push the back button and reload the previous window."
      • will62
        • 229
        • usa
        See the link below. It is a translation from a Japanese site, but easy enough to follow.
        https://translate.google.com/transla...n%2Findex.html
