Neon light transformer identification
  • badcKulture
    • Mar 2018
    • 22
    • France
    I have this transformer and i would like to know what is the maximum neon light power (in watts) i can use with (cause there is no "watt information" written on) ? I have a 22 watts neon light, will it explode ?
    I hope my question is in the right section of the forum.
    And sorry for my little english !
    Thanks for any help !
    Re: Neon light transformer identification
    Where did you get this from?
    It looks like magnetic ballast...
    Tw 120 = Max working temperature of the winding within the ballast, 120c
    Delta T of 55 = Temeprature rise of 55c.
    https://www.giangrandi.ch/electronic...enttubes.shtml
    https://www.electrical-installation....orescent_lamps
    What kind of NEON LIGHTS are you working with? They need high Voltage.
      • 31025
      that's just a 20w flourescent lamp balast - not a HV stepup.
      you can even see the diagram of the tube and starter on it!
      • badcKulture
        • Mar 2018
        • 22
        • France
        Thanks for your answers guys !
        It comes from a neon sign from the 80's or 90's and yes i think this is a ferromagnetic ballast (i said transformer because i didn't know if ballast was a term used in english too).
        So it is a 20W maximum ballast ? So my 22W fluorescent lamp will be destroy if i connect it to this ballast ? ( https://www.amazon.fr/Osram-Lumilux-...s%2C165&sr=8-1 )
          It can handle up to 20W, not putting out 20W, so if you overload it then it will over heat ballast.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            N...no. Its a choke, is all magnetic ballasts are. You can connect them directly across the line and they will sit there and pull 20w happily.
            Once a tube is struck, its akin to a short circuit. They actually display negative resistance, in which, an increase in current through the device causes a drop in voltage across it.
            Magnetic ballasts LIMIT the current through what is essentially a short circuit.
            Now, with that said, under running a tube will result in a HIGHER resistance through the tube and less current to sustain the arc, leaving the tube prone to "ringing" where you will see the arc swirling in the tube, hard starting, lower light output, and the arc "dying" shortly after being established when cold.
            Follow the white rabbit.
              I know that it is just an inductor and it is used to limit the AC current through the FL.
              The ballast is basically connected in series with the FL and it is rated to match the required lamps. Isn't that why there is Voltage, current, ballast factor rating on the ballast and since once the lamp starts conducting, it is not really shorted circuit is it? Am I missing something as to why the ballast will burn out if I do not properly match the lamp and the ballast rating if the ballast can truly be connected directly across the line? May be the core will saturated if it is connected across the line.
              https://unvlt.com/literature/trouble...erheating.html
              https://uk.rs-online.com/web/general...ballasts-guide
              http://www.lutron.com/en-US/Service-...Selection.aspx
                • 31025
                the point is, it wont run a "neon" tube.
                that takes a stepup transformer - usually 3-5Kv
                • badcKulture
                  • Mar 2018
                  • 22
                  • France
                  Here a photo of the full installation (where you can see the starter).
                  Yes Stj, my mistake, it is not a "neon" tube but a fluorescent tube (i will change my title).
                  So first, will this new generation fluorescent tube ( https://www.amazon.fr/Osram-Lumilux-...80&sr=8-1&th=1 ) will work on an old ferromagnetic ballast ? Or it requieres a electronic ballast ?
                  If yes, will my 20W ferromagnetic ballast be compatible with this 22W fluorescent tube without risk of damage ?
                  Sorry if i ask quite the same question but Budm said there is a risk of ballast overheat and then Goontron said this "the arc "dying" shortly after being established when cold" which i don't really understand and if it means a risk of damage of the tube ?
                  In any case, thanks because i have learn several things but i guess i still need a "Yes or No" of the noob i am :p
                  • badcKulture
                    • Mar 2018
                    • 22
                    • France
                    Seems like i can't edit the title sadly :/
                      • Jul 2011
                      • 6039
                      The last picture that you posted is a old stile ballast I find that this type last for a very long time if change the tubes when first start going bad or if start has trouble lighting the tube
                      This type of ballast last a very long time
                        OK, so you are using Fl not NEON, the 22W FL should be find (the current rating on the ballast is high enough to handle 22W).
                        As suggested by Sam, they last a long time as long as you change the tube when it start going bad, I.E. it starts showing blackened ends.
                          • 31025
                          that will work - dont forget the starter needs to be o.k. for the wattage.
                          (and should be replaced when you change the tube)
                          • badcKulture
                            • Mar 2018
                            • 22
                            • France
                            It worked !
                            The new tube works like a charm without flickering, so sould i despite everything replace it ?
                            Thanks all for your help ! One more victory of the second hand !
                              • Jul 2011
                              • 6039
                              Just a recommendation
                              If you replace the tube then you should also replace the starter
                              Or you might encounter a bad tube again shortly
                                Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                by sam_sam_sam
                                I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                I also have back when Light of America had these light bulbs available for yard lights
                                The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                While the Lithonia lighting fixture has all most certain bulb failure
                                So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                I have only had this light fixture for not more than a year if it...
                                07-02-2023, 03:45 PM
                                LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-07-2024, 03:40 AM
                                LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 09:10 PM
                                09-06-2024, 08:40 PM
                              • serious_electron
                                Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                by serious_electron
                                Hello Everyone!
                                I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                06-28-2025, 02:57 PM
