An office computer kept resetting and booting up by itself, and I, being the unceremonial office troubleshooter, was called in to fix it. Shucks, it all sounds like a bad PSU, so I yanked it off and sure enough, there were 4 bloated capacitors in that generic contraption. I replaced them all but noticed a large 5watt 10 ohm resistor at the 5 volt output rail. It's a bleeder resistor to ground. This is the first time I've seen one connected as such. It seems to me it serves no real purpose except drain half an ampere from the rail, and that's a good 2.5 watts of wasted power. I never connect any of my PSUs to the mains without being loaded and connected to a motherboard. So I'm inclined to remove it and get a cooler PSU too. On the other hand, am I missing something?
Why a bleeder resistor at the 5v rail?
by Nagy DanielHi, I'm Daniel, and I'm new to the world of repairing motherboards.
I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
So, I generated a table with AI so I can... -
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
Well, my decice specs are the following:
Model: Acer Nitro 5 AN517-54-55T5
CPU: Intel Core i5-11400H
GPU: NVIDIA GeForce GTX 1650
Motherboard: GH51G LA-L181P Rev:1c
The symptom:
When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...05-26-2025, 10:49 AM -
I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors... -
by artvandalaiThe resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y3 Photos
- Loading...
