Fsp300-60btv
  • golemmaster
    • Jul 2009
    • 100
    Fsp300-60btv
    Ran across this FSP300-60BTV. Won't always power on when connected to a mainboard (D845EBT). Replaced it and computer works fine with another PS.
    Opened the FSP and saw this (see pics). Looks like a big resistor with heat shrink on it. With age or heat or both, the tubing split and took the enamel with it. I don't know if this is the PSs problem or if it is just cosmetic. The resistor measures 7.5 Ohms. Since the enamel is gone I don't know what the value is supposed to be.
    What do you think?
    Caps look fine, BTW.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Fsp300-60btv
    See what it's connected to. Most likely it's a loading resistor for one of the rails.
    The resistor next to the gray (PG) wire seems to have been running hot as well. Probably another load resistor again. Make sure it's not touching the case when it's closed as the enamel seems a bit chipped on that one too.
    Perhaps if they really are load resistors, maybe they're providing some type of quick minimum load for the PSU to start. But again, see what they're connected to.
    Also, have you checked the caps? Check the 5vsb voltage too.
    • yanz
      • Nov 2004
      • 910
      Re: Fsp300-60btv
      maybe that just a load resistor for +5V rail. on some 300-400W FSP, i just remove them. they can be destructive to the component nearside it.
      like momaka said, recheck again. and be aware of minimum load issue if you remove it.
      see my thread :
      https://www.badcaps.net/forum/showthread.php?t=7202
      days are so short when you actually do something..
      • golemmaster
        • Jul 2009
        • 100
        Re: Fsp300-60btv
        Just read through your thread.
        Thanks bunches. Good info.
        I'll poke around a bit more.
        Since the power-on problem is intermittent, it's difficult to diagnose without more tools (and knowledge).
        • golemmaster
          • Jul 2009
          • 100
          Re: Fsp300-60btv
          Without the big resistor, voltages measure:
          12@10.9-11.0, 5@5.25, 3.3@3.47
          12 is very low, others a little high
          without the smaller resistor, won't power on. even with a load on 3.3 or 5 externally.
          WITH both resistors, power on fine, voltages better. 11.65, 5.01, 3.46
          Both get darned hot. might need to relocate them away from other parts and wires, maybe onto a heatsink.
          +5vsb runs at 3.46.
          The dummy load I have only loads +5 and +12.
          I think all my messing with it, desolder/resolder, may have taken care of the original problem. There was a questionable joint on the smaller resistor. Now I wonder about that 5vsb.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Re: Fsp300-60btv
            5vsb is probably whats causing the intermittent failures. May need to poke around there and see whats up.
            • golemmaster
              • Jul 2009
              • 100
              Re: Fsp300-60btv
              I also have a SPI FSP300-60GT whose 12v is at 11. Everything else is good. 5vsb is at 5. Caps look good.
              I guess I need to take these things apart and check parts out of circuit.
              I also need more spare time..... These are things I'm trying to learn... I value Your help.
              • golemmaster
                • Jul 2009
                • 100
                Re: Fsp300-60btv
                The 60GT also has a very low -12 @-10.3
                • golemmaster
                  • Jul 2009
                  • 100
                  Re: Fsp300-60btv
                  I don't get it..... I haven't done anything to the 60GT but run it and probe with my DMM. now 5 is @ 5.52 as well. Jeez!....
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: Fsp300-60btv
                    Put more load on it when you check voltages.
                    If there is no load there is no current to regulate so it won't and the voltage will be off.
                    Try two hard drives on 4-pin drive connectors and maybe a fan.
                    With load 12v should go up and 5v down.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • golemmaster
                      • Jul 2009
                      • 100
                      Re: Fsp300-60btv
                      The dummy load is an old antec load with PG switch. It's got a couple of big resistors on +5 and +12.
                      Here's a pic...
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        Re: Fsp300-60btv
                        We use that same psu tester in my computer tech class. It only puts like a 10W load on each rail. Not enough.
                        • golemmaster
                          • Jul 2009
                          • 100
                          Re: Fsp300-60btv
                          40 Ohm on +12, 10 Ohm on +5.
                          OK.
                          The answer is always... MORE POWER!
                          This thing has always been sufficient in the past.... why would it not be now?
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            Re: Fsp300-60btv
                            Its really only designed to just be enough to get past any minimum load requirements on power supplies, which are typically 1A on each rail, and really only on cheaper, older psu's.
                            These older psu's are not designed to really work under anything less than about 50W.
                            • golemmaster
                              • Jul 2009
                              • 100
                              Re: Fsp300-60btv
                              On the 60GT, I plugged up 4 HDs in addition to the dummy. Voltages are pretty normal. 11.9, 5.1, 3.4, -11.8, -5, 5.02vsb
                              Thanks.
                              I'm going to explore modifying that switch with more load and on other rails.
                              Now back to the 3.45vsb on the 60BTV. Hmmm.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Re: Fsp300-60btv
                                See!!
                                - Dr Seuss
                                • golemmaster
                                  • Jul 2009
                                  • 100
                                  Re: Fsp300-60btv
                                  Alrighty, then! I moved and mounted those resistors to a heatsink where the fan can cool them and are away from wires and things. (see pic)
                                  I poked around some more... following the 5vsb traces... replaced a cap that looked fine but failed ESR. <YEC> 470uF 16v SH105C
                                  5vsb is now at 5.12.
                                  I'm a little concerned that 3.3 is at 3.51 but I don't have a load on that rail.
                                  I don't need this PS. I was using it for experience. And now I have it too.
                                  This may be trivial to you guys but it's another valuable lesson and gives me a needed feel-good-satisfaction in an otherwise frustrating work day.
                                  Thanks for listening and for the advice.
                                  • meicol
                                    • Apr 2010
                                    Re: Fsp300-60btv
                                    Hello .. was I reading everything and ultimately R3 which was his value? It was his purely aesthetic aspect or I replace it and for which.
                                    I have the same problem this totally without his coverage like that that I do not see anything of what they were his values.
                                    I need help !!!!
                                    thank you
                                    • jinu_j
                                      by jinu_j
                                      Hi
                                      05-03-2025, 10:51 PM
                                    • mikey5791
                                      Need help to replace burned resistor in 350w atx psu
                                      by mikey5791
                                      Hi to all forum members,
                                      Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                      The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                      Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                      Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                      12-26-2024, 04:55 AM
                                    • artvandalai
                                      What resistor ohm will work better to repair this waterpik?
                                      by artvandalai
                                      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                      01-05-2025, 04:10 PM
                                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-12-2024, 02:20 PM
                                      HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                      09-06-2024, 10:56 AM
