iMac G5 PSU - no power
  • seanc
    • Nov 2008
    • 1319
    #61
    Re: iMac G5 PSU - no power
    Oh sorry Toasty!
    DPS-180SB A REV:01
    Number: 2950144804
    • Toasty
      • Jul 2007
      • 4171
      #62
      Okay. I have the identical unit. Let me know when you are ready to go back at this.
      The only difference will be I won't get to 220v on mains. Best I can get is ~160 off the transformer. After we are sure the HOT side is not the problem, we should be able to match voltages and readings.
      Toast
      veritas odium parit
      • seanc
        • Nov 2008
        • 1319
        #63
        That's great Toasty.
        I'm in New Zealand right now visiting family and won't be back for a month or so.
        • Toasty
          • Jul 2007
          • 4171
          #64
          Enjoy!
          Chat me up when you get back.
          veritas odium parit
          • xxmiguelxx
            • Jan 2014
            • Spain
            #65
            Hello, recently, I have repaired, an imac G5 power supply (DPS-180SB A), with the symptoms of no standby, totally dead. The power supply, did not have any swollen capacitors on the secondary.
            The replaced components have been:
            Stand by Ic TNY267PN , a 4.7 Ohms resitor (near this ic), and a 400v 3.3Uf (near this ic an under the heatsink, and covered whith heat shrink), this capacitor have been leaking underside and very hard to see.
            First time i have replaced the tny267pn did not work, (a fake ic from ebay), but i have order 10 of them fom ali, and work and a very first try.
            I recomend to put a socket from this ic, and check for shorts on the two diodes near the ic.
            I hope this helps, thanks for this forum.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • chopduel
              Bad mains power causing TV malfunctions?
              by chopduel
              I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
              Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
              • TV would randomly turn off then back on.
              • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
              • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
              12-29-2024, 03:20 AM
              03-31-2024, 02:12 PM
