Re: Hipro D2537F3H - Teapo output capacitor replacemnt
It's there so that if you run the PSU with no load at all on the 12V rail and some (but not full) load on the 5V rail, the PSU won't loose regulation.
So it does have a purpose indeed.
However, typically having just one fan in the PC will put enough minimum load on there to keep the 12V rail happy. Thus, in most cases, the minimum load resistor will not be needed.
I myself don't like to completely remove them, and usually replace them with whatever resistors I have on hand that will work in the circuit. For 12V rail, typically anywhere from 270 to 1000 Ohms is good enough as a minimum load. But removing them completely, at least from my personal experiments and that of a few others I've seen on BCN, usually will NOT cause an issue, either. Nevertheless, I bought a pack of 100 SMD 1-KOhm 1/5W resistors off of Digikey for something like a $1, so I used these on the 12V rail of PSUs quite a bit (typically 2-4 in parallel for a total resistance of 500 to 250 Ohms as a load.)
No need to worry about those then.
Again, tyically I worry only if the 5V rail is showing 6 to 30-ish Ohms resistance (suggesting less than a 47-Ohm resistor is used), and less than 10 Ohms on the 3.3V rail.
Yup, that's why I asked for the extra pictures.
Looking at it, it might be an RC snubber network on the 12V rail (or some other rail). Can't quite tell, but that one I probably wouldn't replace with any other random value and only use the same resistance. See what the non-ground side of that resistor connects to (use your multimeter on lowest resistance setting to find out.) And also see what the other side of the ceramic cap (that is not connected to the resistor) goes to.
That aside, if the resistor is not showing open-circuit, you don't have to replace it. Just make sure it is not shorting to something metal, as the material/layers under the insulating coating are usually conductive.
Or if you want piece of mind, you can replace it. But in that case, since the coating appears tripped, then maybe use a higher power resistor, as that will run cooler and will be less likely to "blister" over time.
