Dps 800 fan not working and variable voltage
  • lordsixel
    • Oct 2019
    • 8
    • México
    Hey guys. Well I'm having a problem with my dps800. It's about a capacitor I think. You are the experts. I was trying to reach 14.3v and it turned off... After that, the fan looks like try to work but it just make a little move.
    The voltage change so fast as you can see in the video.
    I really appreciate you help guys. You are awesome.
    https://youtu.be/TON-OkevRDg
  • lordsixel
    • Oct 2019
    • 8
    • México
    Re: Dps 800 fan not working and variable voltage
    No one? :/ I think I have to pay someone to repair it
      • 31304
      well you could start with a full explanation of what you did,
      because i'll tell you now that most of the car forums like MHautos are full of assholes giving - or more often selling bad advice.
      • lordsixel
        • Oct 2019
        • 8
        • México
        I did same of this video
        https://youtu.be/9--g63ew9HU
        Problem came after I closed it and tested again. Turned off and it didn't worked again
        • lordsixel
          • Oct 2019
          • 8
          • México
          No one? :/ Or some who can tell me which one is the startup capacitors
            • 31304
            for fucks sake, give people time - you arent paying for 24hour service!!
            your also not in my timezone.
            so i watched about 30% of that shit and it's the same old crap.
            you DONT ajust the voltage by bodging the feedback with resistors and you dont rip protection chips off.
            i'm not surprised it wont run - and it's not a cap problem.
            undo what you did and see if you get 12v still.
            • lordsixel
              • Oct 2019
              • 8
              • México
              If you don't want to help. Don't comment. Thanks
                • 31304
                it worked, you did something - now it doesnt.
                isnt it logical to undo what you did to see if it works still?
                let me give you a hint, that chip does a lot more than detect over-voltage.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • Green Probe
                  Recapping a Denon AVR X6400h SMPS
                  by Green Probe
                  (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                  Disclaimer: I'm an amateur hobbyist and will get things wrong.
                  Always use caution when working around mains power and high voltage capacitors!
                  Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                  SYMPTOMS:
                  -No display...
                  07-18-2025, 03:36 PM
                • Fernon@Repair
                  Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                  by Fernon@Repair
                  i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                  VCCIO voltage ok
                  VCCSA Voltage OK
                  VCCPLL Voltage OK
                  Ram Voltage ok
                  RamVTT OK
                  VPP 2.5 OK
                  But No Core Voltage
                  and i want to this vrm ic datasheet or pinout (ISL69269)
                  anyone have this ic pinout voltages?...
                  06-25-2025, 07:19 AM
                • Mani .H Soltani
                  Hello guys/gals i really need a working BIOS for this Asus E203NA Rev3.0 laptop please help :)
                  by Mani .H Soltani
                  Now then SMD before we start our usual Cat & Mouse game the Board im requesting a BIOS for is different then the existing thread and the thread isnt about a no POST asus its about adding Serial number to working Asus so please for the love of GOD don't merge/delete me this time.
                  So my problem is that it don't work nothing i tried a dump it powered on once and ... no display no POST and with OG dump its dead in the waters so can anyone please help with this file ?
                  Laptop is a Asus Notebook L203NA/DS04
                  With a E203NA REV3.0 MB
                  S/N L8NOCX00240534B
                  No Service...
                  06-08-2024, 10:47 AM
                • electron_jj
                  Panasonic TH-L42D25A checking the PSU output voltage
                  by electron_jj
                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                  08-29-2021, 08:13 AM
