Keep the PSU fan spinning after you turn the computer off
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Keep the PSU fan spinning after you turn the computer off
    to cool the power supply when in standby, those two transistor circuits like to make some heat when not in use.
    • everell
      • Jan 2009
      • 1514
      When the computer is plugged in, but turned off, the 5vsb in the power supply is still running. This produces heat in the power supply, even though the computer is turned off. End result is that the heat cooks the capacitors in the power supply while the computer is off.
      How much heat depends on the power supply circuit design, parts layout inside the power supply, and available air flow inside the computer case. The heat problem is worse for some power supplies than others. For instance, the Bestec ATX-250 12E has a reputation for killing mother boards. The problem is due to 5vsb circuit heat failure.
      The circuit in this thread uses only one fan for cooling whether power is on or off. Earlier I had demonstrated a modification using one fan when power is on and another fan when power is off. Attached photo is a Bestec ATX-250 12E with two fans. This power supply will no longer be a mother board killer. It has a modified 5vsb circuit and a separate fan for cooling the 5vsb.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • Rulycat
        • Apr 2010
        • 724
        • United Kingdom
        Thanks for the explanation. Are good brands such as Antecs affected by this?
        EDIT: More specifically the TruePower Trio (seasonic)
        • Wizard
          • Mar 2008
          • 2296
          To vent out the heated air from slowly cooling down warm parts, this also serves to help you to cool room off quickly for the night when PC is turned off so it is not a radiator for 20-30 minutes without the cooling help.
          This circuit cut out fan automatically after a certain time.
          Cheers, Wizard
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Probably not, depends on the age of the power supply and what wattage.
            • etnietering
              • Apr 2009
              • 379
              They're all right. Seasonics are good, so they probably don't need something like this, but I believe it would be beneficial to any power supply. When the power supply is on, it's dumping out anywhere between 40W and several hundred Watts of waste heat, mostly through the heatsinks. When you turn the computer off, the airflow over the heatsinks (from the fan) stops, but they're still very hot. Since there's no airflow anymore, the heat stored in the heatsinks can radiate out and bake all the other components, perhaps even making them hotter than they were when the computer was running. Also, the 5v standby circuit is still running, generating heat of it's own.
              The power supply I put my circuit into was an Antec, but it's not because I particularly thought it needed it, it was just easily accessible, and the one I picked.
              • riotpack
                • Jul 2008
                • 27
                #27
                Think of this as no more than a question, but when the computer is running everything settles down to a standard operating temperature (which may change depending on computer loading) usually 35 degrees Celsius - 45 degrees Celsius cabinet temperature.
                When you shutdown the computer all the components will contract because they are cooling down and this continuous thermal stress eventually kills components.
                Now if you are feeding cool air over the hot components once they are no longer dissipating heat to cool them, then aren't you in fact exposing them to more thermal stress and thereby reducing their life?
                Thats not a Fuhjyyu I used in your antec PSU its a HITACHI!! rofl lol lmao funni gui!
                  • 30941
                  keeps the standby circuits cool.
                  • riotpack
                    • Jul 2008
                    • 27
                    #29
                    But its only on for a couple of minutes once the computer is turned off isn't it (the fan in this design) ? So that would result in the standby circuits (Estimated around 5 watts) going from hot to cold and back to warm when the fan finally turns off?
                    "R2 and C5 control the length of time the fan runs after you power down - with these values it runs between 2 and 2.5 minutes. I know there are probably better, more efficient ways to do this, but I used the parts I have on hand. I know that PSU fans are 12 volt, and some won't run on only 5 volts, but this runs then at 12 volts (minus the diode voltage drop) until the PSU turns off, and then the 5 volts kicks in. Withe the two fans I tested this on (one 80mm and one 120mm) the 5 was enough to keep them spinning."
                    This is what I read.
                    Last edited by riotpack; 05-24-2010, 01:23 AM. Reason: adding source of timer on fan
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      the fan never stops on this design.
                      keeps running off 5VSB all the time..
                      • riotpack
                        • Jul 2008
                        • 27
                        #31
                        Then why not just use this? - I know it's messy; I just quickly drew it up.
                        • Wizard
                          • Mar 2008
                          • 2296
                          #32
                          Put transistor on ground side of fan's, and feed the base via 200-500 ohms to limit current via with diodes or zeners is not meant to be used as current source. Need a pull down resistor of around 1K or so on base as well.
                          This way this is done correctly.
                          Cheers, Wizard
                            • 30941
                            how you do it will actually depend on how the psu fucks with the fanspeed.
                            some will have constant 12v and mess with the ground wire, others will mess with the 12v and keep the fan grounded.
                            these are best because ones without a constant ground are almost impossible to use the tacho output for monitoring.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              EDIT
                              Whoops, wrong "running the fan while psu is off" thread.
                              • прямо
                                Viper22A 5VSB circuit
                                by прямо
                                So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                01-13-2024, 07:05 PM
                              • Astonished
                                Fixing the Charge Circuit of the Batteries of the DC Motor
                                by Astonished
                                Hi friends of electronics
                                What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                Please help me fix this circuit.
                                (the datasheet of the IC: https://pdf.datasheet.live/28...
                                01-28-2025, 06:24 AM
                              • mikey5791
                                Tiny Tech ATX480W output power ticking
                                by mikey5791
                                Hi to all forum members,
                                ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                                Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                                02-20-2025, 01:11 AM
                              • Tarot Superstars
                                Short Circuit tester
                                by Tarot Superstars
                                Hello.
                                I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                Link
                                The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                https://www.youtube.com/watch?v=0eixDdCpiO4
                                My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                09-25-2023, 09:11 AM
                              • M1NEBLANK SHOW
                                MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                                by M1NEBLANK SHOW
                                Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                                (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                                Schematic and Boardview here
                                04-04-2025, 03:57 PM
