Help please, Line + 5VSB increases the voltage.
  • SoporteHR
    • Sep 2018
    • 80
    • Venezuela
    Hello everyone, receive a cordial greeting.
    I have an ATX 500W power source. Chassis Model: LPJ2-23.
    It turns out that when measuring the line voltage + 5VSB. After the source is turned on, the voltage gradually increases until it reaches approximately 7.8 vdc.
    If I leave it connected to the power but turned off, the voltage remains stable at 5.1vdc. approximate
    I thought I was a capacitor in that sector. Then I measured them with the ESR Raptor and they measured me well, but since I don't have a capacitor to know the real capacity, then I proceeded to replace the larger capacitor of 1000uf x 10vdc. I tried and same behavior, the voltage slowly rises to reach 7.8vdc.
    I proceeded to replace each capacitor involved in that line one by one and was testing the same result.
    Last instance, replace TL431, same case, replace ceramic capacitor 104, same case.
    I demolished the 1.5kohm resistors and measured them, and they are very valuable. both.
    When the source starts for the first time, the voltage at the transformer diode output of the VSB line starts at 12vdc, by the time the output voltage rises to 7.8vdc, the output voltage of the diode approaches 17
    volts
    I don't know what else to try. Please if anyone has an idea, I appreciate it in advance.
    The controller of this source is the WT7514L
    Disassemble the source as a custom to check them when I get a computer from a client, in this case I had originally damaged the output capacitor of the line + 5vdc. Replace it arm the source, install it on the computer and the PC worked perfectly, until I turned it off and wanted to turn it on again, at that time the power source turned on and off immediately. I tested the PC with another power source and it works perfectly.
    Thank you very much in advance.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5081
    • New Zealand
    Re: Help please, Line + 5VSB increases the voltage.
    The WT7514L has nothing to do with the 5vSB. It only runs the main supply.
    It looks to me like your 5vSB circuit is one of the 2-transistor designs. Are you sure the new capacitors you tried are good? With bad capacitors, the voltage regulation in these style of circuits is bad.
    If you know the capacitors are good, then check the other parts in the 5vSB circuit. Optocoupler might be bad or something. Or a capacitor in the primary side.
    The 5vSB is probably going to be quite similar to the one in this schematic.
    -David VanHorn
    • SoporteHR
      • Sep 2018
      • 80
      • Venezuela
      Thank you very much friend.
      I just checked the diagram and replaced the octocoupler, since on the primary side, my source has no electrolytic capacitor.
      I am testing the source and it takes 2 hours without changing the voltage.
      I suspect it was the octocoupler.
      Now will you know what happened to the original octocoupler to generate that fault, leak in the internal transistor?
      After the whole day the source was turned on, the voltage of + 5VSB remained stable at 5.11 vdc
      Thanks for the help and excellent diagram.
        • 31259
        the led output slowly drops, philips tv's used to have a big problem with this because they put too much current into the led.
        • SoporteHR
          • Sep 2018
          • 80
          • Venezuela
          Thanks STJ,
          It sounds logical, the LED is degraded internally, but since replacing the optocoupler, ¿
          should I change the value of the LED resistance of this LED? To prevent damage to the new optocoupler.
            • 31259
            no, that will throw off the output.
            • SoporteHR
              • Sep 2018
              • 80
              • Venezuela
              Re: Help please, Line + 5VSB increases the voltage. - Resolved :-)
              Thanks STJ. For the confirmation.
              Yesterday I finished assembling the power source, to rule out and be sure that the fault was the octocoupler, I removed the new one and reinstalled the old one, effectively the voltage went back up to 6.8vdc.
              Today 08-15-2019. The source continues to operate with the stable voltage at 5.17 vdc. approx. I left the equipment on all day yesterday. And it operated correctly.
              I close the case.
              Thanks again to everyone for the help. Have a great day.
              Until next time.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5081
                • New Zealand
                Good to hear
                -David VanHorn
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  by sam_sam_sam
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                • FALKLAN
                  Running Line Voltage and Integrating LED Pods - Automotive
                  by FALKLAN
                  Howdy everyone! I hope all is well where ever you are!
                  I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                  I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                  02-05-2025, 12:30 AM
                • mikey5791
                  Tiny Tech ATX480W output power ticking
                  by mikey5791
                  Hi to all forum members,
                  ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                  Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                  02-20-2025, 01:11 AM
                • tofik
                  MOSFET equivalent K8A60DA
                  by tofik
                  Hello guys,
                  I have a shorted MOSFET K8A60DA with the following characteristics:
                  Type Designator: TK8A60DA
                  Marking Code: K8A60DA
                  Type of Transistor: MOSFET
                  Type of Control Channel: N -Channel
                  Maximum Power Dissipation (Pd): 45 W
                  Maximum Drain-Source Voltage |Vds|: 600 V
                  Maximum Gate-Source Voltage |Vgs|: 30 V
                  Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                  Maximum Drain Current |Id|: 7.5 A
                  Maximum Junction Temperature (Tj): 150 °C
                  Total Gate Charge (Qg): 20 nC
                  Rise Time (tr): 25 nS
                  Drain-Source
                  07-19-2023, 05:18 AM
                • SoporteHR
                  LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
                  by SoporteHR
                  Greetings to all, I hope you are well.
                  I consult you because I have a problem with this power source.
                  The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
                  When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
                  I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
                  but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
                  06-20-2023, 04:30 AM
