Unusual resistor in power supply - help ?
  • Stefan Payne
    • 1267
    Re: Unusual resistor in power supply - help ?
    Originally posted by Dannyx
    The supply or PSU tester ? The tester's back is flat - nothing to see there...
    PSU.
    Looks like a very interesting unit...
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      I DID take pics of the bottom of the board as well - close-ups at that - just in case some of those SMDs popped and the values would become illegible, but I deleted them when I solved the case Not a whole lot to see there - just some SMDs peppered around the area where the TNY chip is - mostly feedback stuff.
      Wattevah...
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
        by sam_sam_sam
        03-31-2024, 02:12 PM
      • Safrilhg
        Look for the resistor value in the BenQ G922HDAL monitor's power supply
        by Safrilhg
        Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
        In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
        How to determine the appropriate SMD resistor value for this condition? Thank You...
        11-06-2023, 12:43 PM
      • speter
        Gold 16ES led driver for use as a HV DC power supply
        by speter
        I bought this https://www.ebay.com/itm/315173036369 power supply to try to convert to a Tube radio B+ power supply I am wondering how to force it on to stay at it's highest voltage. Is there a way to make this not constant current? I need somewhere between 70 to 90vdc at I'm guessing 150ma. I am aware that the switching noise may cause interference in the radio, it is being driven by 4 3.7v lion 21760? cells with a BMS board. I basically want a dumb power supply for 90vdc which will have a cap for filtering between this and the 90v battery circuit
        04-07-2024, 01:29 PM
