Unusual resistor in power supply - help ?
Re: Unusual resistor in power supply - help ?
I DID take pics of the bottom of the board as well - close-ups at that - just in case some of those SMDs popped and the values would become illegible, but I deleted them when I solved the case
Not a whole lot to see there - just some SMDs peppered around the area where the TNY chip is - mostly feedback stuff.
Wattevah...Comment
Assuming...7 Photos -
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by SafrilhgHello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
How to determine the appropriate SMD resistor value for this condition? Thank You... -
by speterI bought this https://www.ebay.com/itm/315173036369 power supply to try to convert to a Tube radio B+ power supply I am wondering how to force it on to stay at it's highest voltage. Is there a way to make this not constant current? I need somewhere between 70 to 90vdc at I'm guessing 150ma. I am aware that the switching noise may cause interference in the radio, it is being driven by 4 3.7v lion 21760? cells with a BMS board. I basically want a dumb power supply for 90vdc which will have a cap for filtering between this and the 90v battery circuit
... - Loading...
