Thermaltake 450 lite with burnt/exploded 5vsb ic
  • Quaddro
    Tukang Kentu
    • Nov 2010
    • 141
    • Indonesia
    Hello everyone.
    My friend gave me a dead power supply, thermaltake litepower 450 watt, with model number LT-450NL2NK.
    after i open the case, i found a burnt IC in 5vsb area.
    The problem is, i don't know what is the ic serial.
    i tried to googled it, but i still can't found the same board type or OEM of this psu, so i cant found the type of burnt IC.
    What is OEM this psu use?
    And what is the type/serial of IC used in 5vsb?
    Thanks alot.
  • R_J
    • 9594
    Re: Thermaltake 450 lite with burnt/exploded 5vsb ic
    Can you provide a better picture of the bottom of ic1? to be able to see the traces and components connected to the ic1
    I am so far guessing it could be a OB5269CP
    • Quaddro
      Tukang Kentu
      • Nov 2010
      • 141
      • Indonesia
      Hi, thanks for the response..
      ok, this is the picture.
      • Quaddro
        Tukang Kentu
        • Nov 2010
        • 141
        • Indonesia
        Forget to include Product number..
        This one is thermaltake litepower 450 watt with Product Number: W0423
        • R_J
          • 9594
          I guess it won't be OB5269CP, this ic uses an external mosfet.
          • SoporteHR
            • Sep 2018
            • 80
            • Venezuela
            Hi, I have a Thermaltake TR2 600W
            In the primary, use a TNY176PN 7-pin IV, maybe your source uses an equivalent.
            • R_J
              • 9594
              Its not a TNY176PN either, wrong pinout, I can find lots of ic's that its not but can't seem to find which one is used here,
              It's also not a BH170A
              • Quaddro
                Tukang Kentu
                • Nov 2010
                • 141
                • Indonesia
                Yes, this one not TNY series. Because TNY using 7 pin.
                What is the oem this psu using?
                Usually thermaltake using solytech for their low end, but i think this one use atng, based on the type of heatsink.. idk.
                The ic of mystery...
                • R_J
                  • 9594
                  What are the other ic's in the primary? and what is that one in the secondary? sometimes searching for known ic's might point towards a similar schematic that has the correct standby ic.
                  I see this 8 pin has pins 7 & 8 connected together and 3 & 4 connected together. sometimes these 8 pin ic's will have pin 7 but it is not used
                  • Quaddro
                    Tukang Kentu
                    • Nov 2010
                    • 141
                    • Indonesia
                    Hello..
                    There's no other ic in primary. Just that one.
                    And in secondary using Weltrend wt7525 as supervisor.
                    • leotron
                      • Apr 2019
                      • 29
                      • Offworld
                      Hello there, check for reviews in the internet for some information like these ones. Some of them have photos that you can see the IC or the resistor values, etc.
                      https://www.hardocp.com/article/2009...power_supply/3
                      https://www.hardwaresecrets.com/ther...supply-review/
                      Also I found this website that has a lot of ATX Diagrams. http://publikz.com/projects/atx/
                      Good luck
                      • Quaddro
                        Tukang Kentu
                        • Nov 2010
                        • 141
                        • Indonesia
                        Good luck
                        Hello Mr. Leo, thanks for the response.
                        Unfortunately, the link that you given is based on fsp apfc machine.
                        So it's different than this one.
                        This thermaltake litepower 450, has the product number W0423.
                        The same board is shown in https://www.pbtech.co.nz/product/PSU...GEN-2-500W-OEM
                        and
                        https://www.newegg.com/Product/Produ...82E16817153279
                        But there's no review about this unit, so i still don't know about the5vsb ic
                        • leotron
                          • Apr 2019
                          • 29
                          • Offworld
                          It's OK, maybe you can write us down the other IC id numbers so we can use it to search on the web.
                          • Quaddro
                            Tukang Kentu
                            • Nov 2010
                            • 141
                            • Indonesia
                            The primary side only use single ic in 5vsb area.
                            The other ic is in secondary, weltrend wt7520 with the function as supervisor.
                            I'll try to draw some schematic for 5vsb section.
                            Maybe it'll help to determine the right ic.
                            • CapSwapper
                              • Feb 2014
                              • 69
                              Thermaltake PSU's are crap. I just bought the 600w for $17 out of curiosity and its full of CrapXon capacitors. It even has CrapXon as the main primary. So much for "high quality components"
                              • Quaddro
                                Tukang Kentu
                                • Nov 2010
                                • 141
                                • Indonesia
                                yeah, especially this thermaltake lite. passive, ancient topology etc..
                                so much crap on one "international" brand.
                                but the goal is to fix something broken.
                                if i can fix it, well, will be a nice addition of my psus..
                                  • 31214
                                  does the pinout match a TOPSWITCH or a Viper ??
                                  • Dan81
                                    SNES-powered
                                    • Oct 2013
                                    • 1866
                                    • Romania
                                    The two Thermaltake PSUs I have are both CWT ISO platform (which I'm not even sure of how much it can do) and while one of them has TEAPO caps (which AFAIK are decent), the other is filled with Fuhjyyus.
                                    So much for a PSU that not only wants to be "cool" but also power a beefier GPU w/ 6pin connector (both have 1x 6-pin 12V plugs)
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    Core i5-3470 3.60GHz
                                    16GB DDR3-1600
                                    Samsung SH-224AB DVD-RW
                                    Delux MG760 case
                                    • Quaddro
                                      Tukang Kentu
                                      • Nov 2010
                                      • 141
                                      • Indonesia
                                      i've already make a simple drawing about the connection of the ic with the other components.
                                      Maybe it can help to find out about this ic serial id.
                                      • R_J
                                        • 9594
                                        Its close, pins 7&8 connect directly to the transformer primary, the diode is in series with the [cap. across the resistor] and are connected across the primary of the transformer.
                                        D1 anode comes from the transformer run winding and the cathode connets to R3? (10Ω) to pin 2 (C1 or is it C3?) connects from pin 2 to ground
                                        • electomech-fixer
                                          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                          by electomech-fixer
                                          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                          09-15-2025, 01:42 AM
                                          Samsung ATIV Book 9 Lite Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung ATIV Book 9 Lite Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Book 9 Lite boardview and Book 9 Lite schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 05:27 AM
                                          HP lite Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP lite Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the lite boardview and lite schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP lite Hybrid (2-in-1)...
                                          09-07-2024, 07:19 AM
                                          09-07-2024, 07:12 AM
