What are typical problems with this kind of psu behaviour?
  • Trofazni
    • Dec 2016
    • 71
    • Serbia
    It is ordinary 12V 5A psu, everything measures ok, what could be problem?
    https://youtu.be/-zwaUHZ2OCk
    • Jul 2011
    • 6026
    Re: What are typical problems with this kind of psu behaviour?
    Let see the plastic housing for this power supply data plate
    Also let see the front side and back side of the board close up
    This power supply looks very familiar to some power supply that I have
    Is this medical grade type power supply
    If this is the type of power supply all the capacitors need to be replaced except the the main capacitor can left alone ——> these are very good switching power supply
    I have quite a few of 5 volt @ 5 amp switching power supply and I always recap them the capacitors that they use are real crap
    I also have a few 12 volt @ 2.75 amp one also
    The photos are from the 12 volt @ 2.75 amp medical grade switching power supply
    On second thought this might not be the same type of power supply
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      Hmmm, OVP shut down and restart? The low cold resistance of the halogen bulb is tripping over-current protection?
      Some of the solder joints near the board edge nearer the camera, roughly in the center of the board, look like they might have voids or cracks (a poor solder joint could open up if current passes through it).
      PeteS in CA
      • petehall347
        • Jan 2015
        • 4424
        • United Kingdom
        try incandescent bulb .start with 20w and work up .
          You should check the cold resistance of that lamp you are using, as Petes suggested it may have trip the over current protection.
          • Retro-Hipster
            Tinkerer
            • Apr 2019
            • 125
            You could use the whole "Diode gone wild" trick and essentially brush one of the leads on one of the halogen bulb contacts over and over quickly to help it warm up until it is lit/hot, then make the full connection.. that or don't go so janky and try something like an ntc thermistor between the bulb and the psu.. But what others have said on this one for sure.. most halogen bulbs have really low cold filament resistance. I'm using one of the 120v variety as a current limited supply on my bench right now. lol
            “Men always seem to think about their
            past before they die, as though they were
            frantically searching for proof that they
            truly lived.”
            – Jet (Cowboy Bebop) -
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • Francesc V.
              Problems with a LINEAR power supply
              by Francesc V.
              Hi:
              I bought an ebay kit to assemble a linear power supply. The following one that is explained in this page:
              https://www.qsl.net/z33t/dc_0-30v_0-3A_eng.html
              The power supply seems to work, but I have the following problems I would like someone to help me.
              1. The input must be about 24-26V AC. My idea was to reuse a 30VAC 160VA toroidal transformer. But with this input the output doesn't go from 0-30V......it remains with some mV. And I guess will stress/burn some components. Do you see any possible modification to...
              09-06-2023, 12:21 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
