Funai Model LC220EM2 PS Issues
  • walldog1
    • Jun 2018
    • 25
    Re: Funai Model LC220EM2 PS Issues
    Picture showed round flat with 2 mounting holes and only 2 leads. Maybe case is 3rd lead? Current Q602 is the common usual small body (3-4mm) with three leads.
    • walldog1
      • Jun 2018
      • 25
      I just looked at a PDF and it will work. Must of had a bad link before, sorry.
      • walldog1
        • Jun 2018
        • 25
        PDF shows it will work, bad link before I guess.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8340
          R602 is fine. Don't worry about that. The BC337 has a different pin out than the original transistor. You could leave one of the legs longer and bend them to the pin out you need.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            The Mosfet I picked is a direct replacement. Not sure if I can find something better than the BC337 to replace the driver transistor.
            • walldog1
              • Jun 2018
              • 25
              You are correct. I just explained in different post what my mistake was. Thanks again. I wish I would have held off on my Mouser order until now.
                The 0.8 Ohm reading is due to the added probe leads resistance, so you are OK, I am surprised that it survived.
                • walldog1
                  • Jun 2018
                  • 25
                  I could not amend my order with Mouser this morning, but they waived the shipping on the BC33740TA. YEAH! This NPN had the highest Hfe of the 3 to pick from. I assumed it was bad as when I finally figured out C,B,E from PDF's and plugged it into my meter on Hfe setting, it read zero.
                  I never used this feature before but I guess it must apply some current or voltage and you would get some number on the meter. And yes, I will have to twist the leads on new Q602 as different CBE order. Thanks, and I'll let you know in a few days if it all works.
                  • walldog1
                    • Jun 2018
                    • 25
                    Thanks budm & Capleaker for your help and advice. I put in all the new parts today, plugged it in and the fuse did not blow. I was happy, but I waited a couple of minutes. Then I decided to get meter and start checking Voltages. That is when I smelled smoke and then the fuse F601 blew. Smoke came from L601, AC Voltage line conditioner. I touched it and it was very hot! It must be shorted on bottom side because the top and sides look new!
                    So maybe L601 WAS THE ORIGINAL CULPRIT all along and he wiped out everything downstream. All my Zener's were shorted again. I did not bother testing Transistors. This is getting recycled. Too bad, it worked so good those first 2 hours.
                    I did gain valuable knowledge during this process (and only cost me $23), so again I say "Thanks" I hope this thread helps someone else someday. I now have lots of spare parts that I'll probably never use.
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                    • nev1001
                      What zener diode might fix the sound on Maestro Mayhem gaming chair?
                      by nev1001
                      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                      I think an issue could be a zener diode (or capacitor) which has shorted out.
                      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                      04-17-2025, 05:09 PM
                    • gretti
                      MSI Z370-A Pro, works but does not power off or reboot and USB issues
                      by gretti
                      I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                      The MSI BIOS included the ME firmware for the board. The size...
                      10-16-2025, 02:14 AM
                    • kotel studios
                      Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                      by kotel studios
                      Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                      State I got it in:
                      Squealing from the PSU
                      After logo I get a blank screen
                      After 10 seconds of having a blank display w/ backlight the TV dies
                      Give it 7-10ish seconds again and it starts to bootloop.
                      What I did so far:
                      Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                      Checked all voltage rails:
                      5VSB - 4.8V
                      AMP+13V - 14.4V
                      13V - 12.98V (in manual 12V)...
                      09-21-2025, 02:00 AM
