power brick dead
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    power brick dead
    i got a power brick in the mail today
    ran for an hour, unplugged it, replugged it, ran for a sec and died
    will not work
    popped it open to find no failed caps
    some tiny ones jwco
    everything with vents nichicon
    big one vz (m) series
    small ones pj (m) series
    bought from ebay store "monster power"
    need help since it will not shot wothout some glue
    its a ac 12v 4.0a used on a sharp flatscreen tv
    no power/led
    i have no dmm at this time
    sigpic
    (Insert witty quote here)
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • mmartell
    How to troubleshoot dead power brick
    by mmartell
    I have an adjustable power supply having a selectable voltage from 15v to 24v. It was sold as a universal soundbar power supply.
    It has been outdoors in the elements powering a set of outdoor bluetooth rock speakers until recently when it stopped working. (ya ya I know...)
    I opened it and it looks like there was some liquid ingress but I can't find any shorted silicon and the fuse is not blown. I measure about 160v dc after the bridge rectifier but nothing at the main cap. I suspect the power ic is not running. Obviously there is no voltage on the secondary either....
    02-05-2024, 06:45 PM
  • Andreas_de
    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
    by Andreas_de
    Hello!
    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
    04-12-2025, 10:38 AM
    03-31-2024, 02:12 PM
