Delta DPS 386AP for HP plotter fuses blown
  • Slawkos
    • Oct 2014
    • 13
    • Ireland
    Hi there,
    I have a problem with my DPS386AP Power Supply, it blew up the fuses after turning on, the same scenario after replacing them. Have found
    faulty MOSFET IRFP450 marked as Q1 on PCB (have checked all of them and all Diodes). Not sure about the rectifier bridge (KBU8K) shows drop of 0.507V and 0.505V on "-" and "~" and 0.944V on "-" and "+" (the last one I'm not sure about). What else can cause the MOSFET burnout? Any suggestions very welcomed. Thanks
  • R_J
    • 9550
    Re: Delta DPS 386AP for HP plotter fuses blown
    The bridge is just 4 diodes in a single package, check each diode on its own. If the reading across + & - is low, its likely something else not the bridge, If the man cap has any voltage on it, it can throw off the reading.
    If the fets were shorted drain to gate, check the gate drive components, It looks like the gate drive ic is on the small sub board, it may have been damaged.
    Also check this thread https://www.badcaps.net/forum/showthread.php?t=17779
    • Slawkos
      • Oct 2014
      • 13
      • Ireland
      Hi, thanks for your help I have seeing the topic you've suggested, I have removed the bridge and checked as I have mentioned in first post. Drop voltage of 0.507V and 0.505V across "-" and "~" and 0.944V across "-" and "+", checked rest of the components on the hi side, they're looking ok. How to check the ic chip I just measured the drop voltage between Ucc and GND and it seems to be ok.
      Is there anything else I can do?
      • R_J
        • 9550
        But what is the VCC voltage? Also check the voltage on pin 14 Vref, it should be 7.5 volts.
        You can check the voltage on the output pin that feeds the fet, but to really check if the ic is ok you need to scope the output to see if it is producing an output pulse
        Download the ML4841CP pdf it may help since there is no schematic of this power supply.
        I found this schematic at danyk.cz/s_atx_en.html, it uses a similar drive ic, It might help?
        • Slawkos
          • Oct 2014
          • 13
          • Ireland
          Hi, thank you for the schematics just have got time and the parts now, after replacement of the fet the supply is back to life the Vcc is 12.54 and Vref 7.49, PFC OUT 2.73V, PWM OUT 3.42V the source on the Fet is 124V, what else can I diagnose and it could lead to the fet failure. I have just got scope but don’t want to brake it as I heard about Isolating transformers need to be used wit it, cheers
          • R_J
            • 9550
            Anytime you use a scope on the primary side of the power supply, you need an isolation transformer, the reason is that the scope ground needs to be connected to the hot ground, and if you do that without isolation, you will blow the power supply.
            There is no problem using the scope on the secondary side if you need to without an isolation transformer.
            As for the voltages, they are likely ok if the supply is working, You may want to either check or replace some of the small electrolytic caps in that circuit. The can go bad (open) and not show any signs like bulging or leaking, they just dry up due to heat over time.
            • Slawkos
              • Oct 2014
              • 13
              • Ireland
              Hi, thanks for the tips I have check some tutorials on YouTube. I have checked the small caps and they're ok but the big one had big resistance so I've replaced it hope it will help for long, big thank you for the help
              Last edited by Slawkos; 04-17-2019, 03:00 PM. Reason: Icones from iPhone didn’t work
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
                MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-07-2024, 03:40 AM
              • MrzPdlch
                Blown fuses on Gigabyte GTX 980TI 6GB
                by MrzPdlch
                Hey everyone,
                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                Find some pictures of the actual GPU together with a picture of how it should look like.
                I also wonder whther it might be a problem that there...
                03-10-2024, 04:14 PM
              • BMCappelletti
                Sonos Play 1 with blown cap and fuses
                by BMCappelletti
                Hi there.
                I was given a Sonos Play 1 (yeah, very old) that does not turn on.
                Checking the main board, I can see a blown cap, that connects to two blown fuses. Right by the LAN port.
                Where should I start looking for the main fault?
                Thank you....
                08-10-2023, 04:02 PM
              • Junkrepair
                Calculating ESR from tan delta -- tan delta's dependence on capacitance
                by Junkrepair
                I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                I found this nice little description of the conversion:
                Calculating capacitor ESR from Tan(delta)
                https://forum.digikey.com/t/calculat...-from-tan/2633
                It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                06-12-2023, 02:45 PM
