HP DesignJet 5500 Power Supply
  • ShelbyStang
    • Dec 2011
    • 2
    HP DesignJet 5500 Power Supply is not working does anyone know what Caps that could cause this to fail on the PS Board.
    (It has volts +3, +5, -15) (It doesn’t have +12, +24, +36.)
    • Jul 2011
    • 6024
    Re: HP DesignJet 5500 Power Supply
    First
    Open up your power supply CAREFULLY
    then look for burnt parts and bloated caps
    If you have an ESR cap tester meter look for caps that have high ohm reading
    I just repaired a Dell power supply for a printer
    I found one mosfet
    I found two caps with high ESR reading and these where not bloated
    After changing these part the power supply works agian
    I hope this helps
    • LEMO
      • Feb 2014
      • 9
      • Kaernten
      For all who want to repair HP DESIGNJET 5000 5500 Power supply's
      Produced by Delta - DPS-386AP PN:2958006202
      I repaired 3 Power Supplies' and found 2 relevant -1x 10 (C33) u 1x 47u (C35) bad caps.
      I will add some Pictures
      There were some other not good Caps - all 10, 22, 47 uF same manufacturer
      But it is good to measure ESR (>30 Ohm)
      I find a good measuring tool is ESR 70 measurement in circuits is possible
      http://www.peakelec.co.uk/acatalog/jz_esr70.html
      To test the PS you have to connect LPM (red wire) to ground (wakeup from STANDBY) and a resistor 1K from 24 V (orange)to ground - minimum current
      Who knows the manufacturer of these caps? tec??
      • Ed Herdman
        • Apr 2014
        • 31
        @ Lemo: The same brand is mentioned here:
        https://www.badcaps.net/forum/showthread.php?t=2311
        See PCBONEZ's post.
        • dmill89
          • Dec 2011
          • 2531
          Ltec, they are common in cheaper Delta products. They seem to hold up relatively well in most Deltas but aren't as reliable as Japanese caps.
          • Domenor
            • Feb 2015
            • 1
            • Brazil
            Thank you Lemo, your tip me was very helpful. The C33 capacitor was bad. Also the scheme for the source test was great. Thank you very much!
            • Sascha65
              • May 2017
              • 2
              First
              I found one mosfet
              I hope this helps
              Hello and thanks for your report. I'm Sascha from Germany and have a question. Which Mosfet with the power supply was defective? Many thanks for your response.
                • Jul 2011
                • 6024
                The mosfet next to the switching IC chip was the one I replaced and the switching IC chip as well as all the caps
                • Sascha65
                  • May 2017
                  • 2
                  Hi Lemo, I need your Help. Please write me. Thank you, Sascha
                  • inspyre
                    • Jan 2023
                    • 2
                    Just wanted to give mega high-fives to the info shared here.
                    Got my 5500 back up and running replacing just 2 caps!
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Delta seems to really like Ltec and Taicon capacitors, they also seem to fail for everyone else a lot earlier than they do for them. I think the guys at Delta do their own in-house testing and don't blindly trust the datasheets provided by the cap manufacturers. But they do eventually fail.
                      A working TV? How boring!
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • eryjus
                        Heathkit IO-4205 Power Supply Caps
                        by eryjus
                        First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                        I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                        I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                        05-10-2023, 11:21 AM
                      • captain150
                        Help with switching power supply caps
                        by captain150
                        I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                        I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                        03-16-2025, 07:34 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
