YLP-013 450W capacitor value.
  • rattman
    • Dec 2015
    • 18
    • US
    Hi Everyone.
    I have a YLP-013 450W power supply, Rev 2.2
    and I'm looking for the value of C28. This disc cap
    disintegrated When Q7, part #C5027 shorted out
    which is connected to the collector of Q7.
    Thank you in advance.
    • Jul 2011
    • 6069
    Re: YLP-013 450W capacitor value.
    Please post pictures of this power supply
    • rattman
      • Dec 2015
      • 18
      • US
      I apologize, it is a power supply out of a desktop computer.
      Here are a few pics of the power supply with heat sink in
      and out of the supply board. Pic #3 shows the damage of
      Q7, and the location of C28 that was removed. I cleaned
      the board up a little to see the locations of the damaged
      components. Any help would be appreciated.
      Thank you.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Rattman, are you repairing this power supply for fun / as a learning experience, or actually doing the repair for a customer (or yourself)? Reason I ask is because that power supply appears to be a cheapo unit that isn't really worth investing time into, unless you're doing it to learn / for fun.
        In any case, that cap (C28) and transistor Q7 are part of the 5VSB circuit on the power supply. Being a cheap PSU, this is a 2-transistor self-oscillating flyback circuit. Q7 is the main switching component and transistor Q4 is its driver. Chances are, Q4 is probably blown too (either short-circuit or open-circuit is possible, since it's a small transistor.) Also worth checking are all the diodes in that circuit. And if you have an ESR + capacitance meter, check the output capacitors of the 5VSB circuit. If not, replace them. There's a good chance those are bad and caused the circuit to go bad.
        As for C28, I can't tell you exactly what it is without some pictures of the other side of the PCB. It may be just a small value cap across Q7 Collector-Emitter terminals, or it may be for something else. As for the ceramic disc cap above that - it appears fairly large and is likely part of the RCD snubber network, so I don't think C28 is a snubber cap.
        But again, will need pictures of the traces to determine that.
        The 5VSB on this PSU being a 2-transistor circuit means it's going to be a fairly simple circuit. However, those 2-transistor circuits are very "particular" about having all parts working. If one part is bad, they tend to blow themselves up again. With that said, when you do any further experiments (after attempting a repair, that is), make sure to use an incandescent light bulb (about 60-100W) in series with the PSU's live input (or just remove the fuse and connect the bulb across that). This will limit the current and save your PSU from blowing more parts, should the 5VSB try to do anything "ballistic" again.
        • rattman
          • Dec 2015
          • 18
          • US
          Thank you for the reply momaka.
          Trying to save a few bucks by repairing it, but it appears that YUELIN does not want you to repair it as there are no schematics to be found anywhere.
          I have an EDS in circuit cap checker that I checked the caps with, they appear to be okay.
          I do use the light bulb trick when repairing TV's, but did not think to use it on power supplies which is a good idea, thanks for the heads-up.
          When the power supply shorted out the computer was off. It came with a mid tower Power-up computer case I bought online a while back.
          I added a few pics showing the bottom of the power board.
          Thanks again.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            Judging from the second picture in post #3 of this thread, it looks like the PSU has generic 1KV (DC) caps where safety agency rated Y caps (250VAC or higher, with special construction) should be used. If so, that is a safety issue.
            PeteS in CA
            • rattman
              • Dec 2015
              • 18
              • US
              Here are a few more pictures of the power supply with a couple numbers on the top in Pic #8 that might help. If someone has this power supply I would appreciate it if you could look at the C28 disc capacitor and see what the value is on that capacitor. Thank you in advance.
              • R_J
                • 9602
                I don't have that ps but maybe this will help?
                • rattman
                  • Dec 2015
                  • 18
                  • US
                  It does help me quite a bit, thank you R_J.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    The diagram that RJ posted looks pretty similar to your PSU. Check the value of the orange ceramic capacitor above C28. If it's 10 nF like on RJ's diagram, then C28 should probably be around 470 pF. Since it blew up on your PSU, check the resistor next to that orange ceramic capacitor for being open-circuit. Basically, C28 is part of the snubber network, so everything must work properly there. Otherwise, those parts and the switching BJT could blow again.
                    While at it, also check the small TO-92 transistor Q4 for short and open-circuit (will need to remove it from the board to check it properly.)
                    • rattman
                      • Dec 2015
                      • 18
                      • US
                      Thank you for the input momaka.
                      I will check the value of that disc capacitor above C28
                      to see if its value is 10 nano, & check Q4 to make sure
                      it is not open or shorted and also that resistor.
                      I will post the results and let you know what I find.
                      Again thank you for the info.
                      • rattman
                        • Dec 2015
                        • 18
                        • US
                        I checked the resistor, (R65=100K Ohms) next to/behind capacitor (C27=10 nF), it measures 99.1K ohms.
                        Since C27 is 10 nF I agree that C28 should be about 0.47 nF 1KV. Checked Q4 for an open/short, measured
                        okay but has a crack across it so I'm gonna replace it. Ordered the replacement parts and will let you
                        know how it goes.
                        • R_J
                          • 9602
                          Q4 is not likely cracked, it's just how some of the to92's are made (they are made in two parts and fused together)
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            You're probably right. But he might as well replace it now - less chance of bad components remaining that way.
                            • rattman
                              • Dec 2015
                              • 18
                              • US
                              Got my parts in and replaced Q4, Q7, and C28. There are no shorts, checked with a 75 watt light bulb across fuse connection. Installed the fuse jumped the green wire and a black wire, nothing. Even tried with a hard drive hooked up for a load, no go. With the jumper in place checked for 5v and 12v, nothing. I will retrace my steps to see if I missed something.
                              Q4 has a crack under the part number around the side to the back.
                              Thanks again for your continued help and input.
                              • R_J
                                • 9602
                                That circuit seems to be the standby circuit only, It should work without any jumpers etc. and you should have standby voltage
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  I agree with R_J here - forget about jumpering the PS_ON signal (Green to ground) for now. First, you must get 5V on the 5VSB pin (purple wire). This should be up as soon as the PSU is plugged in. Without 5VSB, nothing else will work.
                                  If all components check out fine, check the 5VSB transformer's primary windings for open-circuit: that is, the main winding (which should be connected between Q7 collector and +340V tap on the big input caps) and the aux. primary winding (this one should be connected between ground and the 100-Ohm resistor in front of the 5VSB transformer.) If either of these two windings reads open-circuit or high resistance (over 10-20 Ohms, I'd say), the 5VSB traffo may be gone. Also check the source resistor for Q7 (if there is one, as I don't see it) and the 680-KOhm resistor (color code: blue, grey, yellow, gold) next to it. The 680-KOhm resistor is really high resistance, so you need to remove it out of the circuit to check it properly.
                                  • rattman
                                    • Dec 2015
                                    • 18
                                    • US
                                    Hi momaka. I checked the resistance on the transformer and the resistance readings are less than 1 ohm. The components check okay. Checked the voltage on the purple wire but it is not 5 volts. The voltage goes from about 2.71 volts to 3.04 volts, goes up and down constantly. Thanks again for everyone's help.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Good observation.
                                      That means the 5VSB is actually either trying to start or not regulating properly.
                                      The issue that can cause the former would be an overload from a component somewhere or perhaps bad startup capacitor (which your 2-transistor 5VSB circuit doesn't appear to have) or bad output capacitors. And the latter could be due to either bad optocoupler or bad 431 shunt regulator on the secondary side. So it might help to swap these with known good working ones, just to make sure.
                                      • Bill Sullivan
                                        • Feb 2022
                                        I know this is an old post but thought I would answer since I have this board and Rev 2.1 board.
                                        YLP-013 Rev 2.2 c-28 is 221 1kv, c-24 is 103 1 kv
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • Agent24
                                          Dick Smith Q-1760 linear power supply filter capacitor question
                                          by Agent24
                                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                          It has at least one problem.
                                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                          I have already ordered a replacement potentiometer, so that's not an issue.
                                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                          All are CapXon...
                                          10-21-2025, 05:39 PM
                                        • AdrenalinTL
                                          450W PSU capacitor Identification and where to get another one?
                                          by AdrenalinTL
                                          Howdy peeps.
                                          Can someone tell me where to get another one of these? google doesn't seem to have a 560uF and I am still quite a newbie to the whole world of electronics so trying to learn as I go. The one to the right of this pic is definitely swollen. PSU does random shut downs / no power on etc
                                          Also, can it be replaced with a higher uF cap ? Same voltage?
                                          Thanks...
                                          12-11-2024, 02:20 AM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
