Help identity blown part in Alesis Mixer PS
  • R_J
    • 9535
    Re: Help identity blown part in Alesis Mixer PS
    I suspect the MK-328 can't measure it properly. I will ask again, Is the power supply working or not?
    • Carm99
      • Jun 2014
      • 69
      • England
      Ill have to replace the 2200 cap and the small ceramic one then see if it works.
      Ill let you know after that, what happened hopefully it wont blow the small cap again. again.
      Thanks so far anyway.
      • R_J
        • 9535
        That small cap likely went on its own. and if you want to try the supply you can try it without that cap. installed for now. Like I said I doubt that 2200µf cap is bad, if it was it would have either leaked or bulged.
        The most voltage across the small .1µf is 25 volts, It is not uncommon for them to fail shorted
        • R_J
          • 9535
          Originally posted by Carm99
          The 2200 big cap on the board is testing 0.00Ω esr.
          Did you happpen to check the capacity of the cap also? or just the esr? That 0.00Ω esr seemed a bit odd to me. I guess the cap could be completely open and not measuring anything
          • Carm99
            • Jun 2014
            • 69
            • England
            Its not measuring any resistance on a multimeter either so I swapped it for a new one.
            Power supply works now.I didnt leave it on for long though.
            Im gonna check it again later.
            • R_J
              • 9535
              It could be that the 2200 went open and the poor little .1uf tried to do the filtering and failed.
              Try using diode test with your meter, that should show something, then reverse the leads and check again
              • Carm99
                • Jun 2014
                • 69
                • England
                #27
                I tried that. It was the same.
                Im gonna replace the rest of the caps anyway. Also those two 0.1uf ones.
                  • Jul 2011
                  • 6037
                  Not necessarily meaning I had a capacitor ESR reading like that and when I check the new one I got the same exact results
                  I was also confused as well with the results
                  In fact I check this capacitor with a capacitor tester that checks UF readings and it readings were what should have been but I did replace it anyway
                  I would check a new capacitor with same exact UF value and the same exact voltage see if you get the same exact results
                  • Carm99
                    • Jun 2014
                    • 69
                    • England
                    #29
                    I got it working in the end ,it was the transistors.
                    • cmlewis89
                      LG 47LB5DF blown power supply board
                      by cmlewis89
                      Hi folks,
                      I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                      09-03-2024, 07:50 PM
                    • Bektronics
                      Schematic Digital Audio mixer RCF type M18
                      by Bektronics
                      Hello dear audio friends.
                      I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                      The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                      I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                      Thanks in advance if anyone can help me with this schematic.
                      Of course, all information about this digital mixer and possibly references...
                      07-24-2023, 06:40 AM
                    • drscoot
                      HP X360 convertible battery blown fuse error, not charging
                      by drscoot
                      HP Modelnumber: 14-dh0061nb​
                      This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                      The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                      I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                      And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                      All these 3 batteries are charging...
                      12-15-2023, 05:54 AM
                    • Thermaltake
                      Yahama mixer PSU difference
                      by Thermaltake
                      I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
                      I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
                      And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
                      I google a little and found that there is this part number...
                      09-17-2024, 11:52 AM
                    • Thermaltake
                      Power button on Behringer Xenyx 1204USB mixer dead ?
                      by Thermaltake
                      Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
                      I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
                      08-16-2022, 03:22 AM
