This is a sticky topic.
  • Behemot
    • 4845
    • CZ
    #1541
    Originally posted by Pentium4
    …or use a heavily used same spec'd Samxon that reads 270uF.
    What's the nominal, 330 uF?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Yeah, 330uF. It was in a dead Enermax power supply where the PFC transistors and primary FET's shorted when it failed
      • Behemot
        • 4845
        • CZ
        #1543
        It's too close to tolerance mantinel, I'd ditch it.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          So you would have kept the CapXon too in that situation? It read 338uF. I still feel the need to replace it though
          • Behemot
            • 4845
            • CZ
            #1545
            I don't usually replace input caps, mostly only the laughable small 200V ones or in displays where they tend to get bad more than I'd like.
            • cheese007
              • May 2009
              • 85
              #1546
              HEC-550TB. Same unit as this thing. Caps on secondary are all Teapo, except for one Su'scon on the 5VSB and other assorted minor caps. Primary is CapXon.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                #1547
                I've seen that one before - i have the feeling you're gonna find "350W" silkscreened somewhere.
                A working TV? How boring!
                • cheese007
                  • May 2009
                  • 85
                  #1548
                  I doubt it. Regardless, I picked it up for $9.99 and it does 550w clean according to the review.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Good PSU, HEC makes good stuff when they try. I'd replace the Su'scon and Teapo though
                    • Behemot
                      • 4845
                      • CZ
                      #1550
                      Is not yet decided but should get bronze price http://diit.cz/node/92121/su/b607cf0...9eaded3f021841
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Unknown OEM, the previous user ripped the label off but everything points towards a 350W PSU, as in 6A bridge rectifier, TO-247 13009 switchers, 35 transformer, 30A schottky on 3.3V and 5V, dual 20A schottky's in parallel for 12V
                        Take a look at those LCZ capacitors....Their capacitance is way off, and check out the sleeving on the bottom, horrible!
                        Worst of all, check out those resistors by the supervisory chip, they're broken?!?! Is this just your typical "chinese quality" ?
                        The rest of the caps consist of Asia'x, Canicon, and Kingcon (the ones with Ruby style vents)
                        • Behemot
                          • 4845
                          • CZ
                          #1552
                          Not ExplodeGen but the other one I still forget? Sun Pro? I'd say it was labeled at least 450 W
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Probably
                            Interesting guesses, but I would guess Sun Pro would have TB markings on the transformers. I was thinking this looks like an older Wintech
                            • Behemot
                              • 4845
                              • CZ
                              #1554
                              One as the other, I think they almost all use this two decades old design
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                No kidding..because people keep buying them! Think it was even functioning properly with those broken resistors?? They're connected to the POS pin (pin 16) on the PWM
                                • PeteS in CA
                                  • Aug 2005
                                  • 3581
                                  • USA, Unsure of Planet
                                  #1556
                                  P4, re those "broken" resistors, I think they are not broken, but intentionally snipped to trim some aspect(s) of circuit performance. The two resistors are 270K and 470K, and if in parallel with resistors of 1K-10K, those resistors could be used to have a small fine tuning effect. It's cheaper and quicker than a potentiometer, and slightly more reliable as well (compared to a potentiometer).
                                  PeteS in CA
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    Really? Interesting...Thanks Pete
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      I believe the manufacturer is Dongguan Jiqixin Electronics aka Kineagle Electronics.
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        In the heart of China! How did you figure out the manufacturer?? Amazing
                                        • Heihachi_73
                                          • Jun 2012
                                          • 713
                                          AcBel API2PC23 200W power supply from a 2003 IBM S50 SFF desktop. The mainboard was full of dust and trashed, with twelve bad capacitors (the failed caps mostly being KZGs, three 85°C Rubycon YKs and a handful of small Rubycon CEs).
                                          Photos were taken before removing the dust bunnies, in the early hours of the morning under a crappy CFL. The PSU is a two PCB design, separating the primary and secondary sides. Surprisingly, not one capacitor has bulged despite the amount of dust in there, although, the caps are entirely from Nippon Chemi-Con rather than the usual suspect brands found in most OEM PSUs.
                                          On the primary board, we have a bridge rectifier, two 330uF 250V SMQ series and a massive PFC coil.
                                          On the secondary board, there are some decent sized FETs and two copper heat sinks. The ATX power connector lacks the white -5V wire despite being from 2003, so it's a modern design (yet some cheap and nasty PSUs still come with them), and also has a single plug for a SATA hard drive - there is no floppy drive power connector (the floppy was a laptop style drive with a flat ribbon cable, although the board did have a regular 34-pin floppy cable as well). The 12V side has a single 2200uF 16V KY, 5V has two 1000uF 10V KYs, with the small caps being KME series (the larger KME with the vent is 100uF 50V). I can't see the other values around the 3.3/5/12V rails as it is too densely populated in there, but I assume these are also 1000uF 10V caps. I couldn't see the FET/Schottkey markings for the same reason.
                                          The fan is a Protechnic MGA8012MS secured with rubber mounts instead of the usual screws, and has clips on the board so it can be replaced without having to get out the soldering iron. The fan was still OK however, despite the amount of dust, and the PSU still works as well.
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
                                            DVR camera recorder switching power supply capacitor failure really
                                            These cheap non brand capacitors at it again
                                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                            Well at least I have the cameras back on line I to try the...
                                            01-22-2022, 06:28 PM
                                            DVR recorder Switching power supply Failure
                                            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                            This...
                                            05-27-2023, 03:03 AM
