This is a sticky topic.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Originally posted by LDSisHere
    I wanted to share some pictures of power supply that came out of a PCI expansion box that was given too me. It is one of the heaviest and dense power supplies I have yet encountered. It also has three heatsinks compared to the standard two found in most supplies. It does not have the best brands of capacitors but I did not see any of them bulging and it had been running 24/7 for >7 years if not longer.
    That is one SWEEEET PSU!
    Muh-soggy-knee
    • mariushm
      • May 2011
      • 3799
      #1062
      Really not a bad power supply.
      Big heatsinks, capacitors are not that bad (Ce-Tur and Lelon are a bit above those no-name chinese capacitors), transformer looks like it's suitable for the output listed on label...
      It's even tested by UL and the values seem legit:
      http://database.ul.com/cgi-bin/XYV/t...374&sequence=1
      YM-6042A(a)
      v a va
      5.42 46 212
      12.46 34 371 -
      3.41 45 127 -
      5.2 2 8 -
      -12.1 3 24 -
      5.13 6 33 -
      • Agent24
        I see dead caps
        • Oct 2007
        • 4981
        • New Zealand
        #1063
        Must have some good cooling since none of those capacitors look like top brands
        -David VanHorn
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          #1064
          I think the PFC O/P cap (?) was Hitachi. The fan is Nidec, good stuff. The heatsinks ... heavy metal is goodness!
          PeteS in CA
          • Behemot
            • 4845
            • CZ
            #1065
            I wouldn't want to replace those caps if they would fail, there is no room inside at all
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              #1066
              Looks like the only one.
              The heatsinks look like they are bolted on rather than soldered in so it probably wouldn't be too bad actually
              -David VanHorn
              • Behemot
                • 4845
                • CZ
                #1067
                But all the sillicon is attached to them.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4981
                  • New Zealand
                  #1068
                  True, but it's still easier to desolder transistors than heatsinks
                  -David VanHorn
                  • Behemot
                    • 4845
                    • CZ
                    #1069
                    Well, using hot air, you can desolder both at the same time. But I am trying to avoid removing sillicon as much as possible, PCB usually does not liek that much of heat needed to desolder as many joints in the same time.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4981
                      • New Zealand
                      #1070
                      So don't desolder all at once, use a different tool and desolder the leads selectively?
                      -David VanHorn
                      • Behemot
                        • 4845
                        • CZ
                        #1071
                        Well I got only this chineese sucking litz wire, not a great deal…and I have to heat it pretty much too for it to be able to suck somethign out, so
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4981
                          • New Zealand
                          #1072
                          Desolder braid must be fluxed to work properly. If it's some Chinese stuff it probably has nothing on it already, or maybe it's just crap quality.
                          True Litz wire is likely to be enamel coated, which really won't help for desoldering...
                          Get a desolder pump or bulb, even a manual non-heated one will be nicer than proper braid for most things.
                          -David VanHorn
                          • Behemot
                            • 4845
                            • CZ
                            #1073
                            I don't really like these things…
                            Well if I use some flux on that chineese thing and heat it properly (I got 60W pen for that which heats like 150 W one ), it's not that bad, but still, it's messy. I am trying to avoid this kind of resoldering as much as I can.
                            But I am getting practice, so it's better every time
                            • maxd
                              • Aug 2012
                              • 11
                              #1074
                              Brand new Fortron/Source FSP350-50GMN. I bought this to replace PSU in old P4 system. I didn't find any info on web about this particular model before purchasing. As I and couple my friends previously got good experience with FSP PSUs, I went for ir. There were no sticker on the case so I opened it and looked inside. To my surprise this units buid quality apared much cheaper than for example PNF series Fortrons.
                              One 150uF/400V 85C CapXon cap on primary.
                              In the middle 1 Taepo, 1 OST and 1 CapXon brand cap.
                              On secondary 5 CapXon caps and for 3 caps (violet ones) I could not figure out what brand they are.
                              Cables are short. 30 cm each. And there is no that plastic thingy that holds them in place.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Disappointing for an FSP unit. That definitely looks underbuilt for a 350. Those violet caps are probably Yageo/Teapo. At least they used a decent fan. I would recap it. But it only looks good for 250W (Safely)
                                • maxd
                                  • Aug 2012
                                  • 11
                                  #1076
                                  Power output does not concern me much. That PC does not have dedicated video card. All I'm concerned is power noise (no way to measure that) and what this PSU will do to other components if it fails.
                                  I'm concidering preventive recap. Couple of questions. Cap on primary has quite small capacity. No problem if I put there 330uF or 470uF? Or there is no need for that. Then caps on secondary are with different capacitance (470uF-2200uF). Is it acceptable to replace all those just with one value caps? Let's say 2200uF/10 or 16 (largest caps there).
                                    For PFC you typically need 75% or more capacitance to watt ratio so I'd say 270uF minimum, 330uF best.
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      Brand new those CapXon's will keep the ripple in check but I would definitely replace them because it will only get worse over time with CapXon. FSP units are great with good caps. You can increase the capacitance and voltage on them (the filtering caps) but I usually leave or replace with the same value for the -12V cap, which is probably a 470uF 16V cap
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #1079
                                        Been using NCC KY 680 uF as they are even cheaper than 470uF variant at Digi-Key
                                        Anyway, I think that transformer can do the power, input diodes are not that much of a problem too - this thing has active PFC so there would be almost none reactive load, and as for efficiency, I guess arround 80 %. So if the diodes are like 3 A (seem beefy enough for that), it is going to provide the power. Just the ripple
                                        • PeteS in CA
                                          • Aug 2005
                                          • 3581
                                          #1080
                                          Holy cow! Whe-e-e-e-eres the beef?! 250W seems realistic. The caps you would use depend on what's available there in Riga. Speaking generally: Nichicon PW, PA and HE are good series; United Chemicon (Nippon Chemicon) LXZ, KY and KE series are good; Rubycon ZL series is good; Panasonic FC and FM are good (FJ and FK may be good, I just haven't had experience with them).
                                          PeteS in CA
