This is a sticky topic.
  • razvanu
    • Mar 2022
    #3181
    Hi everyone I have 5 PSUs for spare parts, but when they do power on.
    Which of them it's a good to keep ?
      master hoarder
      • May 2008
      • 12175
      #3182
      Not enough pictures to show really... but here's my 2 cents anyways....
      Keep:
      https://www.badcaps.net/forum/attach...3&d=1647766851
      Probably keep (can't see caps and other components to tell more certainly):
      https://www.badcaps.net/forum/attach...5&d=1647766851
      Keep... but add missing input filtering and maybe new caps on output:
      https://www.badcaps.net/forum/attach...4&d=1647766851
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 816
        Re: Thermaltake Purepower HPC-420-102 DF, Recap and new cables
        So i finally got some replacement caps for this thing, so here is the recapping, plus the new cables for this thing.
        5VSB - Teapo SH 1000uf 16, Teapo SEK 470uf 16v ⇒ Rubycon YXJ 1000uf 16v, NCC KYB 470uf 16v.
        12V - Teapo SEK 10uf 50v, Teapo SC 2200uf 16v -> Rubycon YXG 10uf 50v, NCC KZE 2200uf 16v.
        5v - 2x Teapo SC 3300uf 10v -> 2x Panasonic FS 2700uf 10v.
        3.3v - 2x Teapo SC 3300uf 6.3 -> 2x Panasonic FS 2700uf 10v.
        -12v - Teapo SEK 470uf 16v -> Rubycon ZLH 680uf 16v.
        -5V - Teapo SEK 10uf 50v -> Rubycon YXG 10uf 50v.
        I also replaced pretty much all the smaller caps on both the primary and secondary side (forgot to document them all), and out of all the Teapo caps i replaced, only about 2 of them were still what i'd consider to be good, most of the smaller ones had high ESR, and the 3300uf ones had high leakage.
        And lastly, the new cables i attached came from a couple of damaged PSUs, and the cables are as follows:
        20-pin ATX cable (18AWG).
        2x Molex cable (18AWG)
        4-pin 12v motherboard cable (20AWG)
        1x Molux plus 2x SATA cable (20AWG)
        If it doesn't seem like a lot, then just know that it was all what i had lying around at the time, and i could add more if needed, but for right now, it should do.
        I'm not a expert, I'm just doing my best.
        • RukyCon
          A Fake Rubycon
          • Jan 2017
          • 816
          Forgot to add one last thing, I forgot where i had put one of the two fans that were in this PSU, so i substituted it with one of these Sanyo Denki fans i had gotten from a surplus store a long time ago.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            #3185
            If I were him I'd replace the fuse as well. No way in hell that tiny fuse is gonna do anywhere past 200W or so without going nuclear.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              Ultra ULT-500P
              Well, since my last project isn't working out how i hoped it would, I thought i would take a look at another of my PSUs that needs some repairs. In this case, an Ultra V-Series 500w PSU i found for $10 at a Savers thrift store.
              Now unlike every other used PSU i find, this one still had its retail box despite being used, and came with just about everything minus the mains power cable.
              Now another thing about this PSU was, the case had been opened up, and the fan was loose inside the box, but it did not appear the last owner had done anything to the board itself, because if they had, then this thing probably wouldn't have been worth trying to repair.
              Anyway, here is the PSU label:
              Not much to say here, but judging by the UL number, this PSU appears to have been made by Wintech.
              Board Overview:
              So a few things are clearly off here, the most obvious thing being the secondary caps are nearly all dead, but also, it appears something had been spilled onto the board, and had been allowed to pool up around the lower-right corner of the board. The heatsinks appear to be decently sized. And on the bottom of the board, there is a model number on it of WIN-450WP. Now it seems like this PSU board may have originally been designed for a 450w PSU, so it seems a bit sketchy to push the board to 500w, but that might just be me.
              Primary Side:
              So for input filtering, we have three .22uf X2 capacitors split between the main PS board and a separate filtering board, two common mode chokes, and two sets of 2 4.7nf Y2 capacitors. The rectifier is a RS805 (8A, 600V), and the smoothing capacitors are a pair of JEE 820uf 200v caps, both of which test at roughly 760uf. The main switchers are a pair of 2SC3320 transistors in what looks like a dual-foward configuration, and the 5VS/Aux switcher is a C3866 transistor in a two-transistor configuration. The main transformer is roughly 40mm x 40mm.
              Secondary Side:
              The filtering for each rail is as follows:
              5VSB - SB540 (5A, 40v) Schottky Diode, 2x Canicon 680uf 16v with a PI coil between them.
              12V - 2x F12C20C (12A, 20V) Fast Recovery Rectifiers, Su'scon SD 1000uf 16v, PI coil (4mm Core, 10 turns, 14AWG), and a Su'scon SD 2200uf 16v.
              5V - S40D45C (40A, 45V) Schottky Rectifier, Canicon 3300uf 10V, PI Coil (5mm Core, 7 turns, 14AWG), JEE 2200uf 10V.
              3.3V - SBL3040PT (30A, 40V) Schottky Rectifier, Canicon 3300uf 10v, PI Coil (4mm Core, 10 turns, 14AWG), JEE 2200uf 10v.
              -12V - FR154?, PI Coil, Canicon 680uf 16v.
              -5V - 2x FR154?, PI Coil, Canicon 680uf, 16v.
              Of all of the main secondary capacitors, only three appear to have not failed yet, those being the Canicon 680uf 16v cap on the -5V rail, and the two Su'scon caps on the 12v rail, all of the smaller capacitors (except for one) are all Canicon, and a few appear to have been baked, judging by the fact their sleeves have turned a yellowish brown, though next to a couple of these baked capacitors is the only non-Canicon tiny capacitor (Su'scon SK 0.22uf 50V), and its sleeve is still bright yellow, which might say that the Canicon sleeves are just crap (just like the capacitors )
              The controller chip is a KA7500C PWM IC, paired with a SG6510D1 supervisor chip.
              And lastly, the fan.
              Not much to say about this fan, other than the fact it's totally seized up, but i didn't notice that until i was trying to test the PSU and noticed that the fan wouldn't move, despite getting the PSU to turn on, the PSU itself was also very whiny when i powered it up, and that was with no load on the output, i assume the failed capacitors have something to do with it, but i guess i'll have to recap it and see.
              Also, this happens to be my 666th post O-o.
              • PeteS in CA
                • Aug 2005
                • 3582
                • USA, Unsure of Planet
                #3187
                How often have I posted this: those heatsinks do look reasonably substantial. The main transformer looks reasonable as well. 820uF for the input lytics seems a bit marginal for 500W (more OK for 400W-450W), and I don't love that they are 85C rated. ASSuming they current-share perfectly, those paralleled 12V rectifiers are not good for 28A ... even 16A rectifiers paralleled would be marginal for 28A. In contrast and oddly, the 5V and 3.3V rectifiers are reasonable for the rated current. Another oddity is pairing a -52 material output inductor with a TL494 PWM and bipolar transistor switches (both of which keep the switch frequency low, probably around 25-35 KHz).
                But for the under-rated 12V rectifiers, that looks to be a fairly decent PSU crapped up by low quality capacitors. And it did last for 10-16 years ("06" date code on one of the input lytics). Given that vintage, replacing the crap caps on the secondary side with PWs or LXZs should yield a pretty decent 400W-450W that could deliver 500W peak power for more than a femtosecond or two.
                PeteS in CA
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  #3188
                  Had this PSU planned for a KT133A build with a recapped ECS K7VZA rev 3, and a 1100MHz Duron (wanted a ceramic chip specifically, and the only ceramic Athlon I had is dead as a doornail ) and figured I should post it here since I don't think it looks to shabby.
                  For those curious:
                  - transformers are from an discarded Allied unit (it's one of those PSUs I've done over the years) and are their real advertised sizes (ERL35, and 2x EEL-19 from what it reads on their top sides)
                  - BJTs are 2x TT2194, as well as a standard CET CEP2N6 FET for 5vSB.
                  - secondary sillicon: 2x SBL3040PT for 3.3v and 5v, STPS20S100CT for 12v.
                  - Sanyo WG 1500uF 6.3v for 5vSB.
                  - fan is a thermally controlled Xinruilian LP
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • PeteS in CA
                    • Aug 2005
                    • 3582
                    #3189
                    400W? No. The heatsinks might be good for 300W, but that main transformer and 470uF input caps put the practical continuous power in the 250W range, IMO.
                    PeteS in CA
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      #3190
                      That's a 35 sized transformer though (not the puny 33 that most Deer/L&C usually ship with), so apart from the main caps, I'd put it at 280W continuous and 300 peak. Maybe 300 continuous if I could bump up the main caps (and if I had an ESR meter to check if some 680uF primaries I found would suit it)
                      But considering that the machine itself barely hits 250W probably (1x HDD, 1x DVD drive, FX5200 AGP, LAN, TV Tuner and a 1.6GHz Duron), I don't really think I have to tinker with it further than installing it back in the case and using it.
                      And 400W... yeah, that's a no from me too.
                      300-350W with upgraded primaries, since the sillicon seems up to it, and I trust the 35 size transformer to do so too.
                      (double checked and it indeed IS a real 35 sized trafo, unlike Allied's stupid practice of masking a rounded 28 sized trafo as 35 size - yes, some of the newer units they were making (some Rosewills being good examples) had a rounded 28 transformer passing as 35. Only upon noticing there was too much free space between the main transformer and the one next to it, (and comparing to a real 35 I have from another Deer, marked LT535-something + ERL-35ASH) I found out it's a 28. Talk about saving a penny, as the sillicon and othrr parts were way overkill for that 28.)
                      Anyways, I might post up a Sun Pro/Leadman next. Doesn't look too bad to me IMO, but the driving transformers are small compared to the main transformer (which for whatever reason, Sun Pro decided to slap an actual EI-40 transformer out of the blue ). Gotta see if it passes the startup blow test, though last time I took it out of the case, the only things wrong with it were bulging 5vsB and secondary caps, nothing else looked shorted.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1866
                        #3191
                        Welp, the Sun Pro got scrapped. 5vSB had an issue where it would constantly tick, despite being recapped.
                        Instead, I've taken my time to open up an unit I wanted to work on for quite some time. Rhis is a "HKC" SZ-430PDR unit.
                        I'd guesstimate 300W continuous and 350 peak? Main switchers are D304X, main transformer is ERL35 and the drivers look beefy enough. A recap is in order of course (I have saved some Rubycon and Panasonics) although the primaries will stay (IIRC I got those out of a beefy Rasurbo unit that had bigger issues with the secondary side)
                        Also has PFC coil (and it's real!) and a Shenzen Xin Wang Electronic fan (which I'll probably replace with a Young Lin/ Recom branded fan). Mains filtering was redone by me (unsurprising since the original positions are done by a bunch of monkeys) and the 2200uF Jun Fu on the secondary is also my work (the only 2200uF 16v cap I had on my hands..) but otherwise the rest is as bone stock as possible (except the fan which I had it from a scrapped RPC unit that was so gutless I wouldn't have trusted it near anything ATX.)
                        Main rig:
                        Gigabyte B75M-D3H
                        16GB DDR3-1600
                        Delux MG760 case
                        • leotron
                          • Apr 2019
                          • 29
                          • Offworld
                          #3192
                          hello badcaps i was selling for a scrap a few psu and noticed one that was heavy, hmm i said, i opened up and i found a surprise, looks like a second brand from a psu manufacturer maybe? what do you think?
                          • pc7fan
                            • Aug 2013
                            • 52
                            Looks like a filled up Deer (full input filter and nothing seems to be omitted). If you fully recap this L&C/Deer (upgrade the primary caps to at least 470u for 250W if you have any laying around). Even if this has a 35 size transformer, the somewhat scrawny heatsinks themselves, the classic half-bridge design, and the single 80mm fan will limit this supply at 250W continuous.
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1866
                              #3194
                              200W.
                              I'll say this as long as necessary - don't be fooled about the ERL-35-2005 labeling and the transformer shape - that is a rounded ERL-28 transformer which Deer uses to fool people into thinking they have an actual 35 sized transformer. If you have trained eyes, you'll easily notice the rather big free space inbetween the main transformer and the one close to it. An actual 35 size trafo WILL FILL that space.
                              Also it doesn't surprise me it's Allied who does that. They've been doing this absolute BS of using rounded 28 size trafos for almost as long as I could encounter. The only Allieds I've seen that actually had real 35 sized transformers were usually either Modecom FEEL-III units and some of Thermaltake's Litepower units that were subcontracted to Solytech (not all Litepowers were Deers, by the way.)
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                              • leotron
                                • Apr 2019
                                • 29
                                • Offworld
                                #3195
                                Thanks for the answers, so its a realiable PSU so long 200~250w power consumption? Or it it's better to buy a generic 500w psu anyways? I was very curious because the main filter, and the other horizontal circuit, also kinda heavy.
                                thx for the patience
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1866
                                  #3196
                                  It will be good for 200W continuous. Again, that's a 28 size transformer you have there, not a 35 and not a 33 either. I've actually desoldered one of those fake 35 labeled size 28 trafos from an Allied rated a bit higher than yours by quite a lot ("400W", my ass!) and it did indeed read "ERL-28-2005 XF". Not sure what the XF meant.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #3197
                                    Delta Electronics DPS-180AB-20 A [PCB DPS-180AP-20]
                                    It's been a while since I posted one of these, hasn't it.?
                                    I guess I will start with something mundane to get back in shape for posting more.
                                    For today's consideration is a Delta Electronics DPS-180AB-20 A, rev. 0B small form factor PSU from an HP Slimline 450-120KL SFF desktop. HP P/N is listed as 793073-001, if that's of any importance to anyone.
                                    Case pictures shown below… as you can see, there's not much to this PSU. All it has is a 24-pin ATX connector, a 4-pin 12V CPU connector, one regular SATA power connector, and one mini-SATA 5V-only power connector for the optical drive in the system. All wires are 20 AWG, except the 3.3V rail + signal wires on the ATX connector and the mini-SATA 5V-only, – these are 24 AWG.
                                    Next, let's look at the label. The PSU is only rated for 180 Watts of power, which isn't a whole lot. 5V and 3.3V rail are rated quite low at 10A and 7A respectively… and 70 Watts total combined. But note the rating for the 12V rail: it's stated to do up to 15 Amps, which is 180 Watts alone. This suggests the PSU can output all of its rated power on the 12V rail… so definitely not a “retro PC” unit. It's also 80 Plus Bronze and full-range input (meaning it has APFC.)
                                    Anyways, let's have a look inside.
                                    Seems almost gutless for 180 Watts… but in reality, it's just a modern and efficient PSU, so it doesn't need very big components for such output power. Also, it's a Delta after all. So I doubt anything on the label would be a lie. PCB model says DPS-180AP-20.
                                    In the above picture, the lower-right quadrant contains the input filtering (2x CM chokes, 1x AC wires ring choke, 1x 0.1 uF X2 cap, 1x 0.22 X2 cap, 4x 1.0 nF Y2 caps, and 2x 1.5 nF Y2 caps), APFC booster coil (note blue HF core material), and 5VSB supply.
                                    In the upper-right quadrant is the bridge rectifier (GBU408), main filter cap (450V, 120 uF), and main transformer (size 28). Here's a better picture of these:
                                    Going back to the picture before the last one again… left side of the PSU board has, from top to bottom: secondary heatsink with rectifiers, output toroid filter, and output caps. Here are two alternate shots:
                                    Next, an up-close picture of the secondary side heatsink + rectifiers (2x STPS20L60CT in parallel for 12V rail and 1x STPS40L45CT for the 5V rail):
                                    And here is the output side:
                                    12V rail is filtered with 2x 2200 uF caps (without a PI coil in between them) and 5V rail with 1x 1500 uF + 1x 1000 uF caps (with a 6.5-turn, 3mm core PI coil). The 3.3V rail is a little more special – it is DC-DC –generated from the 12V rail. On the input, it has a CapXon PL series 16V 470 uF cap connected to the 12V rail via. a PI coil (same type as the 5V rail one.) On the output, it has 1x 1000 uF + 1x 1500 uF caps. The 5VSB has 1x 2200 uF and 1x 680 uF caps with a PI coil in between.
                                    By the way, note again the blue core of the output toroid. Not sure what it is, but I guess the standard -26 and -52 material cores from Micrometals are not a thing anymore. Only the black core toroid (L303) for the 3.3V DC-DC supply is something I know – Micrometals -45 (all black.)
                                    On the bottom is a daughterboard that runs between the primary and secondary, and contains all of the control ICs. PWM + APFC IC is CM6802 and the supervisor is an Infinno iN1T406-ddg (?). 5VSB is generated from a TNY286pg.
                                    Here is also a picture of the solder-side of the PSU PCB:
                                    This one shows the 3.3V rail DC-DC single-phase PWM controller is an ST L6726A.
                                    And finally, a picture of the fan – a 50 mm Yate Loon D50SH-12C, rated for 0.27 Amps at 12V.
                                    That concludes it all for this PSU.
                                    I did a partial recap on it, just to make it a little more reliable. The HP Slimline 450-120KL it belongs to is for my mother to use as a desktop PC at home. So it has to be a little more trouble-free, if that's possible.
                                    Here's how the recap went:
                                    5VSB: 1x Ltec LZG 10V, 2200 uF --> 1x UCC KY 10V, 2200 uF
                                    3.3V: 1x Ltec LZG 10V, 1000 uF --> 1x Rubycon ZLQ 6.3V, 1200 uF
                                    As you may have noticed, I don't trust Ltec too much. In Delta PSUs where they're used interchangeably with Taicon, I found Taicon rarely failed. Ltec and CapXon – almost always.
                                    Anyways, everything else was left the same as it was. When I get more proper caps, I'll do the rest. Probably very high on that list is the primary cap (Ltec TY, 450V, 120 uF) since I'm sure the APFC stresses it a good amount. I have some Nichicon PT with the same voltage and capacitance from bad Nichicon-made PS3 PSUs. It would be a good fit, I think. Since there is space in there, I'll probably even try jamming in a parallel polypropylene cap as well.
                                    Lastly, a list of detailed component summary shown below:
                                    Primary Side:
                                    * Input Filtering: 2x CM chokes, 1x AC wires ring choke, 1x 0.1 uF + 1x 0.22 uF X2-class caps, 4x 1.0 nF + 2x 1.5 nF Y2-class caps.
                                    * Input protection: T5A250V fuse, 2x spark gaps on CM choke sides
                                    * GBU408 bridge rectifier,
                                    * 1 uF 450V film cap before APFC stage
                                    * main filter cap: 1x Ltec TY, 450V, 120 uF, 18x42 mm, 105°C
                                    * 5VSB startup cap: 1x Taicon PW, 50V, 220 uF, 8x20 mm
                                    * APFC silicon: 1x 13N60M2 MOSFETs (TO-220FP) + 1x STTH8R06fp diode (TO-220FP)
                                    * main PS (2-transistor forward config): 2x K10A60dr MOSFETs (TO-220FP)
                                    * EEL/ERL 28 main transformer + EE19 transformer for 5VSB
                                    ICs:
                                    * APFC + main PS PWM: CM6802
                                    * supervisor: Infinno iN1T406-ddg (?)
                                    * 5VSB off-line PWM-FET: TNY286pg
                                    * 3.3V rail DC-DC PWM (single phase) controller: ST L6726A
                                    Secondary Side:
                                    * 5VSB
                                    *** 1x Ltec LZG, 10V, 2200 uF, 10x20 mm before PI coil
                                    *** 1x Taicon PW, 10V, 680 uF, 8 x 15 mm after PI coil
                                    *** PI coil: 10-turn, 3 mm core, 20-22 AWG wire
                                    *** 3-5A (?) schottky diode for rectification
                                    * 12V Rail
                                    *** 2x United Chemicon KZE, 16V, 2200 uF, 10x20 mm, no PI coil
                                    *** 2x STPS20L60ct (TO-220) schottky rectifiers in parallel
                                    * 5V Rail
                                    *** 1x Taicon HH, 10V, 1500 uF, 10x16 mm before PI coil
                                    *** 1x Ltec LZG, 10V, 1000 uF, 8x20 mm after PI coil
                                    *** PI coil: 6.5-turns, 3 mm core, 18 AWG wire
                                    *** 1x STPS40L45ct (TO-220) schottky rectifier
                                    * 3.3V Rail (DC-DC regulated from 12V rail)
                                    *** 1x CapXon PL, 16V, 470 uF, 10 mm dia., connected to 12V rail via PI coil with 6.5-turns, 3 mm core, 18 AWG wire
                                    *** 1x FDD8896 MOSFET (TO-252) on high-side and 1x D514 GA5C2C MOSFET (TO-252) on low-side
                                    *** 1x Ltec LZG, 10V, 1000 uF, 8x20 mm + 1x Taicon HH, 10V, 1500 uF, 8x20 mm
                                    *** Micrometals -45 material toroid
                                    * -12V Rail
                                    NONE – this PSU does not have a -12V rail.
                                    Wiring:
                                    * 600V, 20 AWG input wiring, except ground (18 AWG)
                                    * 300V, 20 AWG output wiring, except 3.3V and signal wires on ATX connector + ODD SATA 5V-only connector (24 AWG)
                                    * Output connectors: 24-pin ATX, 4-pin 12V CPU, 1x SATA, 1x mini-SATA 5V-only (for ODDs).
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #3198
                                      Re: Delta Electronics DPS-180AB-20 A [PCB DPS-180AP-20]
                                      * -12V Rail
                                      Cool, so it's not actually a ATX compliant power supply!
                                      Makes sense since -12v is only used for RS232 and the PCI slots in general, neither of is present in this PC...
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3582
                                        #3199
                                        What's with output rectifiers' current ratings being higher that the safety label current ratings for the 5V and 12V outputs! [/sarc] More seriously, my guess would be for the lower forward voltage, i.e. efficiency and lower heat dissipation.
                                        I notice the one 12V rectifier that is fully visible has ferrite beads on the leads. These may take care of the spike noise the ferrite rod inductors filter out.
                                        PeteS in CA
                                        • leotron
                                          • Apr 2019
                                          • 29
                                          • Offworld
                                          #3200
                                          SEGOTEP , i kid you not , "super battleship f7 500w" a gift from a friend , read somewhere that seasonic build this one, doesn't have anything on the backside only green
                                          kind regards from south america
