A lot of late Pentium 4 -era PSUs were built like this - i.e. enough Amps on the 3.3V and 5V rail to still work with older 5V-heavy systems, but also enough Amps on the 12V rail for more modern PCs (typically 14-18 Amps for that time).
The 250 Watt HiPro "tanks" from that era are my favorite. You can load them straight to their maximum 14-16 Amp limit on the 12V rail, and they won't say a peep. Not to mention the voltage regulation remains solid. Hence, they can still be used in a modern PC today - albeit one without a high-power graphics card. And the lack of SATA power connectors can be a bit of a bummer unless you have lots of Molex->SATA power adapters around.
 Half of the computer problems is caused by bad contacts
 ) PWM controller, so that means it should be fairly straight-forward to fix. Unlike cheaper Deer, L&C, and Allied units, this one has good output wiring and decent selection of output connectors: 1x 24-pin ATX (of course), 1x 4-pin 12V CPU, 1x 8-pin 12V CPU, 2x 6-pin PCI-E power (but coming from the same strand of wires
 ) PWM controller, so that means it should be fairly straight-forward to fix. Unlike cheaper Deer, L&C, and Allied units, this one has good output wiring and decent selection of output connectors: 1x 24-pin ATX (of course), 1x 4-pin 12V CPU, 1x 8-pin 12V CPU, 2x 6-pin PCI-E power (but coming from the same strand of wires  ), 3x Molex, 4x SATA power, and 1x floppy. All output wires are rated 18 AWG, 300V, and with a valid UL number (i.e. not some cheap no-name wires). So for all of these reasons, I thought that maybe this PSU deserved a second chance. After all, it looked like it blew because it was overloaded. While rated for 500 Watts max, we all know that Deer/Allied/L&C labels should rarely be trusted. Speaking of which, here is that:
 ), 3x Molex, 4x SATA power, and 1x floppy. All output wires are rated 18 AWG, 300V, and with a valid UL number (i.e. not some cheap no-name wires). So for all of these reasons, I thought that maybe this PSU deserved a second chance. After all, it looked like it blew because it was overloaded. While rated for 500 Watts max, we all know that Deer/Allied/L&C labels should rarely be trusted. Speaking of which, here is that: But we shall see about that (I am very doubtful, to say the least). Either way, I personally think the system it was powering was too much for it (it would have been okay if it was a true 500 Watt PSU, that’s for sure).
  At least be consistent with the design. The 12V rectifier does have a 40 Amp -rated part, though.
 At least be consistent with the design. The 12V rectifier does have a 40 Amp -rated part, though. (~1 Watt of power wasted as heat!)
 nVidia RTX 3080 TI, Corsair RM750I.
