How much does it cost?
 And needless to say, it took me less than 3 seconds of viewing the second shot before I figured who made it. Also, the output Fuhjyyu caps were another big giveaway. But I won't spoil the fun here and let other folks try to figure out who made it.
 ) . It is interesting to note here that while Q102 and Q106 are in parallel, they each have their own gate driver circuits - hence why I labeled them on the schematic above as "A1" and "A2". Perhaps that's why Q106 didn't die.
 : Channel Well Technology (CWT), as obviously written on all of the transformers.
 Let’s post another classic reliable workhorse PSU: an Astec AA21470. I doubt many of you have seen this one, as it’s not a unit commonly found in regular PCs. It’s actually the PSU that came with my dumpster-picked HP NetServer E-800 some years ago and still is its PSU. I almost trashed the thing after I found the PC had roaches in it before (but not when I got it). Eventually decided to clean everything after giving the whole PC a RAID treatment – no, not the kind with multiple hard drives. Like our fellow member Junk Parts (RIP) used to say, the only RAID I’ve used came from a spray can.
  Hopefully this might clue you in on the build quality, though.
 - great for those ambiguous-Live Schuko plugs.
 You can tell this PSU was made at a time when lower-ESR PSU-grade caps like Chemicon KY, Nichicon HE, and Rubycon ZL weren’t available or popular just yet, because most of those Nichicon PM’s have a much greater voltage rating than needed – a move probably done to decrease the ESR of the caps while maintaining a certain capacity.
						 Means the PSU will do 0.75A sustained and probably 1 Amps peak. Same goes for the 6A rating on the 12V rail: even with two 10k HDDs, it never dropped out of spec, despite the high current draw at start-up (over 5A with all drives).
 Means the PSU will do 0.75A sustained and probably 1 Amps peak. Same goes for the 6A rating on the 12V rail: even with two 10k HDDs, it never dropped out of spec, despite the high current draw at start-up (over 5A with all drives).  I don't recall what the hold up time is when the power goes out with the PC turned on (I rarely run that PC, so I actually don't recall the power ever going out when the PC was on). It's also amusing that this 256W PSU has more primary capacity than my Corsair CX750M.
						 nVidia RTX 3080 TI, Corsair RM750I.
