The Core 2 Duo should be no problem, but the 8800 GTX is a power hog at 170 Watts, if I remember correctly. So with a standard 65W C2D, you're looking at around 230 Watts max from the 12V rail, which may be a bit high for it without a more moderate load on the 5V rail.
The secondary-side caps are under more stress in this unit, so I suggest replacing those instead. The primary caps should be okay - even crap brands live a long time when there is no APFC circuit involved.
Well, technically since this is a half-bridge design, you could pull the max. current that the output rectifiers are rated for. Of course that may not be possible only due to cross-loading. So this is where experimentation would be needed to determine that. But your ratings are probably not too far what the PSU can do if cross-loaded.
 Half of the computer problems is caused by bad contacts
						 Prefer to find out, if that's possible.
 We talking miliseconds here, you won't see that.
