This is a sticky topic.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    #2741
    Here's a surprising one. Modem PSU, 10v, one and a half amps. Its a bodge-job replacement for a real POS. https://www.badcaps.net/forum/showpo...postcount=1326
    Case shot.
    Not inspiring....
    Board topside.
    This is promising! Good insulation, no Brown Gorilla Snot, plenty of filtering. Looks like the board has provisions for another rail. Actual safety rated caps.
    Topside-BottomWise!
    No bad solder. Plenty of isolation. Not bad.
    And the Money-Shot!
    Decent Chemi-Con caps.
    Secondary Filter: 1000uF, 16v.
    BootStrap: 47uF, 50v.
    Primary Filter: ? It was wrapped in yellow tape... Very large though.
    Goontrons rating: B for beautiful. Needs more heat sink, and the primary cap is resting on some large resistors. More than satisfactory for its intended use. Looks Delta OEM.
    Follow the white rabbit.
    • Behemot
      • 4845
      • CZ
      #2742
      I'd guesstimate that primary cap around 47 uF/400 V.
        master hoarder
        • May 2008
        • 12175
        #2743
        For a 1.5A adapter, the heatsinks look plentiful.
        With those caps, I would have argued you give it an "A"... but it looks like it is a 2-transistor design. So in that case, "B" seems appropriate, as 2-transistor designs are not very efficient. The small cap on the primary may also be a "critical" cap... but again, I see nothing but good caps in this adapter, so that shouldn't be a problem.
        A world of a difference compared to the gutless adapter you posted in the other thread.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          33-47u, 400V? Maybe 68u/400V.
          Actually, since it's rated only up to 120V AC, the cap could be an 82u/200V unit.
          Agree! Looks rather non-RoHS-ey for 2011.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            #2745
            ^ That was my thought. 82uF/200v.
            I gave it a nice dose of 60/40 before i welded the case back together.
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              Here we are with an ebay 12V 2A power supply.
              Label.
              Not looking promising.
              Top side.
              Not bad IMO. I think they did a good job with it.
              Has a nice Y-class capacitor and a PI coil on the output side. I'd take some points off for the cheap glue. The input capacitor is not original to this power supply and no, i did not replace it.
              The big transistor is a STD13005 and the smaller looking one is a AZ431.
              And bonus points to whoever noticed that the input capacitor is bulging.
              Bottom side.
              Looks like they did a decent job on isolation from the input.
              The hot glue was added by me to stop one of the solder pads from being ripped up from the PCB.
              Solder seems to be good.
              Cap shot.
              Input: 10uf 400v
              Bootstap: 220uf 16v
              Output: 680uf 16v
              Brands: BERYL, Ltec.
              Overall i'd say this thing is not bad for the price.
              I'm not a expert, I'm just doing my best.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Vaguely familiar to the 2-transistor 5VSB circuitry modified to 12V, compacted into a wall wart?
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  The power supply is OEMed by unifive. Some of there products seem to be UL listed when looking on there website.
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    #2749
                    Label.
                    Top side.
                    IC1 is an optocoupler, and IC2 is in a TO-92 package. I'm guessing IC2 is a TL431 (or clone), and the output is regulated. The MJE13005 clone transistor - bipolar, not a MOSFET - should be plenty beefy for 24W. As long as its heatsink and the traces "heatsinking" the output rectifier are adequate, it looks reasonably solid.
                    PeteS in CA
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      ...I'm guessing IC2 is a TL431 (or clone)...
                      IC2 is a AZ431.
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        I may all a new wires to the output because the ones that are there are thin and are soldered across the output capacitor making the PI coil useless unlike the old wires.
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          #2752
                          IC2 is a AZ431.
                          That self-oscillating discontinuous flyback circuit using a bipolar transistor as the switch and a **431 as an error amplifier has been around for nearly 40 years. It's not super high efficiency, but the low component count generally, and the lack of a large separate output inductor make it an attractive choice for small adapters.
                          PeteS in CA
                          • RukyCon
                            A Fake Rubycon
                            • Jan 2017
                            • 816
                            Interesting that the design has been around for that long.
                            When it comes down to adapters, i don't really care too much about the efficiency. [Unless it draws many times more power than it outputs.]
                            And IIRC the output inductor is usually referred to as a 'PI coil'.
                            • PeteS in CA
                              • Aug 2005
                              • 3581
                              #2754
                              Here's a second generation single output example from Boschert, dated 1983:
                              Here's a first generation multiple output example from Boschert, dated 1982:
                              The latter was in production when I started at Boschert in 1980.
                              Those little inductors on the outputs are there primarily to reduce spike and ringing noise, not to filter switch frequency ripple.
                              Boschert's second generation discontinuous flybacks were part of a fairly large scale effort to get the pricing for their low and medium power products under $1 per watt. I don't think the first-gen OL25 was replaced, but I know second-gen XL standard products ranged from that 30W single output to a model that could do 165W convection cooled or 185W with forced air cooling. The guy who did all those designs - one guy! - was a genius.
                              By way of contrast in terms of pricing, in 2000 Delta Products was charging Compaq, Dell, and Apple $13-$16 for 200W-250W power supplies.
                              PeteS in CA
                              • RukyCon
                                A Fake Rubycon
                                • Jan 2017
                                • 816
                                I wanted to see how the newer 12V 2A power supply's on ebay looked and all of the newer ones are crap, Oh well.
                                I may make a post about the newer crappy ones if anyone's interested.
                                • kevin!
                                  recapping PCB.
                                  • Jul 2013
                                  • 195
                                  • España
                                  #2756
                                  I found this source on a Pentium 3 that I found at a recycling point.
                                  The source seems very decent, except for the primary capacitors that are garbage, which are SC, but the secondary ones are Nicon, for me Nicon is good brand, I have seen sources with Nicon with 40.000hy and they were in very good condition, although if it does missing the change too.
                                  The rest of the source, I think it's 500W, weighs a lot, and the PFC has a real winding inside, it's not the typical one that put fake PFCs.
                                  I do not have data of the switch, nor the transistor, it is very complicated access, and I do not want to break, because I will use it, I will change the 2 primary capacitors.
                                  What opinates, is it good? I see her quite well.
                                  Gaming pc:
                                  nVidia RTX 3080 TI, Corsair RM750I.
                                  Workshop PC:
                                  Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                                  Server:
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #2757
                                    I have my doubts that PSU will do 500 Watts. Maybe around 400-450 Watts at most. As well-built as it looks, there are still several things I don't like about it:
                                    1. The output filter caps seem way too small. This PSUs appears old and probably has a low switching frequency. So if anything, those output caps need to be much bigger to properly filter 500 Watts worth of power.
                                    2. No combined power rating for the 12V rail or the 3.3V and 5V rails is dodgy.
                                    3. Main transformer is labeled ERL35. To me it looks like it's close to size 39, but maybe the picture is deceiving. In any case, even with an ERL39, you won't be able to do 500 Watts - not with a slow-switching half-bridge topology. Which leads me to my next point.
                                    4. This PSU uses half-bridge topology, most likely with two BJTs on the primary. Such an ancient topology is not very efficient - you'd be lucky if it peaks close to 80%. Most are less than 75%. So with that kind of [in]efficiency, 500 Watts wouldn't really be possible with that primary heatsink.
                                    All that said, this still appears to be a very decent PSU. With good brand caps, it should last a very long time, especially since it has a very simple design with passive PFC. Thus, I definitely suggest recapping it and keeping it.
                                    It may not do too well in a very 12V-hungry modern PC, but it should be okay for a mid-range PC. And because it has a strong 5V rail, it would also be suitable for running an old 5V-hungry rig, like a top-of-the-line Athlon XP PC with a 5V-heavy GPU (Radeon 9700/9800).
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #2758
                                      Xilence units are usually half-decent, not sure about this old series but they usually deliver the power. Though at least the older ones were using all those "peak power" crap tricks, just check my review of the R6: https://www.hardwareinsights.com/xil...p400r6-review/
                                      • kevin!
                                        recapping PCB.
                                        • Jul 2013
                                        • 195
                                        • España
                                        #2759
                                        All that said, this still appears to be a very decent PSU. With good brand caps, it should last a very long time, especially since it has a very simple design with passive PFC. Thus, I definitely suggest recapping it and keeping it. If it does not reach 500W, nothing happens.
                                        Thank you very much ,
                                        I think the same, the capacitors look very small, in addition being SC will not have half of its capacity of what it marks on its label.
                                        Well, I'm not going to ask too much, I'll have it for a gtx8800 with a core 2 duo.
                                        I have been looking for information about the manufacturer of this source, and it is the same one that manufactures for NOX. (Huizhou Xin Hui Yuan Tech)
                                        Nothing happens if it does not reach 75% efficiency, at least if it works, and has good protection, I have enough.
                                        You see, I've seen them in many sources putting peak for 30 seconds for example.
                                        My PSU I think will be the same.
                                        I will recap the primary capacitors and give them a second life.
                                        Gaming pc:
                                        Workshop PC:
                                        Server:
                                        • Stefan Payne
                                          • 1267
                                          That's a Pre Listan era Xilence. Maybe they were too good and that's the reason Xilence went under (and was boght by Listan).
                                          Though there are way way worse...
                                          I'd treat that like a 250-300W unit with max 20A on +5V/3,3V and 15-18A on +12V combined.
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
