Kada 852d+ need schematic
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3609
    • slovakia
    Hello have this hotair and soldering iron station that is not work.
    have anybody schematic for it?
    • 31090
    Re: Kada 852d+ need schematic
    what is bad, the iron or the air?
    those combo units usually have a different board for each side.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3609
      • slovakia
      i allready modified this station wirh my own regulators to use only hot air because its iron is total crap
      but u know i want to learn so i want to repair this board
      i dont measure anything, because i want to first find schematic, if it is awailable
      on picture "SNIM" is marked sensors connectors and "ZHAV" is marked heating elements connectors
        • 31090
        if it's similar to the 858d then start with these.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3609
          • slovakia
          totally different, but its just one layer board so i can easy trace
          make some measurement and give feedback
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3609
            • slovakia
            i realize there is triac missing so i replace it, but now i must measure resistance of temp sensor in heatgun to attach some resistor for testing
            do u think i can replace BTA08-600C with BT139-800 ?
            BTA08 - is 8A and trigger current 5-50mA
            BT139 - is 16A but trigger current is 5-10mA which im afraid of
              • 31090
              139 is better.
              btw, most soldering gear sensors are thermocouples, not resistors.
              they look like a short-circuit and generate a variable voltage that rises with temperature.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3609
                • slovakia
                Originally posted by stj
                139 is better.
                damn thats bad. there are voltages with temps marked on board but dont know if it is for hotair or iron
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3609
                  • slovakia
                  measure hotair and there are resistive sensor
                  so my test resistor would be 30-40ohm
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3609
                    • slovakia
                    Have anybody this station?
                    can u please photo its connectors? there are many same connectors and i dont know what goes where. so please upload me photo
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3609
                      • slovakia
                      and please one photo of secondary windings of transformer, because i found one wire disconnected
                        • 31090
                        the transformer is usually 24v and 9v secondary's
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3609
                          • slovakia
                          i think i have 24V and 10V/its marked on board/, but i have there three windings.
                          one 24V i think because of thicker wire/iron power/ and two with thinner wire connected in the middle - see picture. dont know why it is the second thinner winding with loose wire
                          there is only 3 connection pads so maybe it is two 5V winding connected together to give 10V
                          that 1st picture have bad marks/yellow/ because 2x5V winding come in mind later
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3609
                            • slovakia
                            now i really dont know what to think about this chinese crap station
                            look at the picture with measurements
                              • 31090
                              15v to rectify and drop to 12v/5v for the logic, 24vac for the iron.
                              2v probably not used here - but handy to drive VFD heaters!
                              is that original?? every station iv seen inside had wires coming out - no solder tabs.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3609
                                • slovakia
                                must open station and cut whole cables to get out connectors and find out what is going where.
                                i connect 10V to connector marked 1/10V which i think is for logic and 24V to connector marked 24V for iron heater
                                dont know why this chinas engineer marked +/- on resistive sensor, and 24V IN/GND when it is AC voltage
                                and i forgot that this station dont have main switch so transformer is still working
                                looks like everything is working but dont have voltage on heating for hotair heater.
                                maybe it is because of my sensor replaced by resistorand test load is bulb, so i connect it right to the station.
                                but i will test it at the morning
                                  • 31090
                                  what are you doing???
                                  the soldering iron is 24v,
                                  the hot air is usually mains powered.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3609
                                    • slovakia
                                    that's exactly how i connected it. did u read something else from my post?
                                    looks like it is working. compressor is regulated, and sensor circuit works because when i turn of heater, compessor still works until sensor is cooled.
                                    But air heater is still on. i think that is something bad in regulation of it, because driver/MOC3023/ have still 1.16V between pins 1 and 2
                                      • 31090
                                      on my old one (no microcontroller) there was an opamp.
                                      • ktmmotocross
                                        Boardkiller
                                        • Feb 2014
                                        • 3609
                                        • slovakia
                                        and looks like we have a winner
                                        i take MOC3023 from iron heater and solder it to hotair heater and looks like its working.
                                        now i put everything to station and give a final test
                                        • liquidzorch
                                          862D+ solder station iron out of control when fan on
                                          by liquidzorch
                                          Hello.
                                          I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                                          First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                                          06-09-2022, 08:49 PM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • atunguyd
                                          Acer x163w Monitor PSU schematic
                                          by atunguyd
                                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                          03-05-2025, 02:08 PM
                                        • Thetechdude
                                          MSI Ventus RTX 4080 16G Broadview schematic needed
                                          by Thetechdude
                                          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                          Thanks.
                                          07-15-2025, 11:15 AM
                                        • ianpoultonknights
                                          Zenbook Flip 15 UX562AI schematic
                                          by ianpoultonknights
                                          Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                          06-26-2025, 02:41 PM
