Delta DPSN-525AP Power Supply Repair
  • jayjr1105
    • 281
    Hi all, this power supply is for a Cisco POE ethernet switch. It's 525watts and puts out two rails, 50v for the POE and I think 12v for the main logic board. When powered on, the 50V rail seems good but I get less than 1 volt on all the red wires coming out of the 14 pin connector (14 pin connector is only red and black wires).
    Any recommendations to troubleshoot? I can't find a pinout or schematic but I see that there are basically 2 rails distributed.
    https://prnt.sc/m5lwqq
    http://prntscr.com/m5m6uh
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Delta DPSN-525AP Power Supply Repair
    I'm not familiar with this P/S, but it looks to me like there is a PFC stage, followed by two separate, individually regulated inverters (probably synced). So the fact that the -53 works indicated that the PFC works, but the 12V circuit is not, So your focus will need to be learning why.
    I'd start first by looking at whether the 12V output is shorted. If it isn't and the output is literally zero volts, you need to find out why the controller is not switching. If the controller is on the primary side, you can't use a grounded oscilloscope.
    PeteS in CA
    • R_J
      • Jun 2012
      • 9604
      Start at the missing 12 volt output and trace the secondary circuit back. The voltage will come from diode off a transformer secondary, if there is no voltage on that diode, check the primary side to see how it operates, ie does it have proper voltage to the switching fet/s, is the drive ic getting vcc and is being turned on.
      I could not find any schematic or even good pictures of the solder side.
      • jayjr1105
        • 281
        I'll try to get some high res photos on the back side when I get home.
        Ryzen 3600x
        FX-8802 Iron
        • jayjr1105
          • 281
          Here's a good shot of the back
          https://i.imgur.com/27K5XeK.jpg?1
          Ryzen 3600x
          FX-8802 Iron
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            try to heat up capacitors and checking for output voltage
              03-31-2024, 02:12 PM
            • dragon3x
              >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
              by dragon3x
              Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
              that is still quite new, as it worked OK for some months until it failed.
              At the time I was not into power supply electronics; it was put
              aside and a new power supply installed inside the computer. Also at the time
              power supplies were half the price of today's.
              On the PCB there are a D339 and 7500B chips.
              I have found that schematics with these 2 chips (see included file).
              Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
              Some measurements,...
              06-05-2024, 03:34 PM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Gentian
              Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
              by Gentian
              I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
              09-27-2025, 11:03 PM
