Bosch AL2215CV charger fix
  • Erdist
    • Jan 2021
    • 8
    • Vanuatu
    Re: Bosch AL2215CV charger fix
    Thanks momaka. It looks like there is a miniature crack on the conformal coating between the first and second diode, so good idea to check!
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Oh, and regarding R5 value... I think 22 KOhms is actually right, because that should provide about 6.76V on the Gate of the MOSFET (just do a voltage divider between R3, R4, and R5 and you will see that in order to get a high enough voltage to turn on the MOSFET, R5 must be at least a few 10's of KOhms.)
      Also, I just noticed my post from 2019... and yeah, this 2-transistor self-oscillating circuit does not look very well designed. Heck, the whole PCB looks very cheaply made an separation between adjacent HV traces not good at all.
      *EDIT*
      When I was mentioning R3, R4, and R5, I was referring to this schematic posted by DannyX:
      https://www.badcaps.net/forum/attach...8&d=1547107967
      Looks like that R5 designator is not referring to the same resistor as the one on your board. The one on yours (behind the MOSFET that connects the MOSFET's Source to primary-side ground) should be a low-value resistor: 3 Ohms sounds about right for that. Make sure you use fusible flame-proof (Metal Oxide / MOX ) resistor. If you use Carbon film, it may catch fire if it fails again. And for the resistor in front of the MOSFET, 20-30 KOhms will probably work fine. Yours looks like 39 KOhms (orange, white, black, red, brown - 5-band code for 39K 1%.) And the one above it that connects MOSFET's Gate pin to NPN BJT's Collector pin - 30 Ohms seems like an accurate value. The schematic posted by DannyX refers to that resistor as R7, and it is indeed showing as 30 Ohms.
      • Erdist
        • Jan 2021
        • 8
        • Vanuatu
        Momaka, you are a champion! Thanks very much for your help. It starts to make a little sense now, here's what I think looks to be the situation and the reason for my confusion:
        - on the schematics only R6 is in the 3 ohm range (3.6), the burnt resistor could possibly be 3 ohm with 1% tolerance, but confused about the location of that black band. Also the slot is marked as R5 on the board, which is not matching with the schematics. So perhaps go for 3.6?
        - Right after that, comes F3NK80Z (V6 on the schematics, V5 on the board)
        - then comes R5 on the schematics with 22k ohm, and it looks like it is 39k in the board. Seems like a significant difference.
        -followed by R7 in the schematics with 30 ohms, and on the board (also damaged) looks like it is 30.1k with 1%.
        Do I understand it right?
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Yeah, probably anything in the range of 3 to 4.7 Ohms will work... or at least make the PSU try to turn On.
          This resistor is used for current sensing, so higher value means it will give more negative feedback, so the PSU may self-limit the power faster... which might be desirable, given that it likes to blow up. Lower resistor = more power allowed by the PSU.
          LOL.
          Yeah, looks like the schematics are more or less accurate, but the designators aren't. Not a big deal, I suppose, as long as we say explicitly which part we are talking about so we don't get confused.
          Not a big deal either.
          39K will give about 12.76V max (with a 240V AC line input) at the Gate of the MOSFET, which is OK, since the F3NK80Z is rated for +/-30V V_gs.
          I don't think 30.1 KOhms makes sense for that position. In fact, I'm not even sure why they even have a resistor there. Most 2-transistor circuits I've seen connect the Gate of the MOSFET directly to the small BJT's Collector. That way, when the BJT turns On, the MOSFET Gate is driven to ground and that makes the MOSFET turn Off. If you use 30.1K, that MOSFET may never turn Off properly or make the PSU work only in self-limiting, thus grossly overshooting voltage on the output... or worse - blow up again. The bands also seem to indicate 30 Ohms from your picture. I see Orange, Black, Brown (should be Black, though), Gold, and Brown again. In a 5-band color code, first 3 bands are the digits, 4th is the multiplier, and 5th is the tolerance. So the above should read 300 with the multiplier being 0.1 (Gold)... i.e. 300 x 0.1 = 30 Ohms. And last band, of course, is for 1% tolerance.
          With that said, again I don't understand why they even have that resistor there. Just as a reference, here are a few 2-transistor 5VSB circuits from ATX PSUs, so you can see and compare how similar they are and what they did different:
          https://www.badcaps.net/forum/attach...1&d=1578459617
          https://www.badcaps.net/forum/attach...0&d=1451693563
          https://www.badcaps.net/forum/attach...9&d=1443215464
          • Erdist
            • Jan 2021
            • 8
            • Vanuatu
            Thanks again Momaka for your insights and helping out! I will give the repair a go and see how it goes, hope I can get the required parts. I need that drill going!
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              No problems.
              It really is just a matter of finding the right value resistors... or resistors that you can combine in series or parallel to get the right values.
              If you can't find any parts locally, see if there are any electronics repair shops near you and ask if they have any broken PC ATX PSUs or LCD monitor power boards. Chances are, you might find most parts on one. The MOSFET parameters for this PSU are not too critical, just as long as the voltage ratings are more or less the same.
              Once you fit all the new parts and are ready to test, make sure to use the series incandescent bulb trick. That way, if something is still bad, it should save most or all of your new parts from getting damaged/burned/blown.
              • motormayhem
                Lenovo T460 Only Charges on One Charger
                by motormayhem
                Laptop Question
                I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                05-12-2023, 01:46 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • flat-earther
                ASUS X54H laptop thinks it's always charging even with charger unplugged
                by flat-earther
                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                Windows also shows ''Plugged in'' when charger is not connected.
                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                If I let battery run out and say it has 3% Windows will...
                06-24-2025, 09:32 AM
              • Johndill
                Dell Inspiron 7567 LA-D993P odd charger issue
                by Johndill
                Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                Here are the tested scenarios:
                1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                2. With the laptop off, plug in charger (LED says on) & the front charging...
                11-16-2022, 10:55 PM
