OK to use a mylar instead of electrolytic?
  • berniedd
    • Mar 2007
    • 119
    The P3 computer began to have random reboots and a screeching sound was noted from the "Epraizer" PSU. No bulging caps on the Asus mobo, so I put in another, new PSU. Problem solved. Now I'm trying to recondition the Epraizer. No bulging caps or overheated/dimpled power ICs. I want to replace the suspect capacitors, but I did see a 0.22 uf/50v and a 1 uf/50 v electrolytic. Can I just replace these with mylar or ceramic ones of the same ratings? I already have these in stock in my parts bin. Besides, new electrolytics will eventually dry out again.
    Also, can I safely replace 1000uf/10 v cap with 1000uf/6.3v that's also in my parts bin?
    BTW the thing's populated with Fuhjyyu's, Teapo's and Su'scons!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: OK to use a mylar instead of electrolytic?
    1000uf/10v cap with 1000uf/6.3v is ok, only 3.3v 5v and 12v is seen on the secondary side
    The small electrolytics I am not sure about, they are very important on many powersupplies (having them fail shorted will result in the primary side going poof oftenly...)
    Wait for someone else to chime in on those...
    • Toasty
      • Jul 2007
      • 4171
      Many caps fail without bulging. All of those mentioned brands are crap. You're going to end up re-capping that entire supply. Is that cost-effective for a P3 supply?
      You can not replace electrolytics with mylar or ceramic. The circuit is designed to use the characteristics of a specific type of cap. You -may- be able to use a mylar or ceramic interchangeably, but not with electrolytics.
      Toast
      veritas odium parit
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Get rid of the Fuhjyyu and Su'scon.
        If any Teapo are bad replace all the Teapo too.
        Mann-Made Global Warming.
        - Dr Seuss
        • berniedd
          • Mar 2007
          • 119
          Yeah, maybe it's not really cost effective to take out all them caps, but the real reason I do it is for my own self-satisfaction and pride, that I've resurrected trash stuff and turned them into useful gear again.
          • berniedd
            • Mar 2007
            • 119
            I replaced all caps 470 uf and above with new Samxons GF series. This PSU is now back in service, no more reboots nor screeching sounds are observed.
            • Kingpin!
              3COM OfficeConnect Gigabit Switch 16
              by Kingpin!
              3COM OfficeConnect Gigabit Switch 16 (3C1671600)
              The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
              09-17-2023, 04:58 AM
            • Adenitz
              Replace electrolytic cap with bipolar one
              by Adenitz
              can I use this cap:
              https://www.tme.eu/en/details/ues1h4...tors/nichicon/
              Capacitor: electrolytic; bipolar; THT; 47uF; 50V
              to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
              What exactly I can expect to install bipolar electrolytic cap instead a regular one?
              Thanks.
              02-02-2022, 07:44 AM
            • ten-d
              Nippon Chemi-con 100uf 100v BP electrolytic cap
              by ten-d
              Hi all!
              I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
              01-30-2024, 05:18 PM
            • Perry Babin
              How do organic polymer caps compare to liquid electrolytic for reliability
              by Perry Babin
              I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
              If not organic polymer, what would be the caps that could take the most abuse?
              08-18-2025, 04:04 PM
            • AstutePauciloquent
              Requesting Help Identifying tiny Aluminium electrolytic
              by AstutePauciloquent
              Hi wonderful people. I have a MS-6315 P3 motherboard with very tiny Aluminium electrolytic capacitors. I've made an attempt to identify them from what ive learned so far they might be
              Aluminium Electrolytic
              G = Series
              10 uF
              16 = Volt
              104 Date code 2001 April? (not really important, but interesting)
              Please help to confirm or correct if i am wrong. Thank you
              10-20-2023, 06:29 AM
