OK to use a mylar instead of electrolytic?
  • berniedd
    • Mar 2007
    • 119
    The P3 computer began to have random reboots and a screeching sound was noted from the "Epraizer" PSU. No bulging caps on the Asus mobo, so I put in another, new PSU. Problem solved. Now I'm trying to recondition the Epraizer. No bulging caps or overheated/dimpled power ICs. I want to replace the suspect capacitors, but I did see a 0.22 uf/50v and a 1 uf/50 v electrolytic. Can I just replace these with mylar or ceramic ones of the same ratings? I already have these in stock in my parts bin. Besides, new electrolytics will eventually dry out again.
    Also, can I safely replace 1000uf/10 v cap with 1000uf/6.3v that's also in my parts bin?
    BTW the thing's populated with Fuhjyyu's, Teapo's and Su'scons!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: OK to use a mylar instead of electrolytic?
    1000uf/10v cap with 1000uf/6.3v is ok, only 3.3v 5v and 12v is seen on the secondary side
    The small electrolytics I am not sure about, they are very important on many powersupplies (having them fail shorted will result in the primary side going poof oftenly...)
    Wait for someone else to chime in on those...
    • Toasty
      • Jul 2007
      • 4171
      Many caps fail without bulging. All of those mentioned brands are crap. You're going to end up re-capping that entire supply. Is that cost-effective for a P3 supply?
      You can not replace electrolytics with mylar or ceramic. The circuit is designed to use the characteristics of a specific type of cap. You -may- be able to use a mylar or ceramic interchangeably, but not with electrolytics.
      Toast
      veritas odium parit
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Get rid of the Fuhjyyu and Su'scon.
        If any Teapo are bad replace all the Teapo too.
        Mann-Made Global Warming.
        - Dr Seuss
        • berniedd
          • Mar 2007
          • 119
          Yeah, maybe it's not really cost effective to take out all them caps, but the real reason I do it is for my own self-satisfaction and pride, that I've resurrected trash stuff and turned them into useful gear again.
          • berniedd
            • Mar 2007
            • 119
            I replaced all caps 470 uf and above with new Samxons GF series. This PSU is now back in service, no more reboots nor screeching sounds are observed.
            • Kingpin!
              3COM OfficeConnect Gigabit Switch 16
              by Kingpin!
              3COM OfficeConnect Gigabit Switch 16 (3C1671600)
              The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
              09-17-2023, 04:58 AM
            • Adenitz
              Replace electrolytic cap with bipolar one
              by Adenitz
              can I use this cap:
              https://www.tme.eu/en/details/ues1h4...tors/nichicon/
              Capacitor: electrolytic; bipolar; THT; 47uF; 50V
              to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
              What exactly I can expect to install bipolar electrolytic cap instead a regular one?
              Thanks.
              02-02-2022, 07:44 AM
            • Perry Babin
              Derating of polymer electrolytics
              by Perry Babin
              There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
              If they require derating, why would the manufacturer give them their rated voltage?
              This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
              https://www.mouser.com/datashe...
              10-24-2025, 11:57 AM
            • madscientist750
              Replacing electrolytic caps by solid caps on old motherboards
              by madscientist750
              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
              10-19-2025, 06:10 AM
            • Perry Babin
              Electrolytic cap endurance
              by Perry Babin
              From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
              Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
              Why do polymer capacitors...
              10-18-2025, 05:21 PM
