Replacing a cap with higher voltage, same capacitance.
  • circuitmonkey
    • Feb 2018
    • 26
    I am working on a slew of Seeburg Juke box boards, and while trying to procure the caps.... lets just say I ran into a few snags. These were built in the early 70's and some of the caps on the driver and amp boards have some small uF values. One in particular is a 75v 20uF axial Lytic(that is what is listed in the schematic). I can't find a new replacement(in regards to voltage). My understanding is(keep in mind, I am not real bright) as long as the capacitance is the same, a higher voltage can be used. I can find 100V 20uF axials(pricey), but I also see them rated to 450v(strangely not as pricey). Can someone with some experience in this give me a clue? Maybe in crayon? Thx.
  • redwire
    • 3912
    Re: Replacing a cap with higher voltage, same capacitance.
    Looking for exact old capacitor values does not always go well.
    In the old days you could buy 5uF or 20uF or 50uF, but that became globally standardized to 4.7uF, 22uF, 47uF etc.
    It's best to use the EIA E-12 values for parts. They are in decades, so "220" means preferred values are 0.22 or 2.2 or 22 or 220 or 2,200 etc.
    I would use a 22uF part. Tolerance on electrolytic capacitors is ±20% so a bit bigger value is fine.
    The 75V rating is also a bit odd, it became 63V, 80V, 100V as popular offerings from companies.
    Radial is lowest cost but you'd have to add a flying wire, spaghetti tubing and a dab of silicone glue, to replace an axial part.
    Some axials by Illinois Capacitor, Nichicon at Digikey like 1572-1095-ND but a vanilla part 2,000hr life 85°C, not long life or high temperature -those parts last longer.
    Such as United Chemi-Con KYB 22uF 80V $0.50 and 7,000hrs 105°C. Small compared to the older parts, so easy to put in there.
    Just Radios sells axial electrolytics and oddball (new) parts for antique radio restorations.
    • circuitmonkey
      • Feb 2018
      • 26
      Thank you! I put in my order and will update when everything is installed.
      • Santa Claus
        • Jul 2018
        • Norway
        As redwire wrote, the tolerance are quite high so don't be to worried about the capacitance value. To use one with 10 or 20% higher value is normally OK. Since electrolytic capacitor quite often are used as decoupling at supply voltage it is better to go up than down in value.
        Regarding the voltage this is the maximum voltage the capacitor is designed for. Replacing with a higher voltage is no problem. Based on life time (MTBF) it is an advantage to not use capacitors close to there maximum voltage.
        • circuitmonkey
          • Feb 2018
          • 26
          Looking over my notes, and I could verify by checking my order, I substituted 12V 50uF caps with 16V 47uF caps, and 6V 50uF caps with 10V 47uF caps. These were the only two instances where I used a lower capacitance rating as I would assume since capacitance goes down over time (generally tossing anything with 10% or greater loss) that as long as the caps are good, 47uF should be enough. Everything else I was able to keep close at slightly above. Should I order some bigger caps or do you think these will suffice? I should state, after I restore function to the amp and give it a thorough inspection with slow run up on the Variac, I plan to put a signal through it and check for distortion on the O-scope. Some of these caps may be replaced again with something better. I found it hard to spend a lot not knowing the variables. Still have plenty of issues not related to the caps such as resistors on the driver board that should have a value of 100 Ohms measuring 180 Ohms out of circuit and over 200 in circuit. Little things like that. So far, no dead shorts. But if I do come across some of the transistors being fried in these, I have a feeling it is going to be a real headache trying to find equivalents. Feel free to chime back and thanks again for your help.
          • circuitmonkey
            • Feb 2018
            • 26
            Some pics of the disaster occupying my bench.
              If I were you I would replace those carbon composite resistors with carbon film type at least.
              BTW, you can also use 56uF cap in place of 50uf.
              I.E. https://www.digikey.com/products/en/...tors/58?k=56UF
              • circuitmonkey
                • Feb 2018
                • 26
                I looked into your resistor comment and you are right. It seems that metal film might be the best composition for audio resistors. Any reason I might not want to use those? I had already purchased Nichicon caps, so I'll check the signals once I restore function before I grab something a little longer lasting. I'm making some cheat sheets for quick reference as I have at least 10 of each board. It is going slow, but I took this job to learn and that I am. I appreciate all the input. Here's some more pics. Burnt/blown traces, components, bad.... everything. You know, dirty circuit porn. Enjoy!
                  When those composite resistors start drifting in value, they can affect the biasing of the semiconductors which will cause problem.
                  • circuitmonkey
                    • Feb 2018
                    • 26
                    Just an update: I haven't fallen off the planet. I have been building a capacitor leakage tester designed by Paul Carlson. I have a lot of caps to test on these boards and it seems to me having a good way to test for DC current leakage would be prudent. This required etching a PCB and populating. We are now at the testing and debugging stage, so I hope to have it running on the bench soon. I'll include some pics and tests when I get back to these amp boards. Thx again for all your input.
                    • Baste
                      Replacing a bad Cap with higher value.
                      by Baste
                      Hello experts people,
                      First time poster but lurking the Forums for few days now. I'm a beginner hobbyist who's trying to fix what ever I can and learned along the way. Right now what I have is a busted 58inch LCD TV with backlight issue. Long story short, I kinda found the issue (or atleast on the right track) it's on the power board with bad caps (broken pin). It seems an easy fix, just replace it with the same one and away it goes, but for whatever reason I cannot find the exact value in my place or online store in my country. The bad Cap is 39uf 450volts in parallel. The...
                      Yesterday, 01:56 AM
                    • mikkele86
                      Luxman R-5045 - Capacitor at amplifier output broke, can i replace with higher capacitance ?
                      by mikkele86
                      Hello Im renovation a Luxman R-5045
                      On the attached picture there is a cap 0.047uF (47nF) and a resistor, 10ohm. What is their purpose ? and what would happend if I were to replace the caps with lets say, 10nF or 100nF ?
                      because thats what i got in stock :/
                      04-16-2024, 12:37 PM
                    • SwedishDiesel
                      Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                      by SwedishDiesel
                      Howdy folks,
                      I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                      10-30-2021, 12:47 AM
                    • Delicieuxz
                      Replacing caps in an old speaker system. Should I use a higher value here?
                      by Delicieuxz
                      I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
                      https://youtu.be/1LRIzePlma0?t=273
                      I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
                      Would 680uF be good value to try in place of the 470uF originals?
                      06-25-2023, 08:27 PM
                    • dougg3
                      Faytech FT0150TM touchscreen turning on and off - fixed
                      by dougg3
                      I've been dealing with this 15" touchscreen monitor from the early 2010s. Over time, it has become more and more difficult to power on. As soon as a video signal comes in, the Faytech logo appears on the screen and then it goes black. Then a couple of seconds later the Faytech logo comes back up on the screen and it goes black again. This process repeats over and over again. Eventually if I leave it on long enough, the video display finally comes up and it works fine. The longer I leave it turned off, the longer it will boot loop before working correctly again. I tried a different AC adapter...
                      02-03-2024, 03:04 PM
