Miller 375 Plasma Burt Cap..
  • R_J
    replied
    Re: Miller 375 Plasma Burt Cap..
    There is a bit of information here https://www.elektroda.pl/rtvforum/topic3329021.html
    Here is a translate of the miller reply to the person
    I wrote to Miller and here's the answer:
    Miller part number 218760 is a proprietary part not available as a service item. There is no third party source for the part.
    The subject is closed. Thanks.
  • eccerr0r
    replied
    The logo appears to match that of in the schematics....
    This device seems to be some two way insulated gate controllable bidirectional diode... weird.
  • CapLeaker
    replied
    Originally posted by KG7AMV
    Yea, I also hate parts labeling like that..
    I Also Notice that PM1 Has Miller Part # What Could it Be? Seems to be the only proprietary #'d part.
    That isn't a Miller stamp... Maybe Microchip, Micrel etc?
  • R_J
    replied
    I did find a similar item on alibaba
  • KG7AMV
    replied
    5 legs..
  • R_J
    replied
    Does it have 4 legs or 5 ? it could be similar to the ALFET ALF08NP16V5 but this is a fet, the schematic shows similar but with transistors. So it's a TO-247-5 package
    You could use Go Advanced and attach the documents , that way all the pictures don't have to download each time we go to the thread,
  • KG7AMV
    replied
    I Also Notice that PM1 Has Miller Part # What Could it Be? Have not seen any Other Proprietary Parts on The Board.
    Here Are The Extracted Schematic Images
  • KG7AMV
    replied
  • R_J
    replied
    So they are replacing the 10Ω resistor with a ptc thermistor? too bad they don't provide a picture of the 200656.
    I guess that resistor was a 10Ω, I hate when they mark 100 and its actually 10 multiplied by 0
    This digikey 570-1024-ND would likely work but it is $9.24
  • KG7AMV
    replied
    Originally posted by R_J
    Do you have a picture of the original R123 ptc thermistor? or did they have that white ceramic resistor in its place?
    Ceramic Resistor was in R123..
  • R_J
    replied
  • KG7AMV
    replied
    Just need to find a source that is not a Welding shop or miller part # $13+ ouch..
  • eccerr0r
    replied
    Ah... yeah, normally SMPS have thermistors there, it's very typical along with a relay to get higher efficiency. I was thinking about how practical a regular resistor would do there...may work fine too but I've never worked on welders before...
    oh... main reason for posting... after being infatuated with varactor diodes (yes for radio ).... that MOV RV1 in that schematic is hideously wrong.... I think two inverse series zeners would be a better representation for a MOV than two inverse parallel varactor diodes...
  • KG7AMV
    replied
    Miller Support Got Me A Schematic For The Machine To My E-mail Box This Afternoon Will Upload Soon..
    Bus Precharge Circuit and R123 is 10ohm PTC Thermistor has to be something cheaper..
    http://www.brweldingsupplies.com/mil...-10-ohm-25-deg
    +1 For Miller...
    Schematic Drawing
  • KG7AMV
    replied
    Yea, reason why i am not using solder wick.. Proper desoldering tips..
    I will test the transistors, photo the PCB reassemble with any failed /damged part replaced.
  • eccerr0r
    replied
    well, that's no fun, this is a 3 or more layer board with embedded layer via connections I guess that's the end of remote debug for me, need a continuity checker along with the board for me to work on multilayer boards without a schematic.
    Just a word of warning: this board is extremely fragile to work on, so be careful: if you damage the plated vias, game over.
    The only thing left to suggest: if the semiconductors all look good (i.e. no shorts) it might be worth to just replace that 100Ω resistor and see what it does, make sure you use a DBT and just run it without welding/cutting to see if it at least powers up... I suspect it's simply completely dead at the moment prior to any parts removal?
  • KG7AMV
    replied
    That Lacquer type Coating on these board becomes a mess.
    The 2 Transistors I Marked 10 and 11 are DSP45-12A Rectifiers That is Were The Traces Go Will Know More When I Remove them all and get that plastic Cover Off.
    Should have my 1.3mm and 1.6mm Nozzles By Friday. Found the solder wick but with that coating PITA..
  • eccerr0r
    replied
    How about a picture of the board now, with the components removed, so we can look at how the traces go?
  • KG7AMV
    replied
    Sorry Typo Cap.. But the Cap When Checked Has No value.. Like it is Not Even There Open Leads On the DMM..
  • CapLeaker
    replied
    hmm... what other resistor? I see 2 caps, a relay, another cap, the 100 Ohm resistor and a stack of IGBT's. That white thing in between the relay and the old resistor is a cap and should measure open. I think it was right next to the relay on the board.
  • CapLeaker
    Miller Diversion 165 TIG no arc
    by CapLeaker
    Hmm… someone brought me this Miller Diversion 165 TIG welder for repair. Claim is it doesn’t arc. Well it tries doing something if I put the tungsten tip straight to the aluminum plate. All I hear is a little tick… tick… tick…, I have the power LED on, but the other (blue?) LED doesn’t light up. I think it is supposed to when there is an actual arc.
    So I opened it up, found a bad looking connector between the main board and the small HF board. Checked the SCR and few other things on it and found nothing. Then tried again. Same thing. I will not for its own life strike...
    05-14-2025, 03:32 PM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
  • alltvrepairs
    Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
    by alltvrepairs
    I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
    I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
    Any one met this problem in the past?...
    10-08-2025, 07:34 AM
