Unsafe PSUs
  • pentium
    • Mar 2006
    • 2778
    Re: Unsafe PSUs
    yep, raidmax.
    Stupid keyboard...
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    • AJ847.63e
      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
      by AJ847.63e
      Hi Folks,
      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
      05-06-2025, 10:37 PM
      Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
      by momaka
      This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
      Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
      Macron Power Technology Co. LTD.
      Let’s look at the PSU itself.
      The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
      06-02-2021, 10:05 PM
    • ktmmotocross
      need bios for china laptop S06 C-A 5Y51 S06 MB VERC
      by ktmmotocross
      09-30-2022, 12:32 AM
    • RukyCon
      Modding Two PSUs to Output 12V
      by RukyCon
      Hello again, this might be a bit of a far-fetched question, but is it possible to modify a 36v and a 48v power supplies to output 12v? Both power supplies appear to use the same topology, they both also have a dedicated 12v winding wired to the control chips, meaning that as soon as i change it so the main output is 12v, then the dedicated windings will not be able to output 12v, meaning it will not start up. However, if i were to then take the main output and tie it to where the dedicated 12v output would go, then it should be able to run fine?
      Anyway here is a quick overview of...
      02-22-2021, 01:33 AM
    • dikei
      China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
      by dikei
      Hi guys!
      I'm new to TV repair and just started looking into troubleshooting guides and other online info.
      Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
      1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
      2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
      From my initial research...
      07-06-2023, 11:53 AM
