Unsafe PSUs
  • pentium
    • Mar 2006
    • 2778
    Re: Unsafe PSUs
    yep, raidmax.
    Stupid keyboard...
    Find Nedry!
    Check the Vending machines!!
    • AJ847.63e
      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
      by AJ847.63e
      Hi Folks,
      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
      05-06-2025, 10:37 PM
      Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
      by momaka
      This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
      Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
      Macron Power Technology Co. LTD.
      Let’s look at the PSU itself.
      The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
      06-02-2021, 10:05 PM
    • reformatt
      Macbook display shortage in China?
      by reformatt
      Aftermarket screen prices have jumped for all Apple laptop display assemblies recently. I got something in Chinglish from a supplier on Whatsapp:
      Latest news on supply of Macbook screen with top covers
      1. Industry inside news: macbook screen with top covers with logo won't be restocked in the short term. The product selling now are all from the factories existing inventory. No factory will dare to produce new products in the short term. First come, first served.
      2. The supply of Macbook LCD only is normal and will not be affected by this goverment interview...
      11-04-2025, 06:11 PM
    • ktmmotocross
      need bios for china laptop S06 C-A 5Y51 S06 MB VERC
      by ktmmotocross
      09-30-2022, 12:32 AM
    • RukyCon
      Modding Two PSUs to Output 12V
      by RukyCon
      Hello again, this might be a bit of a far-fetched question, but is it possible to modify a 36v and a 48v power supplies to output 12v? Both power supplies appear to use the same topology, they both also have a dedicated 12v winding wired to the control chips, meaning that as soon as i change it so the main output is 12v, then the dedicated windings will not be able to output 12v, meaning it will not start up. However, if i were to then take the main output and tie it to where the dedicated 12v output would go, then it should be able to run fine?
      Anyway here is a quick overview of...
      02-22-2021, 01:33 AM
