Bestec revisited
  • everell
    • Jan 2009
    • 1514
    Bestec revisited
    I have seen much posted on this website that Bestec is nothing but poorly designed mobo killer. Most of the problem has been attributed to 5VSB poorly designed. I have repaired two Bestec model ATX-250 12E psu that did indeed have poor 5VSB flaw. The pc board was discolored from overheating and components failed which allowed the voltage to go well above the 5 volt level.
    On the other hand I have repaired two Bestec model ATX-250 12Z which have a 8 pin pwm chip (A6351A) for the heart of the 5VSB circuit. The 5VSB did NOT fail in either of these two PSU, and the pc board was not discolored from overheating on these two PSU. Perhaps the engineers have admitted the need to redesign - and the later model does indeed seem to have a much improved 5VSB.
    Bad capacitors can still be a problem, but that is a problem on lots of PSU. Perhaps it is time to elevate the later better designed Bestecs to a higher level of quality, especially above PowMax (aka maximum bang). I'll post some photos of one of these later models, along with a drawing of this new chip design 5VSB.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • Wizard
    • Mar 2008
    • 2296
    Re: Bestec revisited
    Much better.
    This tend to not fire up if cap is bad in that area especially this IC design is done right.
    Cheers, Wizard
    • i4004
      • Oct 2006
      • 2029
      what was wrong with those, and what's the price for that model?
      • everell
        • Jan 2009
        • 1514
        But ...... Did the two ATX-250 Rev Z units that failed for you have the pwm chip in the 5VSB circuit (I don't trust labeling) AND if so did the 5VSB circuit fail? My concern is the 5VSB failing causing burn damage to the PSU and causing damage (or killing) the mobo.
        Of the two that failed for me, one had a resistor value change that simply shut the power supply down. The other had a shorted switcher which took out the fuse.
        I don't doubt that this is an economy (bargain basement) class of PSU. But I do think this later model is much safer, less of a fire hazzard, and less likely a mobo killer. It also has more capacitor filtering on the outputs than the infamous POWMAX.
        • i4004
          • Oct 2006
          • 2029
          who were you replying to in that post?
          some pm?
          anyway, thanks for the answer.....
          • Toasty
            • Jul 2007
            • 4171
            >>who were you replying to in that post?<<
            You, I'm sure. He thought you made the "On the other hand I have..." statement, not realizing you were quoting him.
            Anyway, Bestec's name has been so thoroughly trashed, it would be tantamount to naming your child Adolf. No one will forget...
            Had a Compaq system come in yesterday with problems running programs and strange happenings at boot. Opened the cover to dust it out, and there was a Bestec ATX-250-12Z. Pulled it and put in a new el-cheapo ($29) supply and the system runs fine. Told them, when they have the money to come back and I'll swap it for a better unit.
            veritas odium parit
            • Toasty
              • Jul 2007
              • 4171
              Here Everell-
              Datasheet IR IRIS-A6351
              Edit: Sheet won't attach. Says too big. brb
              veritas odium parit
              • Toasty
                • Jul 2007
                • 4171
                Again-
                Shrunk original by 120kb
                veritas odium parit
                • everell
                  • Jan 2009
                  • 1514
                  To i4004 I would like to apologize if I have offended you in any way. Your posts are interesting and informative, and you experience and expertise is GREATLY appreciated.
                  To Toasty I would like to say that your latest Bestec failure sounds very predictable for what I was saying. If The PSU has the IC for 5VSB circuit, then it protected the mobo such that you were able to simply replace the PSU and get computer back into operation. It would be interesting if you would open it and look for:
                  1. Does 5VSB use IC or two transistor design?
                  2. Is there any pc board discoloration from heat in the 5VSB circuit?
                  3. If not a 5VSB failure - is it just another capacitor failure? Do you have one of those Bob Parker Blue ESR meters? I just got one and am excited about all the new things I am finding out about.
                  Since this is a website for PSU design and troubleshooting, I hope I am not being offensive in asking such questions and hoping for more discussion.
                  • Wizard
                    • Mar 2008
                    • 2296
                    Bestec traditionally used transistors/discrete components for 5Vsb which tend to run hot, bad capacitors, blow up or overvolt and destroy mainboards.
                    But when they started using intelligent designed 5Vsb using IC that has shortcircuit, overvoltage protections built into the IC. And tend to run cooler, more reliable. If the capacitor go bad, this type of IC tend to shut down and play safe.
                    Cheers, Wizard
                    • i4004
                      • Oct 2006
                      • 2029
                      heh, yes...still gotta wonder how come those words of a "stranger" didn't sound surprisingly familiar...just like echo...
                      no reason to apologize, i was just confused by your 1st paragraph which seemed to came out of nowhere...but ok, now you know i use '>' to quote....
                      as i'm too lazy to use full form reply(i use quick reply 99% of the time)
                      also, i usually only use lower case, so that's another way to distinuguish...
                      no, surely not...it was just a small misunderstanding....
                      when i asked who were you replying to, i didn't mean anything condescending(even if it may look that way). i was just asking because i didn't see origin of that 1st paragraph...that was all...
                      to that extent i should apologize to you, if it came somewhat ambiguous..
                      so i apologize if it sounded harsh...that wasn't my intention...
                      yes, discussions about psu failure modes are very interesting...in the end they tell us what psus are safe to use, and which are not...and that it VERY important
                      which one?
                      • Toasty
                        • Jul 2007
                        • 4171
                        i4004 >>which one?<<
                        I think it was WhoFlungDung brand.
                        Weighed about 1/2 of what the Bestec does. Ratings say 400watt... ROFLMAO yeah, right.
                        veritas odium parit
                        • Toasty
                          • Jul 2007
                          • 4171
                          >>1. Does 5VSB use IC or two transistor design?<<
                          ?? I have not investigated but am assuming it's the IC type. It's identical to yours except it's dated 0344 and has less goop and 2 bulged caps. Same WAN NIEN 101V0A markings.
                          >>2. Is there any pc board discoloration from heat in the 5VSB circuit?<<
                          Board is excellent, "factory fresh".
                          >>3. If not a 5VSB failure - is it just another capacitor failure? Do you have one of those Bob Parker Blue ESR meters? I just got one and am excited about all the new things I am finding out about.<<
                          Yes - 2 obvious ones: 1 bulge, 1 bulge & leak - 2200uF/10v Jamicon's
                          Yes
                          Yup, it's fun. Just wish I didn't have to zero it EVERY TIME. :\ Instructions had some errors too, but I pushed through them. Novice builder would be lost or asking questions. (Resistor codes wrong and regulator(?) IC wrong #)
                          veritas odium parit
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3113
                            I don't think bestec's newer power supplies are too terrible except for the bad 5vsb thing that goes on with them. I have a 300w version that has a actual AC rectifier, Panisonic primary caps, CapXon secondaries, decent heatsinks and a good cfm fan.
                            ...I still don't trust it.
                            • Toasty
                              • Jul 2007
                              • 4171
                              370forlife >>...I still don't trust it.<<
                              Like I said earlier, it's the name that kills it because you KNOW it's history. It wouldn't matter if the case was platinum plated, it weighed 3 pounds, had 3 fans, and the caps were all Panny's, it still says Bestec.
                              Run Away! Run Away!
                              veritas odium parit
                              • everell
                                • Jan 2009
                                • 1514
                                Toasty - I have never heard of WhoFlungDung brand. Is this a joke or are you serious?
                                Just for fun, lets compare this Bestec ATX-250 12Z with a REAL mobo killer - a 350 watt PowMax that I ran for 6 years with no trouble, but didn't realize what I had.
                                Looking at the photo of the Bestec, you can see that it has two nice size toroid coils and several filter caps on the AC line input. The bridge rectifier is one piece, and a respectable size. Two filter caps 470 uF @ 200V. It uses a pwm chip UC3842, and TPS3510 supervisory chip. It has four feedback optocouplers, one of which is to protect the 5VSB circuit which uses the A6351A pwm chip. It has two toroid filter coils on the output.
                                Now look closely at the photo of the PowMax which fortunately didn't crap out. On the line input one much smaller torroid line filter. Look at the bridge diodes - four seperate diodes - of three distinctly separate physical sizes. The two filter caps are 330 uF @ 200 V. The pwm switch is the old AP494, no supervisory chip, the 5VSB circuit is just a couple of transistors, and NO feedback optocouplers. The main switching transformer is about half the size of the one in the Bestec. It has only one toroid filter coil on the output. The only redeeming thing I found is a 7805 regulator chip for protection of the 5VSB.
                                Thanks to finding this website and looking over the many posts and experience you guys (and gals?) have, I immediately pulled the PowMax out of service. Haven't decided yet on its replacement, but no more PowMax!
                                I don't mean to say the Bestec is highest quality - but for the "cheaper" PSU, it does look to me like it is far superior to the PowMax.
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  everell >>Is this a joke or are you serious?<<
                                  Dead serious. >:| >:| >:|
                                  Made by HongKongFlyApart Company, LLC.
                                  ROFLMAO
                                  veritas odium parit
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    370forlife >>I don't think bestec's newer power supplies are too terrible except for the bad 5vsb thing that goes on with them.<<
                                    I don't think the newer ones, such as the 12Z discussed here, are going to have this issue. Everell has substantiated that they have improved their design. It seems that they learned of the destruction they were causing and built more robust and better protected units.
                                    Everell's confirmation of the protection makes it more likely that a re-cap of (now)my unit might be in order just to get rid of the crap caps.
                                    Few of us would know any better if not for these forums. We'd simply look at the failure as an "oh well", and go get a new PSU. Or, would waste a lot of time chasing a software issue that did not exist.
                                    @Everell
                                    It seems that the PowMax and Bestec units are related to the same designer/builder, Wan Nien.
                                    Cheers!
                                    Toast
                                    veritas odium parit
                                    • jpdoe
                                      • May 2007
                                      • 237
                                      I remember reading somewhere that Wan Nien is a PCB manufacturer.
                                      If so, it's not the PSU maker, but a part provider.
                                      http://www.ettimes.net/theme/etv2.asp?memberid=49650297
                                      • i4004
                                        • Oct 2006
                                        • 2029
                                        powmax rocks hard!
                                        everything that's connected to it...hehe...
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
                                        • mrcliem
                                          CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                          by mrcliem
                                          Hello...
                                          I got my self a dead CM V700 PSU, with nothing on +5vsb
                                          I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                          As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                          The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                          I have read the datasheet and and still can not...
                                          06-29-2023, 08:18 AM
                                        • socketa
                                          Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                                          by socketa
                                          Rescued this one
                                          Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                                          Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                                          The 5VSB drops to 2.5V when it 'shuts down'
                                          And the voltage across the primary cap falls from 335V to 330V at the same moment
                                          I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                                          12-20-2022, 03:06 AM
                                        • hobostove
                                          Corsair RM1000e - Help identify 5VSB Zener diode
                                          by hobostove
                                          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                          There's a 22ohm resistor that's melted and open, but it still has the bands.
                                          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                          It looks like the diode connects the source and drain of a TNY284...
                                          03-27-2025, 02:25 PM
