ds2331 battery
  • olymbou
    • Mar 2014
    • 30
    • lar
    ds2331 battery
    hi friends. i made a circuit and in the circuit i am using the ds2331. and the thing is . i want to replace a rechargeable battery 3 volt and getting it charged every time the ds2331 is powered how can i make it work can somebudy help
    thanks john
    • Jul 2011
    • 6039
    Re: ds2331 battery
    I look at the data sheet it does not explain how you turn the bit on for it to charge
    Now the DS1302 dose a better job of explaining how to do this
    I have done this with a Basic Stamp about 10 year ago and you can even store data in it memory I will have to see if if I still have a copy of it
    Here is a project that I did about 10 years ago how to start and stop the time chip and set the charging bit
    https://forums.parallax.com/discussi...ReSet_Demo.bs2
    • olymbou
      • Mar 2014
      • 30
      • lar
      Re: ds2331 battery
      thanks sam i will look for it
      • Ancient1
        MacBook Pro 2012 A1398 : Battery BMS circuit repair OR can it boot WITHOUT a battery ?
        by Ancient1
        Hi
        I received such Laptop as junk. Opening it I saw a lot of whitish water residue , but no corrosion really ( few coils have small brown rust marks, no green copper ).
        I cleaned all thoroughly and interestingly , its the Battery BMS board that has the real corrosion spots.. under the protective clear Goo !!
        I want to try and power up the laptop
        Battery is swollen. But I don't want to buy a new battery right now , of course .
        I started work on the BMS by zooming in on green spots . 2 VIAs are filled with rusted copper goo - who knows...
        04-17-2024, 12:46 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
      • trepachka
        iPad Air A1475 Boot loops after replacing battery
        by trepachka
        This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
        The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
        I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
        11-08-2024, 03:17 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
