Smpsu ic
  • barry wilkins
    • Aug 2009
    • 172
    Smpsu ic
    Has any body got the data sheet for this IC
    S03525AN
    thanks
    Barry Wilkins
  • R_J
    • Jun 2012
    • 9633
    Re: Smpsu ic
    Are you sure its not SG3525AN ??
    • barry wilkins
      • Aug 2009
      • 172
      Re: Smpsu ic
      Hi, you might be right it is very difficult to read because it is on a daughter board standing upright,I was trying to read it with a mirror.
      thank you very much for your reply.
      Barry
      • PeteS in CA
        • Aug 2005
        • 3586
        • USA, Unsure of Planet
        Re: Smpsu ic
        Good heavens! I haven't laid eyes on one of those (well, actually its compliment, the SG3527) in (mumble, mumble) years! The two ICs are improved versions of the venerable SG3524. One of the improvements was totem pole output drive pins. Another, IIRC, was improved dead-time control (to prevent destructive cross-conduction). It's a nice mature voltage mode PWM IC.
        PeteS in CA
        • Lee M.
          LG 55LN5710 backlight diffuser sheet order
          by Lee M.
          Hello all, new member here. I replaced the LED strips and found that the BL can be turned on with the TCON board and LCD panel disconnected. So new LED strips are working fine. Now the problem. There are 3 diffuser sheets on this set. One sheet is thicker than the others and I know it goes in first next to the LED strips. But one side of this sheet has a rougher texture than the other side. Does the rough side go up or down? The 2 thinner sheets have tabs that will only allow them to be installed one way so that's good. One sheet is what I would call plain translucent. The other sheet is whiter...
          11-29-2021, 07:52 PM
        • sofles
          Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
          by sofles
          Hi there,
          Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
          With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
          05-30-2025, 01:11 PM
        • lfhlaw
          60LN5600 white reflective sheet
          by lfhlaw
          So I had to replace the LED lights on this TV and that worked out nicely. But the White reflector sheet that helps to diffuse the led lights evenly was glued into the back chassis which had to be removed to replace the LEDs.
          Placing the white reflector sheet caused it to not sit evenly - causing weird diffusing when TV was all put together. Picture is still decent, but now there are dark and light spots due to the white reflector sheet not sitting against the back chassis.
          Anyone have thoughts on replacement white reflector? or do I just scavenge broken TVs for...
          05-23-2022, 07:14 PM
        • loko
          Tesla 13.7 body sculpt repair problem, need help with finding the thyristor marking.
          by loko
          Hello everyone.
          I have a device that is used to shape the human body muscels and burns fat. Works on the principle of electromagnetic impulses. One thyristor in side is shorted which has only this unknown mark on it ( QC230301 ). I can't find any information about it anywhere on the Internet. I tried to replace that thyristor with one of 1.6kv 800A and after 5min. of work he has burned out again, which means that he is probably weak. There is no schematic diagram on the internet, but that didn't suprise me because all the transistors and chips that are on the boards have their markings...
          10-27-2024, 11:31 AM
        • Rictech
          Panasonic SA-MAX770PU SMPSU board fault....
          by Rictech
          Hello everyone. 😀
          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
          There are no devices that have exploded or otherwise show signs...
          08-26-2024, 01:05 AM
