Cooltek 600W (CT-600) recapped...issues
  • Ludran
    • Mar 2009
    First of all I would like to say this is an excellent forum with a lot of great tips and tricks.
    I recapped three psu´s late weekend.... two chieftec 360w and one cooltek 600w the chiefteks now work great with no issues but the cooltek is giving me lots of headache.
    A little background about the cooltek bought it in the beginning of 2006
    http://www.driverheaven.net/reviews/...600w/index.htm
    http://www.sweclockers.com/articles_...id=570&page=10
    http://www.cooltek.de/
    It started after a couple of years to have cold boot-up problems running a dual core opteron system with a HD2900xt until it refused to boot it anymore
    tried it in another system amd socket 754 with a Radeon 9600xt and it worked there until it started to spin the northbridge fan and the the other fans as well as the fan controller was flickering sending out 4.8V on the 12V line and 1.75V on the 5V line when the computer was in stand-by.
    I decided to check it out and to my surprise in had Fuhjyyu caps on the secondary and those had swollen very bad so I recapped it using Rubicon and Teapos I know Teapos isn't preferable but it was what I had at hand
    However it didn't do the trick and the symtoms remained it can't boot any systems... tried four of them from socket A to phenom II .
    12V line still measures around 4.8V in standby and 5V line around 1.75V
    Before recapping the lines were fluctuating +/- 0.1V without load but now they are stable but it still as useless.
    I hope someone here has an ideas about what the fault might be
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Cooltek 600W (CT-600) recapped...issues
    Very Important...did you use ruby con or rubicon. Also, did you test the caps with a esr meter to make sure they were ok?
    • Ludran
      • Mar 2009
      it was Rubycon I used but mostly Teapos unfortunatly and I never checked them either since I don't have a esr meter but they are new have had them laying around for a few years.I know it´s utterly stupid but I was anxious to try it out I can't get hold of any good caps locally here so....but hell I could do the chinese touture of recapping it again and it would be easiest for me to order from Elfa in Sweden.
      The 7 caps I changed were marked
      4. 3300uF 10V.0511.vent EC105 Celcius diameter 10mm, pitch 5mm
      1. 4700uF 16V.0511.vent EC105 Celcius diameter 13mm pitch 5mm
      1. 1500uF 10V.CA08.vent 105celcius C(M) diameter 10mm
      1. 1000uF 10V.0509.vent 105celcius diamter 8mm
      to be changed to
      4.Sanyo 10ME3300WX
      Voltage rating: 10 V dc
      Capacitance: 3300 uF
      Tolerance: ±20 %
      Max. ripple current: 2.77 A @ 100 kHz 105°C
      ESR:
      Impedance: 0.018 Ω @ 100 kHz
      Dissipation factor: 0.23 @ 120 Hz
      Diameter: 12.5 mm
      Height: 25 mm
      Pitch: 5 mm
      1.Sanyo 16ME4700AX
      Voltage rating: 16 V dc
      Capacitance: 4700 uF
      Tolerance: ±20 %
      Max. ripple current: 2.55 A @ 100 kHz 105°C
      ESR:
      Dissipation factor: 0.24 @ 120 Hz
      Diameter: 16 mm
      Height: 35 mm
      Pitch: 7.5 mm
      1.Sanyo 10ME2200WX
      Capacitance: 2200 uF
      Tolerance: ±20 %
      Max. ripple current: 2.36 A @ 100 kHz 105°C
      ESR:
      Impedance: 0.021 Ω @ 100 kHz
      Dissipation factor: 0.21 @ 120 Hz
      Diameter: 12.5 mm
      Height: 25 mm
      Pitch: 5 mm
      1.Sanyo 10ME1000WX
      Capacitance: 1000 uF
      Tolerance: ±20 %
      Max. ripple current: 1.43 A @ 100 kHz 105°C
      ESR:
      Impedance: 0.038 Ω @ 100 kHz
      Dissipation factor: 0.19 @ 120 Hz
      Diameter: 10 mm
      Height: 16 mm
      Pitch: 5 mm
      thou the diameter of them might cause problems getting them there as well as the pitch on 4700uF since it's very crowded in there
      I continue to check if elfa has any other suitable size wise
      • cubytus
        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
        by cubytus
        Hi to all,
        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
        01-10-2024, 01:26 AM
      • otaku_nut
        Vizio E701i-A3 fixed but now has red vertical line
        by otaku_nut
        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
        08-19-2025, 06:11 PM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
      • FALKLAN
        Running Line Voltage and Integrating LED Pods - Automotive
        by FALKLAN
        Howdy everyone! I hope all is well where ever you are!
        I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
        I am uncertain how to convert this line into a switched 12v output line for the LED pods....
        02-05-2025, 12:30 AM
      • mindoverflow
        ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
        by mindoverflow
        hello,
        there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
        I changed pads and thermal paste.
        I run mats test but it is reporting 0 errors.
        I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
        After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
        02-09-2022, 03:22 PM
