Panasonic TC-P54G25 Repair Guidance..
  • Rocket21
    • 7
    Ok before sending in SC board for repair I was hoping for some help/confirmation I am on the right track.(likely send to Ptsparts, any other recommendations?)
    TV "popped" and then didn’t turn on; 10 blink code, but actually 4 after replugging in and then 10 after power hit (tv clicks on at plugin then again a second or two later )
    Saw service manual & not sure I did this right but tested for resistance: p11 seems fine p35 didn’t know how to test this; Unplugged SC board from power supply (sc2/p2) plugged TV in got a 7 blink code
    • Note manual says unplug sc20 (ribbon) to test though, is that a typo perhaps? I did try this and got same 4 blinks on plugin 10 after power button
    Thoughts/ideas? Thanks all!
    AJ
  • Rocket21
    • 7
    Re: Panasonic TC-P54G25 Repair Guidance..
    Mods - Not sure why, yet UNABLE TO EDIt/ DELETE ORIGINAL POST above.... please remove as it's in the wrong forum. Sorry Thanks!
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
      11-20-2024, 08:52 PM
    • AquaMan Ua
      by AquaMan Ua
      05-17-2025, 09:40 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
