I have an ASROCK ConRoe 1333-D667 Motherboard with Core2 Duo E6700 powered by FSP-250 PSU. This has 15A on the 12V line according to the label. I am running with the Onboard graphics and one 250GB Seagate Sata drive. The combo seems to work fine but wanted to know if this is enough PSU for this build. This board only requires a 20-pin PSU. This PSU has the standard 4-pin connector as well as two of the original 6-wire "P2" connectors, so it's an early Pentium 4 PSU.
PSU Compatibility Question
Re: PSU Compatibility Question
Should be absolutely okay with that 15A rating on the 12V rail. Heck, you could probably run a 20-40 Watt video card on that setup and still be okay (or alternatively, two extra HDDs). The 12V rail might start to sag a bit, though. And the PSU run a bit warmer.Comment
by 2wtnHi all, have been lurking here for quite some time, and now my first post
People who have experience replacing CD3217B12 chips (on macbooks), I have a few questions for you.
As far as I understand, the CD3217B12 exists in more than one type and the different types are not cross-compatible. Is that correct? How many types are there in fact that you know of and which motherboards is each type compatible with? Do they look visually the same, or is there some difference in marking?
What should I look at when buying these chips online, for example on... -
by AdminSome sticky topics have been moved to this thread:
Laptop Screen Compatibility - finding a compatible laptop screen with LED-backlight.
Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...12-27-2023, 03:43 AM -
by JSin21Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
I have Samsung Smart TV UA65MU6100WXXY version DA01
Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...4 Photos -
by n_pacHello everyone,
I am looing for suggestion from someone who already tried to replace ThinkPad T14 Gen 1 motherboard with any compatibility versions!
Regarding to the shape of ThinkPad P14s Gen 2 for example or ThinkPad T14 Gen 2, they look same to me except the sleep sensor which is not included in some versions!?
Any suggestion would be very helpful!
Thanks... -
by AJ847.63eHi All,
We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling... - Loading...
