CD3217B12 compatibility
  • 2wtn
    • Dec 2017
    • 5
    • israel
    Hi all, have been lurking here for quite some time, and now my first post
    People who have experience replacing CD3217B12 chips (on macbooks), I have a few questions for you.
    As far as I understand, the CD3217B12 exists in more than one type and the different types are not cross-compatible. Is that correct? How many types are there in fact that you know of and which motherboards is each type compatible with? Do they look visually the same, or is there some difference in marking?
    What should I look at when buying these chips online, for example on aliexpress or eBay, to verify compatibility? There is a huge range in prices, few vendors list compatibility, and even then it's unclear whether they actually know it's compatible or are just copy-pasting from some other source.
    For instance, there is one particular seller on eBay that sells chips claiming compatibility for these boards: 820-01949, 820-01987, 820-02016, 820-02020, 820-02100. Is this a complete list of boards that use the same CD3217B12 type and should I assume that all others use a different type?
    What is your source for these chips, and how has your experience with buying them online been so far? Have you encountered fakes or DOA chips? Can you recommend a particular source to get them? I am located in Israel so my preference would be a reliable source in Europe or in China, although if no such exist, I would probably buy from the US.
    Your replies are greatly appreciated.
  • mon2
    • 16658
    Re: CD3217B12 compatibility
    Which logic board are you repairing ?
    There are some vendors we / you can trust on Aliexpress but not all - based on feedback from this and other forums.
    Best if you can remove from the same donor board and reball it and then use on your board. That is a lengthy process. Respectively, if you can find a ready to use component, that will simplify the repair.
    For starters, see here:
    https://www.aliexpress.com/item/1005...610001157939_7
    https://www.diyfixtool.com/en-ca/pro...42822141313253
    • piernov
      • Jan 2016
      • 4438
      • France
      There are definitely a large amount of dead or fake chips when you buy on eBay/Aliexpress. You can read many reports about "new" CD3215/CD3217 not working whereas donors worked.
      As for the CD3217 compatibility issue, it is unclear what the issue is (at least to me, maybe someone knows more about it). Most commonly seen on 820-01700, people have reported that only replacing one chip from a donor (same model number) did not work, or even replacing all chips didn't work and they had to replace the ROMs too.
      However it is hard to tell if it's not because all chips or the ROM from the patients were defective as well.
      Same for people who said that one set of chips from a donor didn't work on a patient, who knows if the donor chips were good in the first place.
      For now the most reliable way would be to have a donor board which you know that at least USB-PD is working, and replace all USB-C controllers and ROMs. For example iCloud locked, or maybe something like dead GPU. Sadly these are still rare and not cheap. It's more common to stumble across 820-01700 with dead SSD ICs, but since working SSD (at least partially) is required to boot T2 and proceed further with USB-PD negotiation you cannot know if the USB-C controllers are working.
      • 2wtn
        • Dec 2017
        • 5
        • israel
        I had a 820-02016 board here with a bad CD3217B12 and I started this thread for it. Customer didn't approve the repair, so this particular board is no longer relevant. However looks like more boards with these chips will be coming in, so I would like to get some stock in advance. Trying to figure out the compatibility situation with them so I have a better idea what to order. Have you personally had some experience replacing these chips with new ones you bought online? If so, it would be good to know exact boards you successfully replaced them on, and boards that the repair did not succeed.
        Buying donor boards with unknown faults with the current prices doesn't make much economical sense to me, so if new chips are not a good solution then I guess I just don't have an economical way to fix these boards.
        P.s. thank you Piernov for your work on Openboardview!
        • thodoris10
          • Mar 2014
          • 17
          • Greece
          Hello, I have the same issue. I have a board 820-01700 with CD3217B12 I order a new one and now the board is only working with battery and the Type C charger (original) is stuck at 5v ~ 0.25Amps and when the machine boots with battery is swapping to 20v 0amps.
          I also replace the cd3217b12 from a donor board and I have the same issue.
          Anyone knows if with DFU restore will fix the problem and somehow re-register the cd3217 to ROMs or T2 chip.
          Is very annoying that you can't fix this board with a NEW part !
          • mon2
            • 16658
            Start with measuring the voltage to ground of each LDO rail on each ACE controller (cd321x).
            Post each measurement.
            • thodoris10
              • Mar 2014
              • 17
              • Greece
              My problem is the compatibility of CD3217B12 if it was able to put back the original the problem is solved but the original is defective.
              • thereedcloud
                • Trinidad and Tobago
                paul daniel is look for someone who can get a four port usbc board to work with only two ports…preferably the side that you can do dfu on….any ideas?
                • nivirus2000
                  • Apr 2017
                  • 46
                  can someone give me some input on CD3217B12 - 02P0EKS. which i can replace it with for 820-01700-A
                  thanks
                  • eastcoastcomputing
                    • Feb 2023
                    • 59
                    Hi there, I exactly in the situation where all my initial diagnostic points at faulty CD3217B12BCE on a 820-01700 and I'm contemplating replacing it/them. As anyone got a definite answer as to whether they can be replaced by pairs or all four have to be replaced? Do they have to come as a "set" or absolutely from a donor board otherwise they won't work? What about the ROM mentioned before? Does anyone have the chip ref on BV? Or did someone manage to compile a list of CD32s and boards compatibilities that I didn't find? Thanks!
                    • piernov
                      • Jan 2016
                      • 4438
                      • France
                      https://logi.wiki/index.php/CD3217_a...ibility_issues
                        • Feb 2023
                        • 59
                        Thank you very much!
                        • jsrossmann
                          • Nov 2019
                          • united states
                          This is a really old post but if it helps, I was able to use the CDs from 820-02020 donor to fix 820-02016. I can't confirm that they are all compatible 820-01949, 820-01987, 820-02016, 820-02020, 820-02100 but the seller may be right.
                          • PITERPENY
                            • Jul 2023
                            • 547
                            • Ukraine
                            • microelektronics
                            from my limited observations so far, all 3217 are interchangeable if the MacBook has two ports, they can only be installed on MacBooks with two ports, and from MacBooks with 4 ports, they fit from MacBooks with 4 ports. but almost always the indicator will be 20v/0A (sometimes 5v/0A, but after recovery via DFU, the indicators will be restored and the Mac works in normal mode. Apparently, the 3217 power supply program is somehow rewritten.
                            • reformatt
                              CD3217 and I2C addressing
                              by reformatt
                              This was going to be a short post, however I thought I'd write this up as I haven't seen a deep dive like this. I began writing this up for an A2337, but think this deserves its own post for my memory and any corrections that may or may not be needed.
                              A good video describing the straps for CD3217 I2C addressing:
                              https://www.youtube.com/watch?v=MV39IbgPiYc
                              So which CD3217 is needed for a A2337 MAC or for others for that matter? Here is the addressing map for TPS65982 since we don't have datasheets for the CD chips and it appears to be the same anyway.
                              08-06-2026, 10:17 PM
                            • abajor
                              A2251 820-0194 CD3217B12 (U3100_W) donors/replacements
                              by abajor
                              I have an A2251 820-01949 which had a failed TPS62180.
                              I was fortunate enough to find the video on "Exploding USB-C" https://youtu.be/CAGnMR1aVuE?si=O1oYvAyNMeAr4dv4 what was shared here on the topic.
                              I was wondering if there are any cross compatible models that have been discovered?
                              We have an apple ID locked A2179 Mac AIR it's CD3217B2 has different lithography and looks slightly gray but I'm assuming it's the same chip in principal, but I am also aware that for some inexplicable reason mac flashes these chips firmware depending on their location on the board....
                              06-27-2024, 01:10 AM
                            • feherhollo
                              WSON8 NEW Bios Chips READ, ERROR, ETC.
                              by feherhollo
                              I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                              I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                              For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                              11-26-2023, 09:33 AM
                            • dj-bobr
                              Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
                              by dj-bobr
                              I kindly ask for help with Thinkpad BIOS/ME repair.
                              Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
                              It worked fine until I tried to remove whitelist.
                              Steps taken:
                              - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
                              - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
                              03-05-2024, 04:28 AM
                            • Kooopa
                              1 - HP Elitedesk 800 G3 SFF turned into 2 non working unit. Error 5.2
                              by Kooopa
                              Hi everyone, I need some insight as to what's causing this problem.
                              I was repairing an HP EliteDesk 800 G3 SFF that powers on but doesn't POST. I figured it was a corrupted BIOS, so I tried HP's BIOS/EC recovery first, but no luck—I couldn't even get the "Sure Start" screen to appear.
                              So here is the exact sequence of what I did:
                              I had another working unit, so I figured I would lift the BIOS flash first and transplant it as a diagnosis to see if I could get the broken unit to POST. But nothing happened. Upon hitting the power button, the fan would...
                              08-29-2026, 09:02 AM
