24v to 12v project guidelines
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Re: 24v to 12v project guidelines
    Originally posted by momaka
    Hmmm... you mean stolen?
    Could be, but could also be from the wreckers or something like a flea market....which doesn't automatically mean it's NOT stolen, but whatever
    The question is whether or not someone has broken radio codes before...couldn't find too much info.
    Wattevah...
      master hoarder
      • May 2008
      • 12175
      There used to be a ton of small shops for car alarm and radio repair back in the 90's and early 2000's in many places of Eastern Europe. Not sure how it is now. But you may be better off going to one of those if there is one around town. I remember they could get almost any radio going again.
      With electronics so cheap these days, it seems that the radio theft "business" is pretty much dead now. So I don't know how easy it would be to find a small place like that.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        That's not really DIY for a DIY geek like me, which would only make me wonder how those guys do it. Also, the cost of such a procedure would outweigh how much that junker is worth, which may be enough to get a new USB/AUX (no cd) no-name brand off the shelf...
        Wattevah...
          • 31214
          https://www.elektroda.pl/rtvforum/forum412.html
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            I got the bin for my model, found the EEPROM IC inside the thing, but can't figure out how to program it. Seems the pinout is different from that of "recent" chips, so some fiddling may be required...I have one of those CH341 programmers.
            Wattevah...
            • Stephen
              A2991 Logic Board issue, 20volts 0 amps help!
              by Stephen
              Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
              09-10-2025, 03:16 PM
            • Stephen
              A2991 logic board issue, 20volts 0 amps help!
              by Stephen
              09-10-2025, 03:15 PM
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
              Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
              The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
              Securing a good thermal interface between...
              10-07-2024, 04:35 AM
            • Fisher8865
              MacBook Pro A1990 stuck at 5v .592 amps
              by Fisher8865
              Hi guys
              I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
              05-30-2024, 07:36 PM
