SGI Octane 747W Cherokee PSU noise
  • halfloaf
    • Dec 2017
    • 20
    • Uk
    I recently acquired a second hand SGI Octane Cherokee PSU, and while it does power on and 'work' in the workstation, it makes a rather disturbing noise. I wouldn't call it coil whine, it's more like a warbling electrical noise. The noise is from a specific area on the PSU but before I open the PSU and void the sellers warranty, I thought I'd put up a post to see if anybody has come across this before or has any ideas?
    I'm quite happy to replace bad caps etc but if it's something that is likely to cost more than say £25 then I might as well return the unit for a refund. My only issue is these are becoming quite rare and hence resellers sell them for £££ hence the desire to troubleshoot and fix. (I also don't like filling rubbish dumps with electrical waste!)
    The PSU has an SGI part number of 060-0035-001.
    I've tried to record the sound in the link below. What you'll here firstly is the socket switch being flipped, then the relay kicking in then the warbling sound. I've tried different power cords and also wall outlets, no change.
    The sound is audible from about 3m (9ft) from the PSU.
    https://youtu.be/lPwTEdxI9mk
    Any advice gratefully received.
    Jacques
    • 31163
    Re: SGI Octane 747W Cherokee PSU noise
    go ask on Nekochan forums.
    http://forums.nekochan.net/
    • halfloaf
      • Dec 2017
      • 20
      • Uk
      I'm aware of the Nekochan forum and am a member there. While 99.5% of them can tell how to NUMA link two servers together or compile some obscure piece of code, they are a bit thin on the ground when it comes to electronic matters. Tracing 3.3v lines, yes. Diagnosing a sick sounding psu, very very unlikely.
        • 31163
        well they would know if the sound is "normal"
        • halfloaf
          • Dec 2017
          • 20
          • Uk
          Hi, the PSU should be dead quiet apart from the internal fan. The fan noise is separate to this other noise.
          I had one of these 8 years ago and this is by no means normal.
            • 31163
            i had 2, but not with that psu - mine had the inferior ones.
            maybe you have a coil loose.
            • halfloaf
              • Dec 2017
              • 20
              • Uk
              I also have an old Lucent psu, it's dead quiet apart from sounding like a jet engine (fan). It is whisper quiet in all other respects though. Cannot use the Lucent one as it does not work with VPro graphics boards unfortunately.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                Cherokee Int'l seems to be quite defunct, having been acquired by another company in 2008, which has since been acquired by some division of GE that doesn't seem to be into computer PSUs. Anyway, since your PSU is probably 10 to 20 years old, probably some output capacitors have gone high ESR, high enough to cause audible oscillation. What complicates matters, if that is the case, is that modern low impedance capacitors may be too low impedance, causing stability or oscillation problems.
                IF you decide to try replacing output capacitors, use older series like Nichicon PS, PM, or PJ series. These are likely to be contemporaries or near in design age to those you would replace.
                Pictures and information about the output capacitors on the PSU (values, vendors, series) would probably be helpful.
                PeteS in CA
                  • 31163
                  most sgi psu's are loaded with pana FC's and similar grade from nichicon.
                  probably part of the design spec from sgi to the OEM's
                  • halfloaf
                    • Dec 2017
                    • 20
                    • Uk
                    I took a chance last night and plugged it in to the Octane. The warbling sound dissipates when you power on the workstation. When powering it down, the loud noise resumes. The PSU is a bit like modern ones, it never fully powers down and enters a 'power save' mode that draws about 0.2A while plugged in to the wall but turned off at the workstation side. This is sort of confirmed as the psu remains warm in one spot after about three hours of no workstation activity.
                    I've decided to keep the unit so will open it today, take some pictures and plug it into a wall socket to establush which component(s) / area makes the sound.
                    Pics to follow.
                    • halfloaf
                      • Dec 2017
                      • 20
                      • Uk
                      Some photos. This is one of the boards in the PSU. I plugged the PSU into the wall socket and listened for the noise. The noise seems to emanate from the black Potter and Brumfield relay, or immediate surrounding components....as in very immediate. Could the yellow PTG MPX GPF capacitor (??) also make a noise?
                      Anyhow, here are some photos, excuse the flash, it's late...
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        start with all the sm lytics on the small board.
                        hell all the lytics could be done at this age.
                        • halfloaf
                          • Dec 2017
                          • 20
                          • Uk
                          "sm lytics" = surface mount electrolytic ?
                          Sorry not familiar with most electrical abbreviations.
                          • tony359
                            by tony359
                            11-28-2023, 05:18 AM
                          • Asxetos21
                            Dell Latitude 5511 audible electrical noise
                            by Asxetos21
                            I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
                            The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
                            Any advise on how to narrow it down?
                            The schematic is available here:
                            Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
                            03-03-2025, 09:53 AM
                          • MegaZAC
                            Onkyo TX-SR805 noise in one channel
                            by MegaZAC
                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                            There's some logic behind it. As soon as I select an input I get only left...
                            04-23-2025, 10:09 PM
                          • courtcircuit
                            Philips HTS8000 home cinema noise problem
                            by courtcircuit
                            Hello
                            I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                            Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                            Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                            I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                            Removed each of tyhe boards
                            02-08-2025, 08:22 AM
                          • sew333
                            Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                            by sew333
                            Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                            So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                            So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                            I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                            06-14-2024, 07:30 AM
