Magnavox DRV power supply SMPS
    master hoarder
    • May 2008
    • 12164
    • Bulgaria
    #161
    Re: Magnavox DRV power supply SMPS
    The MOSFET going bad.
    Since you had the bulb in series with the PSU while testing the mod board, that means the MOSFET and resistor must have been bad before that. This also happens to coincide with why the bulb kept staying On before that.
    • johnfin
      • Oct 2017
      • 115
      • united states of america
      #162
      Resistors came today. Installed .68ohm resistor and same results: no light and power is getting to board. Circuit breaker ok, power to board, resistor and mosfet new. No power at ouput. Whats the next test?
        master hoarder
        • May 2008
        • 12164
        • Bulgaria
        #163
        Measure the DC voltage on the main cap. Should get about 160-170V.
        - If not, let us know. Check fuse F2001
        - If yes, check the DC *voltage* on both sides of R2101 and both sides of R2106. Also check voltage on pin 6 (Vcc) of the NCP1200 controller. (on that note, did you replace the NCP1200 after the last test when the PSU smoked?)
        • johnfin
          • Oct 2017
          • 115
          #164
          cap = 160vdc
          fuse good (of course)
          pins 6 and 4 of 1200 = 7vdc (yes replaced)
          when measuring resistors, can I use neg of big cap for ground, then each side of resistors.
          Frankenboard coming alive, right?
            master hoarder
            • May 2008
            • 12164
            • Bulgaria
            #165
            Originally posted by johnfin
            cap = 160vdc
            Good.
            pin 4 is primary-side ground - i.e. tied down to the negative (-) lead of the primary-side input cap (the main cap). So you should *not* see any voltage on it.
            Meanwhile, pin 6 (Vcc) should be somewhere between 9.8 and 11.4V (10.6V average) while the IC is working. 7V DC is too low for the IC to start, so that indicates either the IC is detecting some fault or its not getting proper power.
            With that in mind...
            YES.
            Always use the negative lead of the big cap when measuring voltages on the primary side.
            The fact that there is some voltage on pin 6 (Vcc) with respect to the (primary) ground means R2101 is probably good, but still check it.
            Checking voltage on both side of R2106 is also important to make sure we are supplying the IC with high enough voltage (minimum 30 volts needed on pin 8, HV).
            Yes.
            The fact that you have some voltage on the Vcc pin of the NCP1200, that nothing is blowing up/smoking anymore, and that the incandescent series bulb is not coming fully On means we are getting there. Slowly, but will happen eventually.
            So like I mentioned in the beginning, at least with this mod you won't blow more components if there is something wrong with the circuit. The PSU may look "dead" with not voltage outputs, but measuring the voltage on its Vcc pin may give a good indication of what's going on.
            • johnfin
              • Oct 2017
              • 115
              #166
              4&6 of the 1200 means I went across them to get the voltage. =7vdc
              R2101 is a HUGE ceramic resistor, ohms fine and measured each side to neg on main cap = 167vdc
              R2106 is a smd, no real voltage measured from each side to neg on main cap
              ohms fine
              All resistors in series with 2106 ohm out fine.
              So whats next?
                master hoarder
                • May 2008
                • 12164
                • Bulgaria
                #167
                ohms fine
                Hold on, other resistors in series with R2106??? R2106 should connect directly on one side to pin 3 of the main transformer and directly to pin 8 (HV) on the NCP1200 chip.
                Did you replace the orignal SMD R2106 resistor (and remove the other series SMD resistors) from the original design with a 22 KOhm resistor as I drew on the schematic?
                If not, that definitely needs fixing. Pin 8 (HV) of the NCP1200 chip needs at least 30V for the chip to work. If the resistance is too high, that would cause the NCP1200 to have low Vcc voltage and not turn On.
                • johnfin
                  • Oct 2017
                  • 115
                  #168
                  ok, you threw me a curve. I was looking at r2106 on the board. they are all disconnected. the 22k (its good)is new and connected to pin 8. What resistance and wattage should I try?
                    master hoarder
                    • May 2008
                    • 12164
                    • Bulgaria
                    #169
                    Sorry about that. When I was drawing the schematic for the mod board, I reused one of the resistors for R2106 and forgot to remove the "R2106" designator on the board, so that's what probably got you confused.
                    the *new* R2106 (which doesn't even need to be placed where R2106 is), should be 22 KOhms and I think 1/2 to 1W power rating will be more than enough. Give that a try and lets see if there are any voltage outputs.
                    • johnfin
                      • Oct 2017
                      • 115
                      #170
                      the 22k is what you called for and what it is. needs to be lowered i guess. any thoughts.
                        master hoarder
                        • May 2008
                        • 12164
                        • Bulgaria
                        #171
                        Try 10k then. I doubt that's the issue, but nevertheless.
                        • johnfin
                          • Oct 2017
                          • 115
                          #172
                          you were right, didnt work. Paralleled a 18k to get 9900ohms and pins 4-6 read 7.14vdc. Whats next.
                            master hoarder
                            • May 2008
                            • 12164
                            • Bulgaria
                            #173
                            What's the voltage on both sides of R2106 (relative to primary-side ground)?
                            Also, what's the voltage on R2108 on the side that is connected to MOSFET Q2101? (Again, relative to primary-side ground.)
                            We need to understand why the IC is not switching and why Vcc is so low.
                            **EDIT**
                            Looks like the IC might be stuck in protection mode either due to over-current overload or the start-up cap is too small, causing the IC to think the PSU has a short-circuit on the output. But let me know what voltages you get for the above items so we can get a full picture of what's going on.
                            • johnfin
                              • Oct 2017
                              • 115
                              #174
                              R2106 = 157/154vdc
                              R2108 = zero both sides
                              was taken to - side of main cap.
                                master hoarder
                                • May 2008
                                • 12164
                                • Bulgaria
                                #175
                                Sorry for the delay in response, I was traveling again.
                                I looked at the datasheet again, and it appears the IC is indeed stuck in short-circuit protection, given the readings above. You can make R2106 back to 22 kOhms again.
                                After that add another 10 uF cap with the 10 uF cap already there (for a total of 20 uF). If that doesn't work, up the capacity to 30 uF (3x 10 uF capacitors in parallel) or just use a single 33 uF cap if you have one. If that doesn't work, then try 47 uF last. For each of these, measure the output voltage of the PSU. And if the PSU does *not* work, measure the voltage on both sides of R2106 and also on pin 6 (Vcc) of the IC. Hopefully, this should give us more clues for what to change next.
                                • johnfin
                                  • Oct 2017
                                  • 115
                                  #176
                                  22K back
                                  10uf added to 10uf in parallel
                                  results
                                  2106 = 157vdc 148vdc
                                  2108 = zero
                                  pins 4&6 = .06vdc
                                  added 22uf to existing 20uf caps in paralled
                                  same but pins 4&6 went up to .1vdc
                                    master hoarder
                                    • May 2008
                                    • 12164
                                    • Bulgaria
                                    #177
                                    22K back
                                    results
                                    2108 = zero
                                    pins 4&6 = .06vdc
                                    Hmmm...
                                    But in post #164 (with the original 22k and 10 uF cap), you said you had 7V DC on pin Vcc of the NCP1200 IC?? Can you verify that measurement again?
                                    It doesn't make sense for the voltage of the IC to fall down that low with the parallel caps. Please check and report back.
                                    • johnfin
                                      • Oct 2017
                                      • 115
                                      #178
                                      So your mighty 1200 chip is not so mighty. I removed the additional caps, 22k resistor in tact, still no voltage so I replaced the 1200 and guess what, 10volts on pins 6-4. I removed the chip so that I dont blow thru a dozen of these figuring things out. Back to square one.
                                        master hoarder
                                        • May 2008
                                        • 12164
                                        • Bulgaria
                                        #179
                                        Well, your voltage measurements seem different every time, even with supposedly the same parts. That doesn't happen very often, which makes me suspect either your equipment or your measuring techniques... especially given the thread history in the first few pages.
                                        10V means the chip is working along with the rest of the PSU (actually should be 10.6V, but that's still close enough and within range... are you rounding voltages, though? If yes, please don't.) Did the PSU have no output then?
                                        With results like these, I honestly feel that were getting close to the point where I'd rather you send the PS to me or someone else here (if anyone is willing) so that we can get it running for you. Heck, I'm even willing to pay for the return shipping just to get done with this thing.
                                        I mean no offense, as i know you came here to get your PS fixed and maybe even learn in the process... but without good repeatable results, we can't really get anywhere.
                                        • johnfin
                                          • Oct 2017
                                          • 115
                                          #180
                                          Well since you have not answered any PM's or emails in the last 179 posts I wont hold my breath or waste my time with you anymore, phony baloney.
                                          FOR THOSE FOLLOWING THIS THREAD - DONT FIX YOUR DVR. OBSOLETE. IF RECORDING SHOWS FROM TV BUY A $20 RCA DTA880 OR SIMILAR (THERE ARE A BUNCH OF NEW ONES FOR SALE IN 2018). CONNECT TO USB DRIVE AND YOU ARE DONE.
                                          THE END
